95 SC Cat Delete - TCCoA Forums
post #1 of 4 (permalink) Old 05-16-2018, 07:43 AM Thread Starter
nckhammond's Avatar
95 SC Cat Delete
I picked up a 95 SC that was in storage for many years, Ive got her on the road, New water pump, radiator, hoses, filters etc (plugs and wires are on the list). The exhaust is rotted out, however at some pointe someone eliminated the cats. All the kits I see are for cat back. (I get no check engine light thou). Anyone seen a cat delete kit, or at least the flanged elbows to attach to the manifolds, or am I just gong to have to use straight flange adapters and build my own? Also I'm assuming the manifold connection is 2"?
95 Thunder Bird SC Auto Daily Driver Work in Progress, with every factory option original owner could check.
nckhammond is offline
post #2 of 4 (permalink) Old 05-16-2018, 09:06 AM
Thunderstruck95's Avatar
I'm not sure if you have stumbled into Supercoupe Performance yet- but they have several options including these- https://www.supercoupeperformance.co...converters-141
Welcome to the community.
1995 T-Bird.
PI 4.6. Bullitt intake. Stage 2 MHS cams. Kooks Headers. 4,200 ATF Speed converter. BCA Transmission. 4:10s. Tune by Supercoupes Unlimited. 245 RWHP.
3,700 lbs at half tank. Goal- 3,400 lbs
Best of 13.85 at 96 mph. Goal- 11's NA
1997 Lincoln Mark VIII FX2 Sand Dune Machine- R.I.P.
Thunderstruck95 is offline
post #3 of 4 (permalink) Old 05-16-2018, 09:20 AM Thread Starter
nckhammond's Avatar
that's perfect, looks like I may have to play hunt for the O2 sensor thou, as I don't remember seeing one in the pipe there now.
post #4 of 4 (permalink) Old 05-16-2018, 08:23 PM
dDUBb's Avatar
That 95 SC is OBD1, so the only o2 sensors are before the catalytic converters ( one of them is in the exhaust manifold ) .. the PCM wont be able to detect anything after the cats so you wont get a check engine light.
The factory SC exhaust has double walled downpipes up to the point where they Y under the transmission .. tends to make these cars sound more ricey when you go with an aftermarket exhaust setup.
dDUBb is online now
