Explorer Block hugger headers - TCCoA Forums
post #1 of 5 (permalink) Old 03-02-2011, 07:11 PM Thread Starter
I have read alot of threads here about headers for the MN12, just curious if anyone has tried to make Dynomax Block huggers or other explorer headers work?. I have a set GT-40P heads.
mrbowlernc is offline
post #2 of 5 (permalink) Old 03-17-2011, 10:31 PM
LOLA's Avatar
The only true Explorer headers out there are Torque Monster and they will not fit period.
I don't see the block hugger headers fitting either.
LOLA is offline
post #3 of 5 (permalink) Old 03-18-2011, 01:40 PM
The problem is the steering shaft; there's a mod somewhere here for adding ujoints to it to make mustang headers fit, but you'd have to search it out.
post #4 of 5 (permalink) Old 03-31-2011, 12:08 PM Thread Starter
thanks! say the article out there for the steering rod mod. will be going with GT-40P heads. decided to just modify a set of mustang headers using parts from custom header websites. I'll let everyone how it turns out when i finish.
post #5 of 5 (permalink) Old 03-31-2011, 02:46 PM
A cheap trick to run GT40 P heads with factory headers is to cut the flange off the explorer manifolds and use it as a spacer. That will give an extra 1/2" of clearance, which is just enough to avoid burning up plug wires, but small enough that you won't create other issues.
