Custom front pipes - TCCoA Forums
post #1 of 1 (permalink) Old 09-26-2010, 05:05 PM Thread Starter
97Tbird4.6's Avatar
Custom front pipes
I just installed the front pipes with cats from Mandrel Exhaust Systems. They o2 sensor locations were revised and are very easy to get to. They did a Magnaflow "Y" pipe section for me. I needed 2 small pipes with slight bends on the inlet sides and a straight section on the outlet side. All the pipes were long and it needed cut to fit. Once the fitting was done, it bolted to my Dynomax catback perfectly.
Throttle response is better as well as mid-range power. The tone is lower, but you really hear it when you are on the throttle. I am very happy with the performance of the new exhaust.
Sean
97Tbird4.6 is offline
