Any cali guys removed the rear cat and passed smog still? - TCCoA Forums
post #1 of 40 (permalink) Old 05-19-2011, 12:01 AM Thread Starter
I am trying to make my car a little louder. I was thinking of removing the rear cat out of the system I already removed the resonator. The 2 individual front cats are staying. I was wondering if any of you had problems with passing the cali smog test after removing the 3rd cat. My car will appear to have the 3rd cat still if I do remove it. I will cut the Y cat apart and weld up a new Y pipe and then weld it into the Y cat and then weld it all back together. I am just trying to make my car sound like it is actually a V8. I don;t wwant it really loud, maybe just a little louder than a stock 2v mustang.
fordfreak300 is offline
post #2 of 40 (permalink) Old 05-19-2011, 02:08 AM
ogbird95's Avatar
my mufflers did me fine, look nice too.
ogbird95 is offline
post #3 of 40 (permalink) Old 05-19-2011, 10:41 AM Thread Starter
you just put the SLP mufflers on and left the 3rd cat?
post #4 of 40 (permalink) Old 05-19-2011, 12:38 PM
Faster than Porkchop
cjchevez's Avatar
I think Porkchop passed the smog test like that .
1997 Ford Thunderbird 4.6 Sport .
60'...... 2.06
1/8th .. 9.194
mph .... 77.13
mods*
PI heads *PI intake*Mark VIII torque converter*Cobra T-loc w\4.10's * Jmod*tranny fluid cooler*P&P stock T/B & plenum*UD pulleys* Dynotech 4in ds*80mm Lightning maf*Xcal2*02 GT intake tube.
cjchevez is offline
post #5 of 40 (permalink) Old 05-19-2011, 12:43 PM Thread Starter
I tried listening to the sound files in the sticky above, but most of them were now gone. I am just hoping to be able to get a nice sound and not have to keep redoing everything.
post #6 of 40 (permalink) Old 05-21-2011, 12:48 PM Thread Starter
I'm overwhelmed with all these responses lol.
post #7 of 40 (permalink) Old 05-21-2011, 02:19 PM
dDUBb's Avatar
Removing the 3rd cat will not make your car louder - its just going to make your smog inspection numbers go way up but Im sure you'll still pass with the factory cats up front.
Sounds like a waste of time, you would be better off Cutting your mufflers off, that will make your car louder, but you are going to lose a little back pressure at the same time.
dDUBb is offline
post #8 of 40 (permalink) Old 05-21-2011, 03:36 PM
Earl's Avatar
My 95 had no mufflers first and no third cat second. No third cat made the car much louder, I don't know about smog through
Earl is offline
post #9 of 40 (permalink) Old 05-21-2011, 04:22 PM
dDUBb's Avatar
This is when loud becomes obnoxious and annoying at certain highway speeds.
My professional opinion ... leave it stock or just put some different mufflers on it. Dont cut off the 3rd cat - its illegal.
dDUBb is offline
post #10 of 40 (permalink) Old 05-21-2011, 07:41 PM
Raptor22's Avatar
Thats why I'm glad mine's just a resonator, which I plan to delete this summer when I get my car back from the body shop... (hopefully Tuesday, keeps getting delayed...)
[-----[ Conner ]-----] ASE P2 Automobile Parts Specialist - P4 General Motors Parts Consultant
The Blunderbird - 1989 Ford Thunderbird
3.8L V6 / M5R2 / 145,005 miles
Thunderbird SC Suspension Swap - Eibach Pro-Kit
JBL Premium Audio Swap - JL CP108 Subwoofer
Resonator Delete - Magnaflow DI/SO Muffler - Custom 2.5in Exhaust
Raptor22 is offline
post #11 of 40 (permalink) Old 05-21-2011, 11:11 PM
ogbird95's Avatar
yep, has a nice idle and makes a little noise when i step on it, but not obnoxius.
no drone either
what you should do is get the borla resonator and mufflers , that would make it badass
ogbird95 is offline
post #12 of 40 (permalink) Old 05-22-2011, 11:22 AM Thread Starter
I don't want it too loud. It's a daily driver and I am getting old. I will try some mufflers and see how I like it. The 3rd cat will stay. If the 3rd cat helps that much with the smog numbers and makes it that much easier for me to pass smog, then I am keeping it.
post #13 of 40 (permalink) Old 05-22-2011, 09:19 PM
i thought about doing this also but im kinda hasted on it but the flomasters put out great sound with all three cats
newkid510 is offline
post #14 of 40 (permalink) Old 05-24-2011, 01:57 PM
Don't they do a visual inspection during a SMOG check? I ran into that here in PA, had to take my car somewhere else where they weren't so observant.
