4v Swap done, modified Cobra header won't work. - TCCoA Forums
post #1 of 7 (permalink) Old 08-13-2012, 06:19 PM Thread Starter
stay_unique_91's Avatar
I was well aware of the fact that the Cobra exhaust manifolds would not work due to the steering shaft angulation issue. I tried to modify the manifold to work on the driver side but resistance was futile. So now I have a predicament, I can either go with a Mark VIII manifold/cat assembly (which I would like to avoid because I'd prefer not to run catalytic converters because I am cheap) or do a true header set up (which I am leaning towards). That being said if I am doing a header set up I am going long tube, I am aware of the fact that no long tube is made to fit the car in a bolt on fashion and that is fine. I know a Mustang header can be modified to fit, and that is the plan.
My question to you gentlemen, is there a particular header that would be better to use? By better I mean less modifications required? I was thinking of doing MAC or a brand called Pacesetter (I haven't heard of them before) because they seem to be the cheapest.
As far as the steering shaft mod, I'd prefer not to do it because I am cheap and lazy . I have a friend with exhaust knowledge and said that if I could get the headers he would do any modifications needed to make them fit for just the cost of material.
Any advice is appreciated,
Daily Driver - 2014 Ford Mustang GT 5.0 manual black on black. Stock for now.
Current Project - 1996 T-bird LX 4.6L: PI head swap, factory 3.27 TL, tuned by Don LaSota.
Retired Car - 1995 T-bird LX 4.6L: 4v swap plus Cobra goodies
stay_unique_91 is offline
post #2 of 7 (permalink) Old 08-13-2012, 06:40 PM
Moderator & Teksid Whore
guitar maestro's Avatar
AFAIK, no one has tried anything but MAC on a 4.6 mn12. The Pypes brand longtubes look workable though.
guitar maestro is offline
post #3 of 7 (permalink) Old 08-13-2012, 06:49 PM
Pypes only makes the LTs for the 2Vs last I checked
post #4 of 7 (permalink) Old 08-13-2012, 06:56 PM Thread Starter
Will the 4v ones work though? I have read a few articles on here but all I have seen are the 2v with long tubes.
post #5 of 7 (permalink) Old 08-13-2012, 10:08 PM
dDUBb's Avatar
Well, if all else fails, I still have those stock Mark manifolds ..
dDUBb is offline
post #6 of 7 (permalink) Old 08-14-2012, 07:42 AM
how much are the headers you are looking at?
cause right at $200 bucks you can get all the steering shaft stuff.
I know you said lazy, but fabbing headers takes a good bit of work.
From doing both, I would rather do the steering shaft any day than modify headers.
post #7 of 7 (permalink) Old 08-14-2012, 12:53 PM
Be the first to let us know. Fabbing up just two primaries has taken me weeks working alone to get it done right and not have it looking half-azzed. The problem your friend doesn't realize is that you can't just route a couple tubes in however and expect it to work just from sheer memory recollection. You have to keep putting the header in place (either by itself or already attached to a loose cylinder head) over and over again, to see how it will really pan out with clearances around the steering shaft and the K-member. I have lifted that damn head in and out of the mock engine in my car literally over a hundred times. Sure you get a good workout, but it is a real PITA. Probably more than anything I've ever done on my car.
