P0161 Walkthrough - TCCoA Forums
post #1 of 26 (permalink) Old 10-26-2011, 04:18 AM Thread Starter
stingu's Avatar
P0161 Walkthrough
Hi guys, I have P0161 error code, read some threads related to this but no simple answer what to do.
Error is for heater for rear sensor on drivers side, shows up after ca. 40 mins of driving, ever on a cold engine/exhaust
I did unplugged sensors when changed my transmission, it is possible i switched left rear with right rear as harness for both are the same lenght and color - does it matter?
I read also about checkin impedance on pins - pls advice which pin should be checked and what are correct readings
Thanks ;-)
stingu is offline
post #2 of 26 (permalink) Old 10-26-2011, 06:31 AM
Did you try replacing the sensor yet? The heater elements go bad in them often. Most 02's I have replaced for codes was for the heater circuit codes.
post #3 of 26 (permalink) Old 10-26-2011, 08:25 AM Thread Starter
stingu's Avatar
Didn't try, hoped to avoid that ;-)
Anyway, what brand/model of sensor does the job?
stingu is offline
post #4 of 26 (permalink) Old 10-26-2011, 08:34 AM
I prefer OEM if buying aftermarket look for NTK. I avoid bosch on these.
post #5 of 26 (permalink) Old 10-26-2011, 11:17 AM
1996Project-bird's Avatar
Advance auto has NTK, buy online, use a coupon code, pick it up in store. You may want to swap them from side to side to make sure it's the sensor and not wiring.
1996Project-bird is offline
post #6 of 26 (permalink) Old 10-26-2011, 12:40 PM Thread Starter
stingu's Avatar
NKT is only pre-cat and i need post cat :-( do you guys have any part number or sth?
stingu is offline
post #7 of 26 (permalink) Old 10-26-2011, 04:01 PM
Rockauto has NTK in both front and rear.
post #8 of 26 (permalink) Old 10-26-2011, 04:15 PM Thread Starter
stingu's Avatar
http://www.rockauto.com/catalog/x,ca...,parttype,5132
I see only right and left pre-cat from NTK, only rear I see is cheapest UltraPower for $20
Actually - are there any differences between front and rear ones?
stingu is offline
post #9 of 26 (permalink) Old 10-26-2011, 04:47 PM
NTK 22500
post #10 of 26 (permalink) Old 10-26-2011, 09:28 PM
sousa632's Avatar
I use Denso O2's in my cars and I have NEVER had an issue with them.
Having ONLY the p0161 I would guess that it's the sensor that's crapped out. If it were all one bank or all 4 o2 heater circuit failure than the problem is bigger than just the o2
John
1996 TBird LX 4.6
2001 Sable Wagon 3.0 Duratec
sousa632 is offline
post #11 of 26 (permalink) Old 10-26-2011, 09:31 PM
+1 on Denso, inexpensive compared to some of the other brands and no issues so far after 2 years.
post #12 of 26 (permalink) Old 10-27-2011, 02:17 AM Thread Starter
stingu's Avatar
thanks guys, any part number for denso? NTK #22500 found on rockauto for $33
stingu is offline
post #13 of 26 (permalink) Old 10-27-2011, 10:19 AM
sousa632's Avatar
Mine's a 96 so it might be different than your number.
John
1996 TBird LX 4.6
sousa632 is offline
post #14 of 26 (permalink) Old 10-27-2011, 11:42 AM
mr24me's Avatar
I just replaced my O2 sensor (drivers side, after cat) and the replacement was a Bosch for $57. Was it a mistake to get the Bosch for this? I just did this about 5 days ago.
Currently Own:
1987 Toyota MR2 (project car)
1997 Ford Thunderbird 4.6L
mr24me is offline
post #15 of 26 (permalink) Old 10-27-2011, 01:58 PM
I wonder how many of these brands are actually made by different manufacturers.
DanB is offline
post #16 of 26 (permalink) Old 10-28-2011, 10:19 AM
sousa632's Avatar
Not a complete mistake........
the bigger mistake is that you only bought one.... and put it after the cat. When I got mine I bought 2 and put them BEFORE the cats because that's where you actually need the o2 sensor to be at it's best readings as it checks and adjusts numerous things, which can net you more power, a smoother running engine, and better gas milage. The post cat o2 sensors only test to make sure the cats are working.
John
1996 TBird LX 4.6
sousa632 is offline
post #17 of 26 (permalink) Old 10-28-2011, 11:08 AM
mr24me's Avatar
I've never been all that knowledgeable when it came to emissions systems. From what I remember when I had my exhaust off the car (when I put my trans in) the ones before the cats were in a PITA spot. Is it a tough job with the exhaust still in the car?
Currently Own:
mr24me is offline
post #18 of 26 (permalink) Old 10-28-2011, 02:05 PM
The driver side isn't bad, it's the passenger side that's a royal pain. Save yourself the trouble and get an O2 sensor socket beforehand.
post #19 of 26 (permalink) Old 10-28-2011, 03:36 PM
mr24me's Avatar
That's what I used for the O2 sensor that I replaced after the cat. Autzone rents them for approx. $27 deposit. I don't change O2 sensors that often (knock on wood) so I figured I would rent the tool as opposed to buying it. Now if I'm not throwing a CEL, should I just leave the pre cat sensors alone? Or does the factory ECU leave enough variance in the readings to the point that a sensor could be failing, but not trigger a light?
Currently Own:
mr24me is offline
post #20 of 26 (permalink) Old 10-28-2011, 04:05 PM
Huh. Bought mine for $8 at Harbor Freight.
WELL worth it, with the Cougar, the Malibu, the stepson having an Escort and a Taurus (and a Dakota, but don't think it's got an O2 sensor), and any other vehicles. That and until I started swapping, they were ORIGINAL O2s in all of them.
Escort and Taurus are still original, front are in the Malibu, but the rear and the two in the Cougar are new (Bosch for the Malibu, Motorcraft for the Cougar - don't scream, Bosch made the OEs for Chevy and are great in them, whereas they suck planetary masses through stir sticks on Fords.)
RalphP is offline
post #21 of 26 (permalink) Old 10-28-2011, 04:17 PM
mr24me's Avatar
There's a Harbor Freight in Burbank Illinois, maybe an hour or so away from my house. I've been meaning to go there and pick up some stuff, and now I just might have to.
Currently Own:
mr24me is offline
post #22 of 26 (permalink) Old 01-18-2012, 02:30 PM Thread Starter
stingu's Avatar
one question - you say ntk or denso, but i checked and have stock sensors made by bosch - still sure its good change for non-stock brand?
stingu is offline
post #23 of 26 (permalink) Old 01-18-2012, 02:32 PM
There are 2 distinctly different sensors. NTK type and Bosch type. Bosch were not factory on these. Someone had to change them.
post #24 of 26 (permalink) Old 01-18-2012, 03:43 PM Thread Starter
stingu's Avatar
sure? it even has a fancy ford logo on it...
stingu is offline
post #25 of 26 (permalink) Old 01-18-2012, 04:37 PM
Maybe canada or california emissions but I have never seen it. They could have run out for a month and got bosch for a backup...who knows.
post #26 of 26 (permalink) Old 01-18-2012, 05:14 PM Thread Starter
stingu's Avatar
Thanks Alan, I can always count on your advice :-) Its Canadian version, Gonna contact bosch cause i cant find this part number nowhere on the internet :-/ Is it still interchangeable with ntk/denso?
stingu is offline
