angle of cats? - TCCoA Forums
post #1 of 12 (permalink) Old 08-02-2012, 09:30 AM Thread Starter
96Darkstar4.6's Avatar
angle of cats?
i am trying to avoid welding more than once and cutting more than once.. im asking you guys whats the degree of angle the cats are.. i always assumed 45 degrees
Taking time to build it right...
96Darkstar4.6 is offline
post #2 of 12 (permalink) Old 08-02-2012, 09:44 AM
hugh?
you just weld them in where they need to go.....I would run them whatever angle my pipes are(they look straight to me).
post #3 of 12 (permalink) Old 08-02-2012, 10:12 AM Thread Starter
hugh? they aren't straight.. and i don't have butt-loads of money to take to a shop... im having a buddy do it to save money..
post #4 of 12 (permalink) Old 08-02-2012, 10:22 AM
in what degree of angle are you reffering to?
side to side?
or top to bottom?
post #5 of 12 (permalink) Old 08-02-2012, 10:25 AM Thread Starter
top to bottom.. sorry i should have put that lol
post #6 of 12 (permalink) Old 08-02-2012, 07:27 PM
Are you trying to weld up an exhaust system on the floor (off the car)?
post #7 of 12 (permalink) Old 08-03-2012, 07:29 AM
Rayo's Avatar
Originally Posted by 96Darkstar4.6
I'm asking you guys whats the degree of angle the cats are.. i always assumed 45 degrees
Looks more like 120 Degrees??..
Here's a pic of a 4.6 Thunderbird Catalytic Converter set-up..
Good luck making it fit perfect the first try..
1991 Ford Thunderbird Sport
Rayo is offline
post #8 of 12 (permalink) Old 08-03-2012, 07:51 AM
Single or dual exhaust?
If single - you ever consider ordering the OEM fit Magnaflow or Walker pipe?
1996 4.6L at RockAuto - http://www.rockauto.com/catalog/rafr...&parttype=5808 . $322 for the Magnaflow, bolts right in.
Then there's the Mandrel Exhaust System dualie front part - http://www.mandrelexhaustsystems.com...EXHAUST/Detail and it's only $295 to $445 (2.25/2.5, aluminized/stainless, X/resonator).
RalphP is offline
post #9 of 12 (permalink) Old 08-03-2012, 06:01 PM
Rob
Rob's Avatar
Send a message via AIM to Rob
You should tack it in place in the car, then drop the whole y pipe back down and weld it up. You will need to make some intermediary pipes to make the aftermarket cats fit, even then it will be hella tight. I actually did put one on my 92 Cougar v6 on the RH side, but it ended up further away from the engine. Those small diameter spun converters would fit much better.
-Rob
Rob is offline
post #10 of 12 (permalink) Old 08-03-2012, 07:18 PM Thread Starter
im doing it off car.. and im straight piping it.. i need it to work cause my passenger cat is shot..
post #11 of 12 (permalink) Old 08-03-2012, 07:39 PM
You need to at least tack everything together on the car. You can remove it to do your finish welds, but if you're just eyeballing it on the floor, you're going to run into trouble when you go to fit it to the car.
post #12 of 12 (permalink) Old 08-03-2012, 09:20 PM
These cars are unforgiving with tolerances and fitments.
