351 swap headders? - TCCoA Forums
post #1 of 6 (permalink) Old 06-20-2011, 04:04 PM Thread Starter
winkysrides's Avatar
Send a message via AIM to winkysrides
351 swap headders?
I used search and didnt come up with anything
I have a 351w with thats going into a 91 t-bird with a m5r2 and a Canton 15-670 oil pan
I dont think the mac long tubes will fit i was thinking about using shortys any thoughts?
  • "Chuck Norris built my shortblock. It runs on the tears of small children and makes 10,000 hp. He said it's his 'street version' "
wheel hoppin and poppin!
91 Thunderbird sport 357W 5speed
88 stripped out 5.0 C4 and 4:56 gears in a 9in Ford
winkysrides is offline
post #2 of 6 (permalink) Old 06-20-2011, 04:31 PM
tbirdtess's Avatar
Heads?
Hello
What heads do you have?
I run Fox pony manifolds on my Gt40p heads.
You will need to mod front K to fit the oil pan.(minor fix)
Try posting under Exhaust.
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #3 of 6 (permalink) Old 06-20-2011, 05:01 PM
Moved to Exhaust!
post #4 of 6 (permalink) Old 06-21-2011, 08:27 AM Thread Starter
69 windsor heads wich are what the gt40head is based on
and that might be why I couldnt find anything on search I was looking just in the 5.0.5.8 threads
post #5 of 6 (permalink) Old 06-21-2011, 12:50 PM
tbirdtess's Avatar
Heads
Hello
Those are good heads. take standard manifolds.
The valve train isn't the best(heavier than GT40's)
I have had my D0OE heads over 6000rpm.
I have GT40p's now. I do burn a couple plug wires.
(racing engine, high temps)
over the years, there has been several posts about headers on a 351w.
most might hit lower firewall, due to the taller engine.
351W 2bbl.
C-4 Auto
3.90 open rear
post #6 of 6 (permalink) Old 06-22-2011, 09:11 AM Thread Starter
i wonder if there is a block hugger headder that might work
