pipe through stock cats - TCCoA Forums
post #1 of 13 (permalink) Old 05-26-2012, 07:39 AM Thread Starter
conquistador's Avatar
I've searched and searched, but still have a question. I have a 97 4.6 & I wanna drop the exhaust this weekend in order to put pipes though the two front cats. Not looking for anything fancy & the goal is to look completely stock. (In a dream world, I would just run true duals, but I am about as broke as you can be). Anyway, the cats look like there is a bend in them, but I honestly can't tell with everything hooked up. Is it possible, after gutting the cats, to just put a pipe right through them?
Of course, MIL eliminators will be next. I don't want to drop the whole exhaust system just to find out that I will have to hook it up without actually accomplishing anything lol.
Cats are clogged, this is my motive.
conquistador is offline
post #2 of 13 (permalink) Old 05-26-2012, 07:41 AM Thread Starter
Mods, I wasn't thinking. Prolly should have posted in "exhaust"
post #3 of 13 (permalink) Old 05-26-2012, 09:07 AM
Moderator & Teksid Whore
guitar maestro's Avatar
guitar maestro is offline
post #4 of 13 (permalink) Old 05-26-2012, 03:31 PM
You may as well just gut them and be done with it if this is your best option. There's big disadvantages due to turbulance but I can't imagine jamming a pipe that will fit the ID of the stock pipes will be any better, especially for the work involved
post #5 of 13 (permalink) Old 05-26-2012, 03:51 PM
And for the money to actually do the work of piping them, not much more and you've got new cats and a front pipe set.
Checking RockAuto for a 1997 4.6, I find this listing: http://www.rockauto.com/catalog/rafr...&parttype=5808
That's what I'd be saving up for if I were you, anyway. Unless you have a welder and know how to use it (neither of which are true for me!), in which case I'd suggest buying some straight pipe for now to cut and replace the cats, and then replacing THAT when you can afford to as soon as possible.
RalphP is offline
post #6 of 13 (permalink) Old 05-27-2012, 08:24 AM
Rob
Rob's Avatar
Send a message via AIM to Rob
Yee haw! Look at all these universal non-catalytic converters. I remember someone posting this on here before, so I had to do it again!
http://www.siliconeintakes.com/index...0008322d899d9f
This will take care of the turbulence problem since it already has a pipe going through it, but now you will be letting the heavier, unburnt parts of the gasoline just go into the air. You will pass visual inspection, but a sniffer test will probably catch you! You also will still have to have custom down pipes made to get these to fit an mn12. I used to have a universal cat on one side of my 92 LS.
-Rob
Rob is offline
post #7 of 13 (permalink) Old 05-27-2012, 09:59 AM
LOL. Why would you even bother? You can pass a visual, but there is absolutely NO sniffer test you could pass with that thing. Are there states and/or counties out there that do ONLY visual for emissions? I guess to pass an inspection station you MIGHT need these like in Maine where there is no emissions testing.
~Rick
TCCoA Sig
post #8 of 13 (permalink) Old 05-27-2012, 02:12 PM
Technically, in Louisiana, they're supposed to do a visual.
I think there's a shop in Gonzales, LA that actually does ...
RalphP is offline
post #9 of 13 (permalink) Old 05-27-2012, 02:56 PM
Audio Alchemist's Avatar
I'm so glad we don't have to deal with vehicle inspections for emissions in Arkansas. It blew hardcore when I lived in Cali.
If you can't hear it before you see it...what's the point?
Audio Alchemist is offline
post #10 of 13 (permalink) Old 05-27-2012, 03:37 PM
Seems like they would only be feasible if they were installed downstream of the front cats like Mustangs or our 3rd. That would be the only way I could see passing the visual and sniffer tests with those.
post #11 of 13 (permalink) Old 05-27-2012, 10:03 PM
Rob
Rob's Avatar
It would pass visual in my area with these placed in front of the downstream sensors. In dallas/houston/other areas they do a sniffer test, where you would probably fail.
-Rob
Rob is offline
post #12 of 13 (permalink) Old 05-29-2012, 07:46 PM
Send a message via Yahoo to hrdfrntr95
hmmmmm........might have to look into these "NON CATS"......mine r junk and i really dont wana replace with stock cats.......so either these or high flo cats are in order
hrdfrntr95 is offline
post #13 of 13 (permalink) Old 06-11-2012, 08:54 AM Thread Starter
I guess I'll just do high-flows, gotta get the $ in order first
