Making my Cobra Exhaust Manifolds Work - TCCoA Forums
post #1 of 13 (permalink) Old 06-27-2012, 07:57 PM Thread Starter
stay_unique_91's Avatar
I was determined to not do the steering shaft mod to fit these manifolds so I decided to cut and weld the driver side to clear the steering shaft. These are from a 99/01 Cobra. My welds aren't great its been some 6 or 7 years since I welded but I think it will work. I still have a little bit more fabricating to do because the flange does make contact with the block but I am determined to make it work
Photobucket
Photobucket
Photobucket
Photobucket
Daily Driver - 2014 Ford Mustang GT 5.0 manual black on black. Stock for now.
Current Project - 1996 T-bird LX 4.6L: PI head swap, factory 3.27 TL, tuned by Don LaSota.
Retired Car - 1995 T-bird LX 4.6L: 4v swap plus Cobra goodies
stay_unique_91 is offline
post #2 of 13 (permalink) Old 06-27-2012, 09:10 PM
Moderator & Teksid Whore
guitar maestro's Avatar
Good job on getting things done. I for one try to make welds look good, but it's more important for the weld to be sound than pretty. Imma move this to the exhaust forum if it's ok with you.
guitar maestro is offline
post #3 of 13 (permalink) Old 06-27-2012, 09:43 PM
I hope the weld holds up. I know cast iron is a pain to weld.
post #4 of 13 (permalink) Old 06-27-2012, 10:28 PM
driller's Avatar
I think the manifolds are cast steel?
driller is offline
post #5 of 13 (permalink) Old 06-27-2012, 10:36 PM Thread Starter
It was hard to weld but it wasn't too bad. Luckily the manifolds were low mileage and there wasn't much contamination (carbon build up). I too hope the weld holds. I still need to figure out how to make it clear the block. I'd prefer not having to weld it again maybe I can shave down that piece of the block?
post #6 of 13 (permalink) Old 06-27-2012, 11:30 PM
dDUBb's Avatar
Yeah you could always cut that pad off the block .. it seems to be more for manufacturing processes than anything else.
dDUBb is offline
post #7 of 13 (permalink) Old 06-27-2012, 11:56 PM Thread Starter
That's what I am thinking. The transmission seems to have little to no contact with that pad. I'll probably will up doing that
post #8 of 13 (permalink) Old 07-16-2012, 03:57 PM
ROLLINTHUNDER's Avatar
Youre making these work in a 4V bird correct? Do you think cobra manifolds would work easier on a 2V? If not then what would be the best choice in manifolds when it comes to the 2V's? Not trying to do the steering shaft mod either.
ROLLINTHUNDER is offline
post #9 of 13 (permalink) Old 07-16-2012, 04:14 PM
gotta keep the heat up when welding cast.
I like to add a little nickel when doing so.
post #10 of 13 (permalink) Old 07-16-2012, 04:26 PM
dDUBb's Avatar
They wont match up with the exhaust ports .. 2v and 4v are different.
dDUBb is offline
post #11 of 13 (permalink) Old 07-16-2012, 06:44 PM
I heard others have tried this mod on mark8s and the welds dont hold up or crack. However thinking about it going cast iron in a super hot environment is the best choice Id think. If you had them braincoated the heat retention would yield lower bay temps. I hope you get it to work out though I dont know all the technical reasons why others failed.
post #12 of 13 (permalink) Old 07-16-2012, 07:28 PM
dDUBb's Avatar
Contamination or not enough penetration is the primary cause for welding failures.
dDUBb is offline
post #13 of 13 (permalink) Old 07-16-2012, 09:28 PM
You should send those to Preston to have them ported and coated to protect the weld.
