stainless or steel? - TCCoA Forums
post #1 of 20 (permalink) Old 10-22-2014, 10:46 PM Thread Starter
1996Project-bird's Avatar
stainless or steel?
Are factory exhausts for 97 4.6 stainless of aluminized steel? I have to weld in new cats, just wondering what material I'm dealing with.
1996Project-bird is offline
post #2 of 20 (permalink) Old 10-22-2014, 11:16 PM
Stainless
post #3 of 20 (permalink) Old 10-25-2014, 01:48 PM
Moderator & Teksid Whore
guitar maestro's Avatar
guitar maestro is offline
post #4 of 20 (permalink) Old 10-25-2014, 01:53 PM
If it were aluminized they'd all have rotted off the midwestern cars by 2000.
post #5 of 20 (permalink) Old 10-25-2014, 02:11 PM
Mine were definitely aluminized...
post #6 of 20 (permalink) Old 10-25-2014, 03:01 PM
96PRLBRD's Avatar
My 96 is definitely stainless, it would have rotted off by now if it was not.
--> My most recent pics <--
96PRLBRD is offline
post #7 of 20 (permalink) Old 10-25-2014, 03:12 PM
Stainless (generally) will be nonmagnetic.
Try sticking a magnet to it. If the magnet barely sticks it's stainless. If the magnet adheres strongly it's aluminized steel.
post #8 of 20 (permalink) Old 10-25-2014, 04:43 PM
Well mine was certainly quite rusty when I took it off, so...
post #9 of 20 (permalink) Old 10-25-2014, 04:54 PM
Quick someone grab a PMI gun.
And a copy of Mechanical Engineer's Reference Book.
bulldog is offline
post #10 of 20 (permalink) Old 10-25-2014, 05:00 PM
LOL
I consulted one of then engineers and one of the welders that I'm working with before posting the reply above ... You know what I do, and we were all in agreement.
post #11 of 20 (permalink) Old 10-25-2014, 05:27 PM
My magnaflow muffler is covered in surface rust, which is 409 stainless steel, so...
post #12 of 20 (permalink) Old 10-25-2014, 08:57 PM
Stainless steel CAN rust. Some faster than others.
Stainless just doesn't rust as fast as aluminized or cold-roll steel.
Fuelly
RalphP is offline
post #13 of 20 (permalink) Old 10-25-2014, 10:42 PM
I believe mine is stainless as well. It's in pretty good shape and is all original which is 288K miles worth. Other parts of the car aren't as lucky
1996 Ford Thunderbird LX - 4.6L V8 - Full LED conversion almost complete - Daily Driver
2012 Mazda 3i Touring - Skyactiv-G 2.0L I4 - LED interior and tag lights, TRS Black Series Clear Lenses w/blocked squirrell finders, DDM 4500K HID low beams, 9011 HIR1 high beams - SOLD
2011 Mazda 2 Sport - 1.5L I4 - LED interior and tag lights, First Retrofitted Mazda 2 in North America using Morimoto Mini D2S projectors and Osram Xenarc 4300K D2S bulbs http://www.mazdas247.com/forum/showt...it-your-Mazda2 - TOTALED
Now offering retrofitting services including projector swaps, lens swaps, painting, etc. PM for details
96MN12Bird is offline
post #14 of 20 (permalink) Old 10-26-2014, 06:56 AM
Rayo's Avatar
As it's already been said the factory exhaust is stainless..A low grade stainless probably a 409 type stainless, but stainless nonetheless..
I have very few exhaust mods..
A set of High Flow Cats with the 3rd cat, and resonator eliminated with a 3" y-pipe..Then back to the stock exhaust right before the fuel tank..
The only rust on my factory exhaust is the front section that was modified, and that's only surface rust..
Someone should try polishing their factory exhaust just to see how much of a shine it will hold..Since it is stainless after all..
It only makes sense if/when I upgrade my entire exhaust I should use stainless instead of the cheap aluminized tubing..
There's no reason to downgrade in quality if the factory used stainless..
1991 Ford Thunderbird Sport
Rayo is offline
post #15 of 20 (permalink) Old 10-26-2014, 10:19 AM
Moderator &amp;amp; Teksid Whore
someone got ripped off
post #16 of 20 (permalink) Old 10-26-2014, 01:29 PM
Don't forget, he lives where they salt the roads every winter.
Salt and water does a number on stainless steel almost any variant.
Fuelly
RalphP is offline
post #17 of 20 (permalink) Old 10-26-2014, 02:25 PM
r429460's Avatar
So the SS on boats is going to corrode.
Quickest N/A Modular MN12.
01/31/18 PBIR
THE danner EATER
r429460 is offline
post #18 of 20 (permalink) Old 10-26-2014, 02:42 PM
Originally Posted by Rayo View Post
As it's already been said the factory exhaust is stainless..A low grade stainless probably a 304 type stainless, but stainless nonetheless..
Type 304 is not a low grade stainless; type 409 is the lower grade and most likely the grade of stainless used for the exhaust from the factory. See below for why.
From Wiki:
"Type 409—cheapest type; used for automobile exhausts; ferritic (iron/chromium only)."
From BORLA:
"... Also, the inferior [409] grade of stainless is the only cheap material that will last through the factory warranty period."
BORLA uses T-304 series austenitic stainless; the classic 18/8 (18% chromium, 8% nickel) stainless steel.
304 is also non-magnetic due to the higher nickle content; 8 to 10% nickle for type 304 vs only .5% for type 409.
If it sounds like I'm promoting BORLA well ... yea ... I am a fan of theirs.
http://www.borla.com/support/faqs/wh...xhaust_upgrade
http://www.autoanything.com/exhaust-...nd-sounds.aspx
It all depends on the type of stainless; there are about 30 different types ranging from 100 series to 600 series ...
http://en.wikipedia.org/wiki/SAE_ste...tainless_steel
Also see: https://www.dieselnet.com/tech/diesel_exh_mat.php There's a good discussion of stainless in automotive exhaust systems at this link.
It's not just salt that will cause corrosion in stainless:
"Also, some commonly used stainless steels, such as type 304, have been found to corrode after exposure to urea decomposition products in high temperature environments." This problem is mostly related to diesel engines.
"Some of the stainless steel car exhaust systems available in the market these days are built of aircraft-quality T-304. It is true stainless inside and out, not aluminum, not mild steel, not coated aluminum, not just enveloped with stainless on the outside for show.
Car exhaust coatings extend the life of mild steel however; coatings suffer at the weld points. Compared to aluminized steel, 100 percent [stainless] steel has the highest chromium content, making it the most resistant to corrosion. Moreover, it is the most reliable material for a long-lasting car exhaust system."
http://www.streetdirectory.com/trave...r_exhaust.html
Got GOOGLE?
post #19 of 20 (permalink) Old 10-26-2014, 08:21 PM
Rayo's Avatar
Thank You Dr.Wikipedia..
Yeah I had that backwards..The 304 is the better of the two between the 304 and 409 stainless material..
Rayo is offline
post #20 of 20 (permalink) Old 10-29-2014, 08:27 PM
gordonm1's Avatar
I just replaced the exhaust on my '92 LX. It was kinda sad because the old exhaust came out entirely intact as if you could install it again and go for many miles. I thought I could hear a small leak but I replaced mostly to get all I could out of my engine without changing heads. I've read my 1992 is stainless, or was, dual 2.5" no cats True bendz aluminized now. Might have to park it for the winter to save the most valuable parts now.
gordonm1 is offline
