easiest way to remove exhaust manifolds? - TCCoA Forums
post #1 of 23 (permalink) Old 05-29-2011, 06:32 PM Thread Starter
Boost!!!
modularbird's Avatar
im doing my exhaust tomorrow.ive got shorty headers and the full mandrel bent exhaust system. i started working on my exhaust today and i couldnt get to the bolts that bolt the manifolds to the downpipe... im just wondering what the easiest way to remove all of the stock exhaust.
Blake
1996 thunderbird lx (the silver slut)
http://forums.tccoa.com/vbpicgallery.php?do=view&g=387
modularbird is offline
post #2 of 23 (permalink) Old 05-29-2011, 06:40 PM
Swivel sockets and wobble extensions will get the pipe to manifold bolts out but the only way you're getting the manifolds off in any easy manner is pulling the motor.
Quick tip, stock manifolds outflow and outlast JBA/SSautochrome shortys
post #3 of 23 (permalink) Old 05-29-2011, 07:11 PM Thread Starter
Boost!!!
is there some way to do the headers without pulling the motor? i have all day tomorrow. surely its doable in under 10 hrs...
Blake
post #4 of 23 (permalink) Old 05-29-2011, 07:21 PM
Tiny hands and tools, patience and 2 packages of band aids might get two thirds of them, there's a few that are completely inaccessible break loose and torque down.
Find someone with an engine hoist you can borrow if you really want to use shortys, it will be much quicker and easier.
post #5 of 23 (permalink) Old 05-29-2011, 07:43 PM
Thermite or C4.
What? He didn't specify he wanted to put it back ON!
RalphP is offline
post #6 of 23 (permalink) Old 05-29-2011, 07:49 PM Thread Starter
Boost!!!
im not trying to be a smart a$$ when i say this. but i dont think everyone who has installed headers or ported manifolds have pulled their motors.surely someone has done it...i just need to know how
Blake
post #7 of 23 (permalink) Old 05-29-2011, 08:25 PM
Loose the garbage shorties, the only thing thats better than stock manifolds is ported stock manifolds or kooks or modded long tubes. Dont waste your time. YOu aren't going to speed up the earths rotation any better with shorties. I just think you should know that.
post #8 of 23 (permalink) Old 05-29-2011, 08:47 PM Thread Starter
Boost!!!
i didnt ask if they are garbage or not... i just want to know how to install them.and was that comment really necessary? if you have information to contribute to this thread that HELPS me with my exhaust then please share it...
Blake
post #9 of 23 (permalink) Old 05-29-2011, 11:02 PM
VicRattlehead's Avatar
Food for thought. The best way to to get better performance out of exhaust without going to the kooks is to leave the stock manifolds on. 15 years I've had my stock manifolds on and so far so good. There is no gain changing them.
CMP Drag Racing
VicRattlehead is offline
post #10 of 23 (permalink) Old 05-29-2011, 11:06 PM
Your not going to get the answer you're looking before because it's impossible. No one in all my years here or prior from reading through old threads has successfully accomplished it with a 4.6. Have a look for yourself, there's NO room to do it.
If you want to do it in under 10 hours without pulling the motor or pulling the heads the only way to do it is to not do it.
post #11 of 23 (permalink) Old 05-30-2011, 09:58 AM
DLF
DLF's Avatar
Drop the K-Member...
My Web Site
DLF is offline
post #12 of 23 (permalink) Old 05-30-2011, 10:11 AM
Baby Huey
warmaster259's Avatar
I put them on mine with the motor still in the car, pain in the azz but it is doable. They ended up cracking a year later though. Long tubes are next on my agenda.
Jim
warmaster259 is offline
post #13 of 23 (permalink) Old 05-30-2011, 06:37 PM
TGJ
Baddest N/A NPI in Canada
TGJ's Avatar
+1
That is how I installed my Kooks...
TGJ is offline
post #14 of 23 (permalink) Old 05-31-2011, 08:49 AM
CableguyJJS3's Avatar
Send a message via AIM to CableguyJJS3 Send a message via Yahoo to CableguyJJS3
I dropped my K-member when I installed my headers and even then is was a major pain in the butt. I can't even imagine how you'd do it with it still in the car. The bolts right near the motor mounts are next to impossible to get at.
Ban low performance driver's, not high performance cars.
"Any idiot can make a Mustang fast, but it takes a special kind of idiot to make a Thunderbird fast."
CableguyJJS3 is offline
post #15 of 23 (permalink) Old 05-31-2011, 11:18 PM
A friend of my attempted an in-car removal. Was not successful, I helped out for an afternoon. There is a lot of good advice here on how to do it properly.
John Fritz is offline
post #16 of 23 (permalink) Old 06-02-2011, 11:52 AM
MAMN12 Posse Member
JeffTBird93's Avatar
I removed my shorties and went to the big version of the Kooks...took...2-2.5 hours...tops. There's plenty of room to work with.
~Jeff
*signed off
JeffTBird93 is offline
post #17 of 23 (permalink) Old 06-02-2011, 04:48 PM
remove the motor mount to cross member bolts and hoist it up, or drop the K.
post #18 of 23 (permalink) Old 06-08-2011, 06:32 PM
I felt that it was called for you obviously didnt search how peoples shorties all crack over time. Just saving you grief and yes they are garbage. Get ported braincoated manifolds. Sell your fshorties for a set of those and you'll actually get a gain. Shorties flow worse than stock so yeah I dont know how else you'd classify them. If you insist on putting on the garbage get a hoist with load leveler and suspend the engine while you lower the K you'll need a particular E18 socket for the K bolts. Goodluck its not personal about your garbage manifolds either Im just stating what many here already know and no one thinks they gained anything from them.
post #19 of 23 (permalink) Old 06-08-2011, 06:35 PM
http://forums.tccoa.com/showthread.php?t=131931
He did ask here, but like this thread he's looking for 1 yes it will work post among 20 no it will not work posts.
post #20 of 23 (permalink) Old 06-08-2011, 06:55 PM
MY mistake but seriously who here has sung the praises of shorties?
post #21 of 23 (permalink) Old 06-09-2011, 06:30 AM Thread Starter
Boost!!!
i didnt fool with them trying to install...i think im just gonna sell them. thanks for the advice guys
Blake
post #22 of 23 (permalink) Old 06-09-2011, 05:24 PM
Smart move. Go ported stock manifolds with the money and maybe youll break even. Or even a set of used stang long tubes modded for that money. I heard cableguy picked up a used set of mac headers for 150 and modded them to work clearing everything.
post #23 of 23 (permalink) Old 06-09-2011, 05:50 PM Thread Starter
Boost!!!
Thumbs up
i mostly just wanted something that was the same size as stock to go in the stock location. now that i have the new exhaust system installed i think gonna be done lying under the car for a little while...until i get my dynotech ds anyway!
Blake
