I broke my kooks - TCCoA Forums
post #1 of 6 (permalink) Old 08-25-2011, 10:23 PM Thread Starter
Silenced's Avatar
I broke my kooks
Anyone have a better way of patching the hole where this used to be than pulling the motor and calling a welder?
Powered by:
Megasquirt EMS, Vortech Superchargers, Renegade Racing, Gator1980Transmission, Innovative Motorsports, Devil's Own, Magnaflow, Eibach, KYB, Kooks
Silenced is offline
post #2 of 6 (permalink) Old 08-25-2011, 10:57 PM
Hmm. I would say maybe cut off that flare add a tube nut, weld the tube nut to the broken piece, tap the header with threads, but even that would require removing the header to access and address the problem, and if you go that far you might as well just weld it right on where it broke off. My only additional tip would be to suspend the engine, and drop the k-member to avoid the hastle of removing the engine from the top.
post #3 of 6 (permalink) Old 08-26-2011, 07:37 AM
So others know to be careful, how did this happen?
post #4 of 6 (permalink) Old 08-26-2011, 08:16 AM
you know the saying, do it right the first time.....it usually saves a lot of time.
post #5 of 6 (permalink) Old 08-26-2011, 08:20 AM Thread Starter
Silenced's Avatar
Nut that would not come off with PB Blaster, and 2ft breaker bar. If your EGR Fails or needs to go away for any reason, get the high-temp jb-weld putty stuff and cap that sucker. It's not strong enough to hold twisting.
Powered by:
Silenced is offline
post #6 of 6 (permalink) Old 08-27-2011, 11:03 AM
seawalkersee's Avatar
If you just want it patched, I will do it for you. Just let me know.
SWS
seawalkersee is offline
