Interchangeability - TCCoA Forums
post #1 of 7 (permalink) Old 03-16-2013, 10:48 PM Thread Starter
Interchangeability
Howdy!
I have what's probably a stupid question.
Bill at SCP claims the 3.8SC and 5.0HO downpipes for 1991-1993 TBirds/Cougars are the same.
Does anyone else know if they are? And are the 3.8NA downpipes also interchangeable?
Thanks in advance!
RalphP is offline
post #2 of 7 (permalink) Old 03-17-2013, 05:03 AM
Ralph,
Can't help you with the SC or 5.0 but the 96-97 3.8NA downpipes were different, drivers side I believe.
post #3 of 7 (permalink) Old 03-17-2013, 12:36 PM Thread Starter
Originally Posted by Rodeo Joe View Post
Ralph,
Yah, the 94-95 SC are different than the 89-93 downpipes, so Mandrel Exhaust Systems needs to know which one.
I wasn't specific enough, I meant 89-93 due to the variance in 94.
'Course, it'd be nice to know if the 94-97 V6 were all the same - be helpful in case someone's dumping their old SC exhaust and someone like S4Gunn could buy it cheap!
RalphP is offline
post #4 of 7 (permalink) Old 03-17-2013, 08:05 PM
S4gunn's Avatar
'Course, it'd be nice to know if the 94-97 V6 were all the same - be helpful in case someone's dumping their old SC exhaust and someone like S6Gunn could buy it cheap!
I actually already have an SC "true dual" exhaust thanks to Dan.. on the cheap. He needed a stock exhaust with cats to pass smog and I wanted my craptastic lemons car to sound like a proper racecar. Considering the leaks in the piping that drove me nuts trying to track down and patch, I think it was a wash as to who got the better deal here
It was a single piece setup with cherry bombs for downpipes and flowmasters at the end. I believe it came from an early model SC. My car is a 95 3.8L N/A tbird.
BTW, this post says that 3.8L and 5.0L downpipes are in the same position. This bodes well if (when?) we finally bite the bullet and go to a v8
http://forums.tccoa.com/showthread.php?t=107943
-g
http://goo.gl/csaet4
S4gunn is offline
post #5 of 7 (permalink) Old 03-19-2013, 05:12 PM
dDUBb's Avatar
-g
The exhaust I got had only 1 good cat - the other one was hollow.
The Dual exhaust you got was from a 95 SC.
The 94/95 3.8 NA and SC use the same exhaust manifolds so they interchange - although the stock SC exhaust has a slightly larger diameter pipe.
dDUBb is offline
post #6 of 7 (permalink) Old 03-19-2013, 05:28 PM
Now, I thought the SC manifolds were different than the NA because I've heard how they are the best flowing available.
post #7 of 7 (permalink) Old 03-20-2013, 01:11 AM
Rayo's Avatar
5.0 DownTubes
Ralph..
I think Bill is making that claim because the downpipes he sells are 2 seperate pieces..
So you could basically twist one side or the other to get it to fit right..
The driver side downtube on the 89-93 SC, and the 91-93 5.0L MN12 both have a 90 degree bend where they mount to the collector flange..
The passenger side downtube looks pretty close as well..
I've heard a few guys say the factory SC exhaust system will bolt up to the 91-93 5.0L MN12s..
Originally Posted by XR7 Dave
The 5.0 will bolt up to stock SC exhaust.
Originally Posted by MadMikeyL
Yes, SC exhaust will be a direct bolt-on.
Originally Posted by ClintD
Yup, even the cat's are the same. usually the V6 only has 2 cat's. But you will have to weld in a bung for the O2 unless you remove the EGR tube on the exhaust manifold and put the O2 in there.
I'll just clarify what ClintD said..
The stock 89-93 SC exhaust does not have a bung on the passenger side downtube for the O2 sensor, but will otherwise bolt up fine..
IIRC Joker77_2005 was using the SCP Catless Downtubes on his 5.0, and said they fit perfect..
I hope that helps..
1991 Ford Thunderbird Sport
Rayo is offline
