To dual or not to dual - TCCoA Forums
post #1 of 19 (permalink) Old 10-20-2012, 08:10 AM Thread Starter
kids93bird's Avatar
after much debating and no conclusion i am still undecided on which route to go.
My 93 5.0 H.O will be getting the exhust done soon and these are my options. your opinions are appreciated.
(KEEP IN MIND THAT I HAVE ALREADY REMOVED THE CATS AND RESONATOR AND HAVE TWO CLEAN 2.25" PIPES COMMING FROM THE EXHAUST MANIFOLDS TO A Y-PIPE WERE THE RESONATOR USE TO BE)
#1 buy the mandrel exhaust true dual setup 2.25" or 2.50" for $150.00 and two flows supper 44.
#2 run a 3" pipe from the first y-pipe (old resonator spot) weld a muffler there then continue rearward to a second Y and split that into two 2.50" tail pipes.
#3 run a 3" pipe from the first y-pipe (old resonator spot) continue rearward with the 3" pipe to one flowmaster muffler at rear.
1993 thunderbird 5.0 H.O A4
2003 Crown Victoria LX
1995 Camaro Z28 M6
1992 mustang LX 5.0 H.O A4
kids93bird is offline
post #2 of 19 (permalink) Old 10-20-2012, 08:20 AM
coggonobrien's Avatar
my vote is for mandrel
David
coggonobrien is offline
post #3 of 19 (permalink) Old 10-20-2012, 08:20 AM
Dual exhaust will give you the enhancement of having either an x or h pipe for additional scavenging. Keeping the pipe size down will keep velocity high and prevent you from losing low end torque, but a second pipe will give you additional headroom for additional power if it's added down the road.
post #4 of 19 (permalink) Old 10-20-2012, 08:21 AM
True duals FTW. X cross-over for upper rpm power and a higher tone, H cross-over if you want slightly more low rpm torque and a throatier, muscle-car rumble.
~Rick
TCCoA Sig
post #5 of 19 (permalink) Old 10-20-2012, 12:15 PM
I'd go for stainless Mandrel Exhaust Systems if I were you.
2.25" for better low end torque, 2.5" if you're planning to go higher power later.
RalphP is offline
post #6 of 19 (permalink) Old 10-20-2012, 12:28 PM
Tbird1997's Avatar
True duals. Forget 2.25 and just get the 2.5 or you will regret it later.
And I have super 44 flows for sale if your interested... http://forums.tccoa.com/showthread.php?t=139975
-Patrick
Tbird1997 is offline
post #7 of 19 (permalink) Old 10-21-2012, 09:51 PM
tbirdtess's Avatar
defend
Defend your ladies honor! DUAL!
#1
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #8 of 19 (permalink) Old 10-22-2012, 08:51 PM
96Darkstar4.6's Avatar
mandrel bent.. mine sounds great! got slps on..
Taking time to build it right...
96Darkstar4.6 is offline
post #9 of 19 (permalink) Old 10-22-2012, 09:12 PM
~Rick
TCCoA Sig
post #10 of 19 (permalink) Old 10-22-2012, 09:46 PM
Roadrunnner's Avatar
Im now on my 4th exhaust setup and think its finally done except headers. First I ran no cats or res with dynomax mufflers. Then bigger pipe stock routing with super 44s. And coming in 3rd place is was true dual 2.25 header in to 2.5 mid with an h. Im now running 2.5 and an x. I vote 2.5" with an x pipe and some super 44s. Loud and proud sounds sexy too.
I have afew clips at the top of the exhaust section. I should put up another
Will
Roadrunnner is offline
post #11 of 19 (permalink) Old 10-31-2012, 08:24 PM Thread Starter
kids93bird's Avatar
well folks i will be doing true duals and super 44s with some snazzy borla tips. thanks for all your suggestions.
Yup it took one day shipping since i live in the same city.
1995 Camaro Z28 M6
post #12 of 19 (permalink) Old 10-31-2012, 08:52 PM
Tbird1997's Avatar
Wow nice! Be sure to post pics when you throw it on!
-Patrick
post #13 of 19 (permalink) Old 11-03-2012, 09:08 AM Thread Starter
kids93bird's Avatar
OK then
ok update got the exhaust up, welder had to add two lengths of slip on piping to the sections that face the engine to mate up to the ones previously done from the exhaust manifolds. and heres the exhaust system from the exhaust manifolds back with no cats or resontors, i have to admit though that the super 44s are a tad louder than i thought and tone is different from what a fox may sound like with same mufflers. mayabe due to the fact motor is bone stock @ 200hp and the location of mufflers being that on fox bodies hve their mufflers mid body mounted and tone may change when exhaust runs through a tail pipe out of muffler.
1995 Camaro Z28 M6
post #14 of 19 (permalink) Old 11-03-2012, 09:12 AM Thread Starter
kids93bird's Avatar
next series of mods will be finding a posi carrier and gears i have a line on real cheap but not sure if i wanna go 4.10s
i was leaning more towards 3.73s
1995 Camaro Z28 M6
post #15 of 19 (permalink) Old 11-03-2012, 10:45 AM
Tbird1997's Avatar
Nice!
Video clip?
I would stick to 3.73s since its the 5.0. Doesn't need to rev way up high like the modular motors do.
-Patrick
post #16 of 19 (permalink) Old 11-04-2012, 07:16 AM
Rayo's Avatar
You're AOD is going to shift really early if you go (numerically) any higher than 3.55's..
One way around that is using a Full Manual Valve Body that allows you to control the shifts..
Do you think you could post some pics of your Down Tubes & The middle section of exhaust on your Thunderbird?..Thanks
1991 Ford Thunderbird Sport
Rayo is offline
post #17 of 19 (permalink) Old 11-08-2012, 05:25 PM Thread Starter
kids93bird's Avatar
Rayo i didnt manage to get pics of the bend tubing made after the exhaust manifolds to the mandrel exhaust system but as soon as i start messing around down there again i will take detailed pics front to back. what i can tell you is that when i did remove the stock 2 cat pipe my muffler giuy exacted the same 2.25" pipe with as little crimping as possible. real clean exhaust piping from both manifolds back.
1995 Camaro Z28 M6
post #18 of 19 (permalink) Old 12-01-2012, 10:03 PM
Send a message via Yahoo to barry96cat Send a message via Skype™ to barry96cat
That is a nice Install. I would like to know where would I put my o2 sensors if I wanted to keep them?
barry96cat is offline
post #19 of 19 (permalink) Old 12-06-2012, 07:06 PM
looks awesome
1995 black thunderbird 4.6, sohc, auto, 15 inch turbine wheels, 215\70\15, niteshaded tails, mufflers deleted, pioneer deh-p9800bt HU, 8000k HIDs, pilot slim fogs.
1993 ranger splash blue and black, 2.3 5 speed, 3.73 gears, niteshaded tails, black projector headlights, hurst shifter, roll pan, flowmaster 40, chrome 18x9 inch bullitts, nexen 245\45\18 tires, waaaaay more mods to list.
rangersplash2.3 is offline
