Exhaust leak (behind resonator) - TCCoA Forums
post #1 of 4 (permalink) Old 10-28-2013, 07:33 PM Thread Starter
Talking Exhaust leak (behind resonator)
As stated, I have a nasty exhaust leak directly behind the resonator on my 95 Cougar; it rattles and stinks something awful. From an illustration I saw on the web, it appears that the resonator may be a separate bolt on item? If so, it seems that I need only replace the resonator (clamps at rear are solid rust), add a new clamp, and I'm finished?
MntnLion is offline
post #2 of 4 (permalink) Old 10-31-2013, 06:25 PM
Seems it should. But.....funny thing about exhaust systems.
What starts out as "I just need to replace this _____ and it'll be done" usually turns into "I had to do the whole @#$% exhaust system just to replace one part! ARGGH!!"
You might get lucky, but be prepared for more than you initially anticipated.
Delete my account.
94 Thunderbird XX is offline
post #3 of 4 (permalink) Old 10-31-2013, 06:38 PM
You might just want to eliminate that stupid resonator and put a piece of pipe in.
If you know someone that can weld the piece in, it's the best way, otherwise just clamp it on!
That's what I would do, anyways.....
~Rick
TCCoA Sig
post #4 of 4 (permalink) Old 11-04-2013, 09:22 PM Thread Starter
Thanks fellas. When time (and cash), allow, I'll try to get it done properly.
MntnLion is offline
