Walker cat back - TCCoA Forums
post #1 of 3 (permalink) Old 06-22-2012, 04:49 PM Thread Starter
97 30th's Avatar
Walker cat back
For those interested Summit has the Walker Dynomax cat back for $288 plus a $75 rebate in the form of a debit card until the end of the month. I got mine this week and installed last night. Mike
You can't fix stupid
97 30th is offline
post #2 of 3 (permalink) Old 06-23-2012, 05:31 AM
I've had mine for years, I like it!
post #3 of 3 (permalink) Old 06-23-2012, 07:40 AM Thread Starter
97 30th's Avatar
My son had it on his Thunderbird which I was going to swap over to my car(His is wrecked) But when I pulled it off I found out one of the mufflers is rusted and the other is not far behind and whoever put it on did not fit it up well. it was hitting the cross brace under the pipe in the front and they wire tied a piece of rubber to the pipe because it was rubbing on the diff mount and had it so close to the sway bar that they couldn't use a clamp and had it welded all up. I priced out the mufflers and it was almost $200 so I got all new for not much more and it fits very well when you spend a few minutes adjusting everything before you tighten it up.
97 30th is offline
