Exhaust "Donuts" - TCCoA Forums
post #1 of 10 (permalink) Old 02-28-2006, 11:23 AM Thread Starter
Traveler's Avatar
Exhaust "Donuts"
I'm getting ready to pull the exhaust from the manifolds in order to get some clearance to install new tranny mounts. Before I do this I'm curious. What are the odds that I'll need new gaskets for the manifold/exhaust pipe joint, and/or new bolts for the same place? Is it easy to remove and install?
Don't want to get halfway through and find out I need new parts or tools!
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #2 of 10 (permalink) Old 02-28-2006, 01:31 PM
Awaiting E-Mail Confirmation
tinman_72's Avatar
There is a 100% chance that you will NOT need new exhaust donuts. Donuts are for GM's.
tinman_72 is offline
post #3 of 10 (permalink) Old 02-28-2006, 02:06 PM Thread Starter
Traveler's Avatar
LOL thanks. Is there any kind of gasket, or something sealing the joint that I need to worry about?
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #4 of 10 (permalink) Old 02-28-2006, 02:36 PM
fast Ed's Avatar
It is a ball flange connection, no gaskets or sealer needed. Just has to be drawn up and tightened evenly on both studs.
cheers
Ed N.
88 T-Bird Turbo Coupe 5-speed
fast Ed is offline
post #5 of 10 (permalink) Old 02-28-2006, 03:33 PM
MN12 Fanatic
Tony's Avatar
Send a message via AIM to Tony Send a message via MSN to Tony Send a message via Yahoo to Tony
Yeah what they said! But be carefull not to break any of the studs, especislly the little one! It can turn into a nightmare!!!
Sold - 1997 Ford Thunderbird 4.6 Sport - Full bolt on, PI stuff, gears, converter, exhaust, full suspension & many other things.
2007 MUSTANG GT (5M) - 504rwhp/449rwtq
- Paxton NOVI 2200 H.O. (10psi) - CMDP's - 127200 Comp Cams - BBK LT's - O/R X - FRPP GTA's - Mid Atlantic Tuned - FRPP 4.10's - Truetrac - Moser Axles - McLeod RST - Fidanza Steel FW - Eibach Pro Kit - J&M LCA's - UMI Relo. Brackets - Spohn Adj. PHB - Prothane Motor Mounts - Hawk HPS Pads - 19" Sport Edition KV5 Rims - Hankook Ventus V12 Evo Tires
Tony is offline
post #6 of 10 (permalink) Old 02-28-2006, 03:38 PM
Eleventeenth Gear Poster
Aaron K.'s Avatar
Is there any generic type of gasket one could use in that location if they think they have a leak there?
Sold = 96 Thunderbird
Aaron K. is offline
post #7 of 10 (permalink) Old 02-28-2006, 03:42 PM
MN12 Fanatic
Tony's Avatar
Well I have never seen a gasket for them before.
But I am sure you could slap some Exhaust/Muffler Cement in there and that should take care of any leaks!
I have personally never did it on my Bird, but have done it on several other vehicles with good out comes....
Tony is offline
post #8 of 10 (permalink) Old 03-04-2006, 01:14 PM
ScottG29's Avatar
Send a message via AIM to ScottG29 Send a message via MSN to ScottG29 Send a message via Yahoo to ScottG29
BE SUPER SUPER CAREFUL NOT TO BREAK THE STUDS.. makes for one hell of a job to fix
Scott G
96 Thunderbird LX Sport 4.6L V-8 202 rwhp 276ft/tq
-March U/D Pulleys -PP Balancer -True dual flowmaster exhaust w/o cats -PI Intake -Trickflow Plentum -75mm throttle body -Cold air -90mm MAF -Tune by Livernois Motorsports -Some audio equipment -17 x 9 Cobra R Wheels -275/45 Bridgestone Potenza's -Eibach Springs -Koni Shocks -KVR Rotors -Kevlar Pads -3000 Stall -3.73 Gears -B&M Transcooler
www.livernoismotorsports.com
Mod-Motor Specialists
ScottG29 is offline
post #9 of 10 (permalink) Old 03-04-2006, 02:30 PM
Gcline's Avatar
well, before you put it all back together, put some muffler cement on the ball flange, because your prolly not gonna be able to tighten as tight as it was (because of old bolts and whatnot) so its just extra security.
Daily Driver, 38mpg!
Gcline is offline
post #10 of 10 (permalink) Old 03-05-2006, 06:42 PM Thread Starter
Traveler's Avatar
LOL I've thought of a better way to get the tranny clear. I'm going to have "joints" put in the exhaust just after the Cats. Then I can loosen them and slip the exhaust off easily whenever I need to.
Thanks for the tips though. Come in handy if I ever get rid of the cats.
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
