Should I buy new (Flowmaster) cats when having the exhaust replaced? - TCCoA Forums
post #1 of 10 (permalink) Old 04-10-2015, 04:32 PM Thread Starter
Cougar Pilot
BlackCat94's Avatar
215k miles on factory cats, no known issue with them, but if I'm replacing everything else should I do these too? I know they clog eventually.
I'm not going to go catless as I don't plan on running mufflers and don't want it to be too loud, nor do I think I can replace the cats with SS pipe on my own.
Let's assume I can get them for $31 each, in which case I might be dumb not to?
http://www.flowmastermufflers.com/?p...category=0&kw=
TCCoA, there's no better way.
BlackCat94 - The Revolution.
BlackCat94 is offline
post #2 of 10 (permalink) Old 04-10-2015, 06:01 PM
bowez's Avatar
Stay OEM--they are better in every way. Only exception to that is if they are bad and you must get emission checked.
Think about it OEM convertors are expensive for a reason--the same reason they are stolen. Aftermarkets ones aren't for the same reason.
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
post #3 of 10 (permalink) Old 04-10-2015, 06:55 PM
gordonm1's Avatar
The cats are needed to pass inspections. So, depending on how rigorous the inspections are, you might need the stock cat. I'd find out what you can get away with at inspections and make your decision based on that.
My stock cats were a very restrictive part of a very restrictive exhaust system. I put on hi-flo 2.5" Magnaflow cats but I don't get inspected.
gordonm1 is offline
post #4 of 10 (permalink) Old 04-10-2015, 07:00 PM
Factory or nothing.
post #5 of 10 (permalink) Old 04-11-2015, 07:10 AM
bowez's Avatar
They are not as restrictive as every on thinks--now that 90 bend right in front of them is.
93 SC Tbird
93 5.0 Tbird
bowez is offline
post #6 of 10 (permalink) Old 04-11-2015, 11:22 AM
gordonm1's Avatar
My 1992 5.0 had a straight pipe that required the 90 degree bend happen in the cat. I'm not really sure what the original poster would do to the front half of the exhaust to improve flow and stay OEM. Bigger pipes with reducers on both ends of all three cats and eliminate the resonator?
You could do the back half first maybe without mufflers or free flow ones Like Magnaflows and see if you are happy. You might find a guy that will reuse the original mufflers and just see what a true dual back half does for you with bigger pipes.
I needed the dual in dual out resonator/xpipe to reduce noise with free flowing rear mufflers. I've still got my original front half and may post a pic here to see how restrictive it looks.
http://i79.photobucket.com/albums/j1...pshlpdefbh.jpg
The newer pipes are the xpipe and 1 nice 90 degree mandrel bend in 2.5". The second exhaust shop that installed the DI/DO resonator and cats only charged another $320. This is what they removed, its a lot bigger and smoother than stock. The passenger side is almost a 90 bend just before the cat and the driver's side that's shielded is a 90 between the cat and down pipe. FYI my entire exhaust system was still solid and could be bolted up to another 1992. It just breathed like it was headed for heart surgery.
gordonm1 is offline
post #7 of 10 (permalink) Old 04-11-2015, 09:44 PM
If you're not worried about larger flow in that section, stick with the OEM cats as the larger bodies will do more for sound suppression. Catalytic converters aren't as restrictive as people think they are. The pipes are where you will gain most of the flow. Gradual bends and larger piping(sized appropriately for your application) will flow best. If you're wanting larger pipes up front, then match high flow converters with the right pipe size. The last thing you want is to reduce pipe size down to stock for just the converters and then neck it back up. It creates a bottle neck and hurts flow.
The reason factory converters are stolen is because of the rare Earth metals that are in them like Platinum.
1996 Ford Thunderbird LX - 4.6L V8 - Full LED conversion almost complete - Daily Driver
2012 Mazda 3i Touring - Skyactiv-G 2.0L I4 - LED interior and tag lights, TRS Black Series Clear Lenses w/blocked squirrell finders, DDM 4500K HID low beams, 9011 HIR1 high beams - SOLD
2011 Mazda 2 Sport - 1.5L I4 - LED interior and tag lights, First Retrofitted Mazda 2 in North America using Morimoto Mini D2S projectors and Osram Xenarc 4300K D2S bulbs http://www.mazdas247.com/forum/showt...it-your-Mazda2 - TOTALED
Now offering retrofitting services including projector swaps, lens swaps, painting, etc. PM for details
96MN12Bird is offline
post #8 of 10 (permalink) Old 04-12-2015, 08:54 AM
bowez's Avatar
And the amount in OEMs v. Aftermarket is what makes them effective for over 100k miles, while aftermarket are only good for a few years.
93 SC Tbird
93 5.0 Tbird
bowez is offline
post #9 of 10 (permalink) Old 04-12-2015, 11:56 PM Thread Starter
Cougar Pilot
BlackCat94's Avatar
No inspections, unless it's done roadside by a trooper who thinks my car is awfully loud!
Not going to have any mufflers, true duals all the way back. The third cat is already long gone.
I was just thinking the factory cats would be nearing the end of their life, but perhaps not.
post #10 of 10 (permalink) Old 04-14-2015, 09:03 PM
That's due to the size difference. OEM converters are larger than high flow units. Placement also has a big impact on life.
