Some exhaust work - TCCoA Forums
post #1 of 23 (permalink) Old 02-19-2006, 08:20 PM Thread Starter
Some exhaust work
Ok, I'm prolly gonna get flamed (to lazy to search ) for this but in a few days (once I get paid) I am taking my car down to the exhust shop to have it put up on the rack to see what they can do. Now, I already have a straight pipe in place of a resonator and dual flowmasters. I am looking at spening between $300 and $700 dollars. What can I have done (cats, pipes, etc.) and how much am I looking at spending. HP and sound gains? Sorry for the noob question, thanks for being patient with me.
Slow95xr7 is offline
post #2 of 23 (permalink) Old 02-19-2006, 08:42 PM
Well if your going to admit your too lazy to search you just asking to get flamed. You can get a custom 2 1/4 setup with either a mid mount magnaflow or h-pipe with mufflers in the rear for probably like $500 maybe less. You need to give more info on what your looking for in sound ect.. and if you need cats in your area. DO A SEARCH next time theres probably 100s of threads on setup and take a look at the soundclips area for ideas.
-Matt-
MattsLE97 is offline
post #3 of 23 (permalink) Old 02-19-2006, 08:43 PM
Well, to put things in perspective, I have $625 in the exhaust on this car (not counting the headers).
And those are the polished cats and muffler from Magnaflow/Carsound. So I would have to say that $700 would let you do just about anything within reason as far as exhaust goes.
-Rod
post #4 of 23 (permalink) Old 02-20-2006, 12:17 AM
Refrigerator Raider Hater
GreenBird's Avatar
I have almost $1000 in my exhaust not including headers, but it's dual 2.5" stainless everywhere, even the hangars, tips, o2 bungs, etc.
$600 would be quite doable for mild steel.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #5 of 23 (permalink) Old 02-20-2006, 09:02 AM Thread Starter
^Thanks for the advice, good to know It won't cost an arm and a leg. And I negelected to metion I live in Missouri, so that means I need mufflers and cats. Thanks a ton.
post #6 of 23 (permalink) Old 02-20-2006, 10:19 AM
I have less than $400 in mine, although it is 2.25" compression bent, one muffler, and two tips..
I think total it was about $340
weswing04 is offline
post #7 of 23 (permalink) Old 02-20-2006, 11:00 AM
bad93bird's Avatar
I've got about $150 in mine. All I had done was cut the resonator, weld a Dynomax bullet muffler in it's place and cut the 2 mufflers off the back and run straight pipe in their place. Sounds great.
bad93bird is offline
post #8 of 23 (permalink) Old 02-20-2006, 11:31 AM
Traveler's Avatar
I've got pretty much the same setup as MattLE97, and what WesWing04 used to have. (do you still have the midmount magnaflow?)
I think it probably cost me around 300-350 by the time it was done. But I got a great deal on parts from Ebay.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #9 of 23 (permalink) Old 02-20-2006, 11:44 AM
yep, just not the round ones in the back.
post #10 of 23 (permalink) Old 02-23-2006, 12:24 AM Thread Starter
How much HP are we looking at. Converting a stock exhaust system to flowmaster mufflers, 2.25' piping, magnaflow cats. and what should I have in place of the 3rd cat?
post #11 of 23 (permalink) Old 02-23-2006, 07:16 AM
Baby Huey
warmaster259's Avatar
Make sure to keep in mind that most exhaust shops wont touch catalytic converters.
Jim
warmaster259 is offline
post #12 of 23 (permalink) Old 02-23-2006, 12:44 PM
Flowmasters .....
I'd either run a single DIDO Magnaflow in place of the third cat with no rear mufflers, or run dual Magnaflows or Borlas at the rear of the car, with nothing in place of the third cat.
-Rod
post #13 of 23 (permalink) Old 02-23-2006, 12:54 PM
Traveler's Avatar
My local shop didn't mind pulling the third cat, but refused to touch either of the first two cats.
Guess they figured that as long as they left the other two cats, they weren't breaking any real laws.
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #14 of 23 (permalink) Old 02-23-2006, 01:05 PM
I usually just trailer the car to the exhaust shop with no exhaust on it. Most shops won't remove the cats, but if the cats are already gone (no exhaust), they'll install whatever you want.
-Rod
post #15 of 23 (permalink) Old 02-23-2006, 01:16 PM
bad93bird's Avatar
I think 2.25 is the stock size. I really wouldn't go much bigger than that with a stock engine. If I was really doing a complete exhaust, I'd go with shorties, cut off the cats. Have the 90 degree bedn on the drivers side removed, then install some free flowing cats. ONly 2. Get rid of the 3rd cat and change that into a Y pipe or H pipe. Keep my Dynomax bullet and just pipe frome there to the bumper. I might go up on pipe size I may not. I'm just a little over stock.
post #16 of 23 (permalink) Old 02-23-2006, 11:47 PM Thread Starter
Rod. I really like your setup, you think it would pass MO emissions?
post #17 of 23 (permalink) Old 02-24-2006, 01:54 AM
Thanks, and yes (I live in MO, too).
-Rod
post #18 of 23 (permalink) Old 02-26-2006, 07:57 PM Thread Starter
Well, I stoped by the local exhaust shop and they estimated $800 parts and labor for the magnaflow cat, DI/DO setup for parts and labor They also said my car had 2" piping.
post #19 of 23 (permalink) Old 02-26-2006, 08:27 PM
Jedi Master
mn12xr7's Avatar
my exhaust cost me about $200 tops...no cats, two flows no rear exit..
-Orlando
mn12xr7 is offline
post #20 of 23 (permalink) Old 02-26-2006, 08:59 PM
Wow. I would check out a couple other exhaust shops in your area to compare prices. By the way, what area of Missouri are you in?
-Rod
post #21 of 23 (permalink) Old 02-27-2006, 01:20 AM Thread Starter
^In around the St. Charles/ St. Peters/ O'Fallon area. Like 20 min west of St. Louis...and yeah, this is the place (compare automotive) that wanted to $300 dollars to put on flowmasters! Lol. I think I'll shop around. Thanks again.
post #22 of 23 (permalink) Old 02-27-2006, 11:46 AM
Well, if you feel like taking a drive, House Springs Discount Muffler (in House Springs, MO) is the place that does my exhaust work. They have a guy (who owns a 90 XR7, by the way) come in on Saturdays to do custom work. He is the one that did the exhaust on both my Splitport 94 LX and my DOHC 90 XR7.
-Rod
post #23 of 23 (permalink) Old 02-27-2006, 12:54 PM
hee hee, same hear.
Except Edelbrock mufflers.
