I give up! Magnaflow cats question... - TCCoA Forums
post #1 of 20 (permalink) Old 02-20-2006, 03:39 PM Thread Starter
Unhappy I give up! Magnaflow cats question...
Okay... Now I've spent half an hour searching here and
another half hour comparing the Magnaflow cats
on summit....
I just can't see any difference between the one
for 65 bucks and 135 bucks...
Okay... the 135 ones are 21" 3 chambered
honeycones made out of stainless steel.
and the 65 ones are 16" but that's all the difference I
can tell...
My guess is that the 21" ones are better at removing
the CO and HC but would 16" do the job?
I've got about the same laws over here as
the poor souls in Cali but with the difference that
as long as the new exhaust is equal or better at "cleaning" the
exhaust it's okay...
They don't care if it's stock or if it after market as long as the
CO and HC values are under certain limits...
So, what's everyone using and does anyone got
a partnumber?
Thanks!
//Per
Thyg0d is offline
post #2 of 20 (permalink) Old 02-20-2006, 06:17 PM
21" long cats!?!
Do you have the part numbers of the two that you're looking at?
-Rod
post #3 of 20 (permalink) Old 02-20-2006, 06:38 PM
FordFanatic's Avatar
why not order them from supercoupeperformance.com?
FordFanatic is offline
post #4 of 20 (permalink) Old 02-21-2006, 05:01 AM Thread Starter
http://store.summitracing.com/defaul...5&autoview=sku
http://store.summitracing.com/partde...1&autoview=sku
For example...
Can't find any differences other than the lenght...
The reason I don't buy 'em from supercoupeperfomance.com
is that I have to get some other stuff and the shipping is cheaper if
I order A LOT of stuff at the same time...
//Per
Thyg0d is offline
post #5 of 20 (permalink) Old 02-21-2006, 01:19 PM
You want the first one. The second one has a O2 bung in the middle of the cat, and the last two have ports for use with an air pump.
EDIT: Before you order, take a look at your engine to see if you have an air pump. I just noticed that you have a 302, which may have come with one. It would be a belt driven pump, in addition to the AC compressor, alternator, water pump, and power steering pump. If you DO have one, then you'll want one of the two bottom cats that you listed.
-Rod
post #6 of 20 (permalink) Old 02-21-2006, 01:40 PM Thread Starter
Yup... Got an airpump.... down to the left below the alt...
Don't dare to take it off since it lowers the CO and HC value...
From what I've read it helps burning unburnt fuel vapors...
But from what I remember it's just connected to one
of the cat's right...?
So the right choice would be
one
http://store.summitracing.com/partde...5&autoview=sku
and one
Right?
One 16" 2½ inch in/out with AIR
and one 16" 2½ inch in/out without AIR
Thanks for your help...
//Per
Thyg0d is offline
post #7 of 20 (permalink) Old 02-21-2006, 01:45 PM
That is correct.
-Rod
post #8 of 20 (permalink) Old 02-21-2006, 02:06 PM Thread Starter
Thanks alot!
You know the stuff as usual!
//Per
Thyg0d is offline
post #9 of 20 (permalink) Old 02-21-2006, 02:10 PM
No problem.
-Rod
post #10 of 20 (permalink) Old 02-23-2006, 06:00 PM
whats it mean when it says converter style 2 way or 3 way? i was going to buy these ones but had that question when i was looking at the ones thygod was looking at.
http://store.summitracing.com/partde...6&autoview=sku
post #11 of 20 (permalink) Old 02-24-2006, 01:58 AM
The stock third cat on our cars is a three-way (two inlets/one outlet). A two way only has one inlet and one outlet.
-Rod
post #12 of 20 (permalink) Old 02-24-2006, 05:24 AM Thread Starter
Are you sure?
Just thought if you check out this link
the converter style is 2 way/3 way/3 way with oxidation...
How the .... do they know which one to send if they've got
the same part# ???
Just got confused again...
Edit:
So sorry to tell you but you're actually wrong...
Both are 2/3 ways but a bit above it says single inlet and single outlet
so it can't be the number of outlets/inlets....
Going to ask summit and see what they say...
//Per
Thyg0d is offline
post #13 of 20 (permalink) Old 02-24-2006, 09:10 AM
2 way and 3 way are not the number of inlets and outlets, "Three-way" refers to the three regulated emissions it helps to reduce -- carbon monoxide, VOCs and NOx molecules.
I don't know what 2 a two way does, and I don't when a 2 way is fine (older vehicle) and when a 3 way is needed.
Bangster is offline
post #14 of 20 (permalink) Old 02-24-2006, 12:49 PM
Well, that's the last time I listen to the guy at the exhaust shop.
I guess you learn something new everyday.
-Rod
post #15 of 20 (permalink) Old 02-24-2006, 02:05 PM
ok cool, cause i was looking at the picture and scratching my head. sweet, im ordering those and some dynomax bullets and having the exhaust redone.
now another stupid question. im going to run 2.5" all the way back, i need a 2.5" cat right? i was just worried that if they were both the same size it wouldnt slip over the pipe. oh and i need some o2 bungs, anyone know what size?
post #16 of 20 (permalink) Old 02-24-2006, 03:05 PM Thread Starter
Got a really fast answer from Summit...
Unfortunately the answer came so fast he didn't have time to put
much effort into it....
Response (A.C.) - 02/24/2006 01:20 PM
The 2 way was normally used on the 1980 and earlier, but I would still consider the 94006.
Didn't clear my head that much really...
Probably asked the wrong question or something...
But there you have it anyway...
So I guess Bangster was right on!
Thanks!
//Per
Thyg0d is offline
post #17 of 20 (permalink) Old 02-24-2006, 03:26 PM
looking on summit all the bungs are 18x1.5 so i guess thats a pretty safe bet. any opinions?
post #18 of 20 (permalink) Old 02-24-2006, 03:30 PM Thread Starter
Yeah probably...
I'm having a shop do mine so I haven't thought
about it actually.. That'll be their problem...
//Per
Thyg0d is offline
post #19 of 20 (permalink) Old 02-24-2006, 03:33 PM
the shop im going to didnt have any so i have to get them.
post #20 of 20 (permalink) Old 02-24-2006, 04:27 PM
well i got the highflow cats off of scp. mine as well pay a couple extra bucks for the ss.
got the mufflers and bungs from summit. figure if the bungs are wrong i can send them back, but if all of the ones they sell are the same its a pretty safe bet.
