Hollowing/Removing Cats? - TCCoA Forums
post #1 of 10 (permalink) Old 12-10-2010, 10:36 AM Thread Starter
CougarChaserXR7's Avatar
Well I was wondering what are the pros and cons of doing this?
1995 Cougar Xr7 4.6
The never ending debate:
http://forums.tccoa.com/showthread.php?t=132847
CougarChaserXR7 is offline
post #2 of 10 (permalink) Old 12-10-2010, 10:56 AM
Mgino96tbird46's Avatar
Pro: none
Con: Check engine light
In my opinion, if you are going to replace or remove the factory catalysts, put some high flow cats in there. They are not that much of a restriction and you won't be harming the environment. I don't mean to sound like an eco-freak, but I prefer to be responsible when it comes to things like this.
Last edited by Mgino96tbird46; 12-11-2010 at 01:05 AM. Reason: incorrect info- my bad
Mgino96tbird46 is offline
post #3 of 10 (permalink) Old 12-10-2010, 04:24 PM
lowbird96's Avatar
pros, not much
cons, poor gas milage, check engine light, failed emissions testing, reduced performance, also on some cars hollowing the cats make a bad smell and makes your exhaust sound like crap.
get some high flows or remove the 3rd cat or both
third birds the charm.. I HOPE
lowbird96 is offline
post #4 of 10 (permalink) Old 12-10-2010, 05:20 PM Thread Starter
okay thanks. So will a high flow cat cause a decrease in gas milage?
1995 Cougar Xr7 4.6
post #5 of 10 (permalink) Old 12-10-2010, 06:05 PM
No.
post #6 of 10 (permalink) Old 12-10-2010, 06:20 PM
Originally Posted by Mgino96tbird46 View Post
Pro: slightly more flow
Incorrect. Hollowing out the cat does not increase flow. Yes it increases cross-sectional area, but the huge void in the catalyst chamber reduces exhaust gas velocity and will disrupt the flow more than if the cat was there. The only way this increases the engine's performance is if the catalyst is plugged up and/or broken apart, thereby blocking the flow.
post #7 of 10 (permalink) Old 12-10-2010, 07:42 PM
Scott D's Avatar
I've always just taken the cats off of the car
Scott D is offline
post #8 of 10 (permalink) Old 12-10-2010, 08:08 PM
Scott D's Avatar
I know it's not a Ford, but my C-1500 sounds rather good ... http://www.youtube.com/watch?v=F1y7pV7tuRg
Scott D is offline
post #9 of 10 (permalink) Old 12-10-2010, 10:35 PM
92's don't have OBD 2, thus don't have rear O2 sensors, thus won't throw a code.
post #10 of 10 (permalink) Old 12-11-2010, 04:25 PM
conversion02's Avatar
My advice, dump the whole 2 into 1 into 2 crap stock system and have something made. Even better yet - http://www.mandrelexhaustsystems.com/servlet/StoreFront
conversion02 is offline
