Installing exhaust - TCCoA Forums
post #1 of 8 (permalink) Old 09-09-2014, 08:57 PM Thread Starter
Woodman's Avatar
Installing exhaust
So what's it take to actually install a cat back exhaust?
My plan is to remove the Y pipe/center cat, and install a true dual with a crossover or a center dual in/out resonator.
I've never installed an exhaust, and I have no welding experience. Is it as simple as using heat/penetrating oil to remove the old exhaust, then bolting up the new one? Anything I need to have on hand to install it? Extra clamps, a few extra connectors, etc?
It looks "easy" assuming I can get the old one off, is it a big deal?
Woodman is offline
post #2 of 8 (permalink) Old 09-09-2014, 09:33 PM
If you're talking about a ready-made kit, it should be pretty easy. I've not purchased a kit before, but cutting/splicing new exhaust tubing isn't too difficult if the system is in decent shape.
If you're talking about a homemade setup, that would be bit more challenging, especially without a lift.
DrFishbone is offline
post #3 of 8 (permalink) Old 09-09-2014, 09:35 PM
If you have a pre-bent setup, you should be able to cut/splice the tubing with simple hand tools and you can use exhaust clamps to secure the parts together. Otherwise, I don't think bending straight tubes or welding mandrel pieces together would be quite a job!
post #4 of 8 (permalink) Old 09-09-2014, 09:44 PM Thread Starter
Woodman's Avatar
Yes, I'm looking at ready made kits. Thanks, for some reason I thought it was a much bigger job than that.
Woodman is offline
post #5 of 8 (permalink) Old 10-01-2014, 11:01 AM
CEDARS.SLEDS's Avatar
There some nice stuff on eBay wallet friendly priced
CEDARS.SLEDS is offline
post #6 of 8 (permalink) Old 10-01-2014, 10:22 PM Thread Starter
Woodman's Avatar
I did see that. Luckily, when I bought the GT Bird, it already had a true dual exhaust installed with a center mount dual in/out magnaflow and glasspacks on the end of each pipe to give it a mellow yet aggressive tone.
Woodman is offline
post #7 of 8 (permalink) Old 10-02-2014, 02:28 AM
rushtonracing's Avatar
Here is one possible course of action.
http://www.mandrelexhaustsystems.com...ird/Categories
https://www.supercoupeperformance.co...less-steel-159
https://www.supercoupeperformance.co...ensor-bung-807
https://www.supercoupeperformance.com/stainless-steel-exhaust-x-pipe-
451
https://www.supercoupeperformance.co...s-material-155
http://www.dynomax.com/mufflers?muff...figuration=140
Take parts to an independent garage that specializes in exhaust, and muffler installs. Pick a shop that has an actual tube bender, like a cnc machine, to make fine alignment bends in the mandrel exhaust pipes for proper fitment of various parts listed if needed. And, a quality install means all parts are welded together. No clamps.
1995 Thunderbird LX 4.6l 97 Headlamps/Hood All Red Tails Muffler/Resonator Delete
2004 Tahoe 5.3 4x4
2008 Acadia Limited AWD
...still looking for a clean, low mileage, rust free 96/97 Thunderbird 4.6
rushtonracing is offline
post #8 of 8 (permalink) Old 10-03-2014, 05:31 AM
Moderator & Teksid Whore
guitar maestro's Avatar
451
I like how the O2 bung is a hard to find item lol.
guitar maestro is offline