John Fritz is offline
post #15 of 40 (permalink) Old 06-10-2011, 03:11 PM Thread Starter
I decided not to take out the 3rd cat. I didn't want to mess with it when it comes to smog time.
post #16 of 40 (permalink) Old 08-01-2011, 11:58 AM Thread Starter
I ended up just getting stock 04 cobra mufflers and welded them on to my car. The car sounds like a v8 now. it is still quiet at idle and cruise but when i step on it it gets a little throaty. I am very happy with the sound. I wasn't looking for loud as I have a car that is already extremely loud. I wanted it to sound like a v8 since it is one and I ended up with that. For anyone else doing this, the car is only slightly louder at idle and cruise and then comes alive when you step on the gas pedal. Don't expect it to be overly loud. I can still hear the engine over the exhaust until about 2,000 RPMs. I just wanted to update this for anyone searching out the topic and finds this.
post #17 of 40 (permalink) Old 08-01-2011, 02:57 PM
dDUBb's Avatar
Did you use the Cobra Bypass mufflers with the pressure valve ??
dDUBb is offline
post #18 of 40 (permalink) Old 08-01-2011, 08:25 PM Thread Starter
Heck if i know, they were stock 04 cobra mufflers. That would make sense to me if they have pressure relief valves in them why they get louder once I really step on the throttle. I will try to get the part number off of them after dinner and look them up and post back. I really love how quiet they are when cruising and how they are a little louder on heavy throttle.
post #19 of 40 (permalink) Old 08-01-2011, 08:41 PM Thread Starter
Part number is hard to read but appears to be fI7950-a-0274 which brought nothing up in a search. They are what ever muffler was used on a stock 04 Cobra as ford put it ont eh show room floor.
post #20 of 40 (permalink) Old 08-02-2011, 12:48 AM
do you do 55 in the 55 mile per hour zone? speeding is illegal.
1992 sport, m5r2 swap. Next, headers and exhaust
1991 super coupe. Five speed. New motor mounts and a few performance parts coming
1990 super coupe auto. Needs new crank
Plus a few parts cars
schwalbe is offline
post #21 of 40 (permalink) Old 08-02-2011, 01:15 AM
dDUBb's Avatar
Is that a rhetorical question ?
The Speed limit is 65 MPH here in California, and yes I do abide. Thank you.
The problem with removing the 3rd catalytic converter is that when the Smog tech does a visual inspection, you will Fail.
dDUBb is offline
post #22 of 40 (permalink) Old 08-02-2011, 01:21 AM
dDUBb's Avatar
I have the same mufflers for my DOHC Tbird, I just havent welded them on yet. Was wondering how they might sound after installation ...
dDUBb is offline
post #23 of 40 (permalink) Old 08-02-2011, 09:38 AM
SVT2888's Avatar
Send a message via AIM to SVT2888
I own that POS and yet it passes smog and it does sound nice.
Mods: Concrete Median
CNCpics.com-Automotive Event Photography
Facebook
Ebay Store
Official B-team member. Viva La Revolucion!
SVT2888 is offline
post #24 of 40 (permalink) Old 08-02-2011, 09:47 AM
haha yes it was. in California, it's 55 for semi's. which i dont do.
schwalbe is offline
post #25 of 40 (permalink) Old 08-02-2011, 06:27 PM
GRNDPNDR's Avatar
Why should that matter when there are already two cats on the system?
I was under the impression that the third cat was more of a "fail-safe" type feature just in case some gasses got past the first two.
I don't know about California, but I'm just thinking as long as the two existing cats are CARB compliant there shouldn't be an issue as the guy doing the visual inspection will see that there are two cats.
besides that, the third cat is almost far enough away to not make much of a difference. it takes a lot longer to reach operating temps.
Rest In Peace Mom.
GRNDPNDR is offline
post #26 of 40 (permalink) Old 08-02-2011, 11:29 PM
dDUBb's Avatar
Because if your smog guy notices the 3rd cat missing - it can be recorded as a Failure in the DMV system. Its just a hypothetical situation .. chances are, Most smog techs wont notice - but if I were doing a smog, on YOUR car, here in California, with my license .. I would definately look under your car and you better have all 3 cats if you want to pass.
Yes the car passes the emissions test with only two cats - its the Visual test. I got around this on my 94 SC .. they only put 2 cats on the 5 speeds, but the Automatics have 3.
If the car is 96 or newer, the Cats also need to be OBD2 certified in California.
Why are you guys so persistant about removing the 3rd cat ??
The thing about California / Emissions .. is that we have 36+ million people here, and just as many cars - that is a LOT of cars.
dDUBb is offline
post #27 of 40 (permalink) Old 08-03-2011, 09:03 AM
GRNDPNDR's Avatar
I was just curious really. We can pass visual here so long as the guy can see a cat on each pipe. After that if it passes smog, it's good to go.
Cali has some harsh standards and for good reason like you said.
Rest In Peace Mom.
GRNDPNDR is offline
post #28 of 40 (permalink) Old 08-03-2011, 10:10 PM Thread Starter
California won't let us legally modify the exhaust system from the cats forward. I have left the 3rd cat in place and will remain to do so. I ended up finding the sound I was after and I like it.
post #29 of 40 (permalink) Old 08-03-2011, 11:12 PM
thunderclaw's Avatar
i used to live in cali. i removed the resonator and mufflers and straight pipe it sounds nice sound nice without mufflers, if you want a bit louder and u dont get annoyed by the sweet sound of the engine take the resonator out. i never had problems smoging the car.
thunderclaw is offline
post #30 of 40 (permalink) Old 08-03-2011, 11:15 PM
idk why these engines are not as loud as the 4.6 on the mustangs, i guess ours r not as agressively tuned. whatever it is i saved my money instead of buyin mufflers
