Q: Looking for opinions on exhaust flange gaskets - TCCoA Forums
post #1 of 6 (permalink) Old 04-19-2016, 03:45 PM Thread Starter
S4gunn's Avatar
All:
I'm putting my exhaust back on so I can rebuild the last section after my tbird track car got rear ended in our last lemons race.
For those of you unfamiliar with my car, it's a 95 tbird with a 5.0 and manual swap I use for lemons. A few years ago I built my exhaust system to be an homage to the Pagani Zonda AND remov
You can hear the system here:
http://forums.tccoa.com/8-engine-5-0...ggestions.html
See pics here:
http://tccoa.com/forums/101-exhaust/...my-review.html
Anyway, I need to rebuild the last section since it got a little crunched and I need to extend the quad tips because some of my drivers were complaining about the fumes when under caution (fair enough).
Here's my question: for the 3" to 3" flanges, I've been using the following ceramic/metallic gaskets between the flanges.
Summit G4749 Collector Gaskets Steel Core Laminate 3 Hole 3" Inside Dia Pair | eBay
The problem is that the gaskets keep disintegrating after exposure to heat (because racecar). After just two days on the track (granted, these are 8 hour days), the laminate stuff is coming off and the underlying matrix is still in place.
When I last pulled the exhaust off (4 track days, the gaskets just fell part).
The poor mans solution is that I can just put copper RTV on the current gaskets and bolt everything back together. The downside is that the next time I want to put gaskets on, I'll have to spend effort scraping/brushing the old RTV off. This is what I'd probably do at a racetrack but if I have the time to fix things correctly pre-race, I might as well do so.
Alternative to buying more gaskets that will just fall apart again:
1) Same stuff, just slightly cheaper - EPP Exhaust Gasket 3 Bolt 3" inch 77mm Fits Nissan RB25DET Elbow Downpipe R33 | eBay
2) ALUMINUM gaskets - 3" Aluminum Exhaust Gasket Collector Cat Back Joint Pipe 3 Hole w Fire Ring | eBay
3) Felpro 60083 (looks even cheaper than the summit gaskets but they ARE cheap)
http://www.autozone.com/1/products/2...pro-60083.html
4) Fancy COPPER gaskets - 3" Copper Header Exhaust Collector Gaskets Reusable SBC BBC 302 350 454 383 New | eBay
I use two of them right now so the plan is to buy 4 (two to use on the car, two as spares).
Q: What would you guys use in my situation? I'm leaning towards the copper gaskets from eBay (eBay is ideal because I have a few GCs I've bought for cheap).
Regards,
-g
http://goo.gl/csaet4
S4gunn is offline
post #2 of 6 (permalink) Old 04-19-2016, 04:04 PM
bowez's Avatar
On my cars I use RTV only, if you want an easier to clean solution Copper is the only way to go.
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
post #3 of 6 (permalink) Old 04-19-2016, 05:28 PM
I'd go copper, since you have to have access; it's pricey, but can be reused forever.
The best way I've found to remove rtv is a steel wheel wire brush; you have to be really careful.
Especially with air tools.
post #4 of 6 (permalink) Old 04-20-2016, 07:40 AM
T6Rocket's Avatar
Don't expect miracles with the copper. I used a Mr. Gasket 3-bolt copper gasket on the 3" exhaust dump cap I used to have on my turbo car. After using it a couple times, there was clearly carbon on it, indicating at least a small leak. Nothing audible though.
You would think it is soft, and conforms to the flanges, but it doesn't. I was concerned about stripping the bolts and didn't want to over-tighten. I guess if you really cranked it hard, the results would be a little better, but for me, I had to use the RTV with the copper anyway.
Al
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is offline
post #5 of 6 (permalink) Old 04-20-2016, 06:49 PM
Originally Posted by T6Rocket View Post
...I was concerned about stripping the bolts and didn't want to over-tighten. I guess if you really cranked it hard, the results would be a little better, but for me, I had to use the RTV with the copper anyway.
Al
You have to tighten it enough to deform the copper.
If the bolts are too weak to compress copper slightly, they need replacing anyway.
For the next use, hammer it flat, hit it with a torch until it glows red hot, and use it again.
I've got a copper dirt bike head gasket that 30 years old, I can't count how many times it's been apart...
post #6 of 6 (permalink) Old 05-08-2016, 05:30 PM
Have you considered switching to a doughnut. Napa number 31556 in their exhaust parts. Its made by Walker and I believe is also the walker number. It's graphite with a 3 inch id. Your flanges would have to bell a little bit and pinch the gasket between the the flanges. The graphite construction would compensate for irregularities and hold up to the temperature. Should be reusable. A second option would be the Napa 31703. This one will be similar to the a Toyota flange gasket. My choice would be the 31556, but it's not my project. As a side note, When my 67 Mustang was restored in 1985 we used the the doughnut and flared joint. I still have the car and the same gaskets in it today. The car was a daily driver and weekend racer through the 80's and just a daily driver through most of the 90's.
NapaMike
napamike is offline
