I'm exhausted - TCCoA Forums
 1Likes
  • 1 Post By XR7-4.6
post #1 of 6 (permalink) Old 09-03-2016, 01:37 PM Thread Starter
Mr.Thunderbird's Avatar
I'm exhausted
Looking forward to next years plans for true duals I have found some JBA headers for $295. They are the stainless/ceramic types. I've also heard a lot about just porting the stock manifolds, but doing searches on the subject mostly finds old post with no photos that are still there.
Here is the long range plan. All the add on's I do now I want to bolt up to a new engine I plan for in the future. So I know that headers aren't going to be too useful to a stock engine now, but they should last and work better than stock for another engine with more power later....
Does anyone have experience with the JBA headers? With porting stock manifolds? I have most of the tools necessary for the porting. I plan on the use of 2 1/2 inch mandrel bent exhaust.
Mr.Thunderbird
Mr.Thunderbird is offline
post #2 of 6 (permalink) Old 09-03-2016, 02:39 PM
*dry* It may help to know which motor you're applying them to.
Fuelly
RalphP is offline
post #3 of 6 (permalink) Old 09-03-2016, 03:39 PM
JBAs have all the downsides of low quality headers and all the performance of stock manifolds. Shorties are a complete waste of money in general, they give some bling under the hood but our SOHC heads and big shock towers basically render them invisible.
Woodman likes this.
post #4 of 6 (permalink) Old 09-03-2016, 04:50 PM Thread Starter
Oooops
It's '95 4.6 with 92,000 miles
Mr.Thunderbird
post #5 of 6 (permalink) Old 09-03-2016, 04:55 PM Thread Starter
Not after bling. So I can get some stock manifolds and do some porting. Is there a better year of manifolds that will fit my 4.6? And any photos of the work that's been done to them so I have a better idea of what I'm up against. I have most of the tools at the saddle shop to do the porting save for a right angle grinder.
Mr.Thunderbird
post #6 of 6 (permalink) Old 09-03-2016, 08:16 PM
Woodman's Avatar
Porting the stock manifolds will give you better performance than shorty headers, but saving up for some Kooks is where the power is at.
Woodman is offline
