deleting cats... - TCCoA Forums
post #1 of 4 (permalink) Old 09-13-2012, 05:16 PM Thread Starter
deleting cats...
my question is are the cats on each of the headers feeding back into the muffler?
have a buddy that tells me im crazy in thinking there is 2 cats and not just 1 and that they must be further on.
a better question might be do you guys know of a good right up on removing them yourself and think you could use a pipe cutter of sorts?
Thunderingbird is offline
post #2 of 4 (permalink) Old 09-13-2012, 06:25 PM
1992 V8? There's THREE cats.
One right, one left, and one rear (where the two pipes run into a "Y" fitting).
Behind that is the resonator.
Unless you don't have but one unit there, then there's a right and a left.
RalphP is offline
post #3 of 4 (permalink) Old 09-13-2012, 09:34 PM
Rayo's Avatar
Thunderbird 5.0 Exhaust
Here's the Exhaust set-up on your 92 Thunderbird 5.0..
As far as removing your Catalytic Converters..
The Passenger Side Catalytic Converter you could cut out and straight pipe...
The Driver Side Catalytic Converter is at a 90 Degree angle..So there's no straight piping that..
You're going to have trouble deleting the Front Catalytic Converters..
Unless you get some 120 Degree Down Pipes, and you are a competent welder..
1991 Ford Thunderbird Sport
Rayo is offline
post #4 of 4 (permalink) Old 09-13-2012, 09:36 PM
As to replacing them - with OEM design, or with X pipe/DIDO muffler and true duals out the back?
RalphP is offline
