Just installed true-dual exhaust - TCCoA Forums
post #1 of 16 (permalink) Old 03-13-2006, 06:54 PM Thread Starter
PostSkank
StupidFly's Avatar
I had a free weekend, and everything I needed, so I spent about 12 hours yesterday cutting mandrel bends, tac welding, and getting under and out from under my an car innumerable amount of times. The result was a 2.5" true dual exhaust, cats, magnaflow x-pipe/resonator, and 2 Borla XS mufflers.
It actually isnt any louder than my stock exhaust without the rear mufflers, and is perhaps quiter inside the car. It has a slightly different tone though. I like it.
The SOTP meter isnt telling my much of anything as far as power gains, however it seemed to pull a little better on the Interstate today.
... as this was my first endeavor into fabricating exhaust systems, this one seems to hang a little low in the rear... I'll have to watch those speed bumps until I get a chance to get back under there and fix that
math > pasta
StupidFly is offline
post #2 of 16 (permalink) Old 03-14-2006, 12:16 PM
Midnight's Avatar
Send a message via AIM to Midnight
How much $
Sprtnlax14: i was was up at 4:30 to hunt
LtlLinds424: you did NOT just say hunt
Sprtnlax14: whatever, the day you become a vegan we'll talk
LtlLinds424: the day that you stop only spitting game and not producing girls in your bed... we'll talk
My Dragons
Midnight is offline
post #3 of 16 (permalink) Old 03-14-2006, 12:31 PM
Traveler's Avatar
Pics please.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #4 of 16 (permalink) Old 03-14-2006, 12:33 PM
Your car originally had a third cat, right? You think you will have trouble passing emission testing? I want to get done what you did, high flow cats, no third cat, x pipe, two small round mufflers mid mounted, 2 1/4 pipe all the way back.
Plus finding someone that will get rid of the third cat is not likely, I have called a couple of places, and they seem to only do after that third cat. I don't want it to fail the visual inspection. My mufflers are pretty crappy right now, the inner muffler has leaks and a ton of stuff is dumping out the drain hole.
Bangster is offline
post #5 of 16 (permalink) Old 03-14-2006, 12:55 PM Thread Starter
PostSkank
StupidFly's Avatar
Originally Posted by Midnight
How much $
I think I have about $350 or so invested. I got the X-pipe/res for x-mas, so add a little more for that.
Originally Posted by Traveler
Pics please.
I have a couple on the camera, I'll get 'em off as soon as I can.
math > pasta
post #6 of 16 (permalink) Old 03-14-2006, 12:56 PM Thread Starter
PostSkank
StupidFly's Avatar
well, I guess I'll find out about the emissions this fall I think I'll be alright though.
math > pasta
post #7 of 16 (permalink) Old 03-14-2006, 08:14 PM
I'd love to do that with my car this summer... where did you get the mandrel bent pieces, and what shapes would you recommend? spintech baby
weswing04 is offline
post #8 of 16 (permalink) Old 03-28-2006, 02:05 AM Thread Starter
PostSkank
StupidFly's Avatar
I got the mandrel pieces from summit. I got 180* J-bends. If I had just ordered a bunch of 45* bends, I think I might have had less trouble, but that would have cost me about 4 times as much (since the 45* and 180* pieces I was looking at were about the same price.
pics!!
Heres the completed front section. I was in a hurry, so I lopped off the upper portion of the stock downpipes,welded in an adapte, and built from there. That will be replaced with 2.5" next time I get under the car... probably this summer.
another shot of the front section. Frank couldnt resist shocking TCCoA
one of many trips to the bandsaw
midway through the rear section. We had been at it for a good 10 hours at this point, and were pretty tired. So we got a little rushed and sloppy. This is where our angles really started to stray
back at the bandsaw... only about half as dirty as I was when we finished.
a shot of the rear section in the car
A shot from the rear.... you can really see how low it is in this one. Next time I get a few days to myself, I'll fix the geometry on a few spots so it'll tuck up higher. For now, I'll just take it slow over the speedbumps.
math > pasta
post #9 of 16 (permalink) Old 03-28-2006, 10:33 AM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
looking good, nigel. how low does that magnaflow hang down?
2014 GT
1990 300ZX TT
big mike is offline
post #10 of 16 (permalink) Old 03-28-2006, 03:33 PM Thread Starter
PostSkank
StupidFly's Avatar
Thanks mike, the Magnaflow isnt too bad (though it could stand to be a little higher). I just need to take a weekend and rework a couple of the angles, and it should be fine.
math > pasta
post #11 of 16 (permalink) Old 03-29-2006, 07:37 PM
Nice work. The only suggustion I would make is put a connection somewhere so if you have to do rear work or header work you can take just half the system down instead of all of it. Ball connections work well, that way you can adjust the pipe alignment some for a better fit. Also double check all the welds to make sure there are no leaks at all.
Hollywood Ed is offline
post #12 of 16 (permalink) Old 03-29-2006, 08:28 PM Thread Starter
PostSkank
StupidFly's Avatar
I ordered some ball connections, but they didnt show up in time for the install.... in fact, they never showed up. I was only able to find one place that carried them (Dr. Gas). Summit has some, but they are 3" in and 2.5" out (or vice versa)... any idea where else I could nab some? Right now I have some exhaust clamps at the back end of the magnaflow, but I'd much rather the ball connectors.
We pressure checked 99% of the welds before we installed them (ie, Frank held his hand over one end, I stuck my face over the other and blew. Listened for leaks and watched for weld smoke coming out). We were satisfied. When I get under there again, any leaks we missed should be pretty apparent.
math > pasta
post #13 of 16 (permalink) Old 04-11-2006, 06:16 PM
Lithsanatrex's Avatar
Send a message via MSN to Lithsanatrex
nice setup, and i love the homemade leak checker
Lithsanatrex is offline
post #14 of 16 (permalink) Old 04-11-2006, 06:25 PM Thread Starter
PostSkank
StupidFly's Avatar
thanks
I'm going to Switzerland for 10 months or so starting in October, so now I'm thinking about selling it this summer. Need to finish up the brake upgrade and hub swap first though, and some general tune-up stuff. Almost a little frustrating, getting all this work done on it, and now I'm possibly going to sell it.
Anyone interested in a hard-run '92 LX?
math > pasta
post #15 of 16 (permalink) Old 04-13-2006, 08:46 AM
Nice. I can't believe you don't feel much difference. My sotp meter showed huge gains from new exhaust. 1/4 mile times showed 20hp gain I installed 1 5/8 shorty headers at the same time though. The factory rear mufflers were in place before the swap also.
The mandrel bends are nice. Mine has a few spots where the compression bends are probably hurting flow. Oh well, a stick of pipe costs the same as 1 mandrel bend probably.
I took the ball connection from the Mustang h-pipe I ordered and totally hacked up. Most muffler shops can make a ball connection or have used ones around. You could also get them from a salvage yard.
icantdrive55 is offline
post #16 of 16 (permalink) Old 04-13-2006, 10:49 AM
leet sauce
eg0r's Avatar
eg0r is offline
