Fake duals question - TCCoA Forums
post #1 of 15 (permalink) Old 04-04-2006, 03:42 PM Thread Starter
Fake duals question
I'm assuming the exhaust on my 95 LX is factory since car has only 78,000 miles on it. My question is why in the world would the exhaust be installed the way it is, with this H pipe(think thats what its called) and TWO mufflers back by bumper? Why wouldn't ya just put a muffler mid with SI/DO and then just run the pipes on back with some tips on them? Thats what I'm thinking of doing, is there some issues with this I don't know?
Kevin
KANGEL is offline
post #2 of 15 (permalink) Old 04-04-2006, 03:53 PM
Your car comes stock with a Y pipe not an h pipe that I'm aware of. It really depends on what kind of sound your trying to get out of it too.
96CougarXR7 is offline
post #3 of 15 (permalink) Old 04-04-2006, 03:54 PM
Its just the way they designed them and to keep them quiet.
And the setup goes cats to resonator to mufflers
-Matt-
MattsLE97 is offline
post #4 of 15 (permalink) Old 04-04-2006, 04:06 PM Thread Starter
Well I've heard of this H pipe, whats it for?
KANGEL is offline
post #5 of 15 (permalink) Old 04-04-2006, 04:49 PM
to balance the flow and pressure of gas of each pipe after the cats
1993 3.8L Tbird----sold
1994 4.6L Tbird----sold
1995 Mark VIII----sold
2004 Mustang GT----sold
2003 Mach 1----current
smitty2919 is offline
post #6 of 15 (permalink) Old 04-04-2006, 05:58 PM
Theres an xpipe and H-pipe
post #7 of 15 (permalink) Old 04-04-2006, 08:38 PM
JL2K7388's Avatar
Send a message via AIM to JL2K7388
about to ask a stupid question, there is no sound or performance difference from getting a stainless steel muffler as opposed to the regular satin muffler just looks??
96 LX 3.8
Custom air intake, 9" K&N Cone, ASP underdrive pulleys, True Duals with DI/DO midmounted Magnaflow, ported upper and lower intakes, ported TB...and more to come
http://www.cardomain.com/ride/2385772
-Johnny-
JL2K7388 is offline
post #8 of 15 (permalink) Old 04-04-2006, 08:43 PM
SuperNewbie
supergordo's Avatar
The Stainless steel version is more rust resistant. If youre in a sunny and warm climate, an aluminized muffler would last for a real long time. My 94 bird has the original exhaust system on it, and its no where near the end of its service life.
But i seriously doubt youd notice any performance difference between the two.
supergordo is offline
post #9 of 15 (permalink) Old 04-04-2006, 10:25 PM
MN12 Fanatic
Tony's Avatar
Send a message via AIM to Tony Send a message via MSN to Tony Send a message via Yahoo to Tony
http://www.mn12performance.com/mn12-...st/exhaust.htm
Stock exhaust is restrictive and not the best for performance . It does it's job of keeping things quiet, which is what it was designed for.
No performance differance between a stainless and a aluminum muffler. Stainless is just more rust resistant than aluminum and it is pricey.
Sold - 1997 Ford Thunderbird 4.6 Sport - Full bolt on, PI stuff, gears, converter, exhaust, full suspension & many other things.
2007 MUSTANG GT (5M) - 504rwhp/449rwtq
- Paxton NOVI 2200 H.O. (10psi) - CMDP's - 127200 Comp Cams - BBK LT's - O/R X - FRPP GTA's - Mid Atlantic Tuned - FRPP 4.10's - Truetrac - Moser Axles - McLeod RST - Fidanza Steel FW - Eibach Pro Kit - J&M LCA's - UMI Relo. Brackets - Spohn Adj. PHB - Prothane Motor Mounts - Hawk HPS Pads - 19" Sport Edition KV5 Rims - Hankook Ventus V12 Evo Tires
Tony is offline
post #10 of 15 (permalink) Old 04-05-2006, 05:06 PM Thread Starter
Not sure what the resonator does but if I remove it and put lets say for example, a magnaflow SI/DO, tailpipes with tips, any problems without the res? What would sound be like?
KANGEL is offline
post #11 of 15 (permalink) Old 04-05-2006, 05:44 PM
Honestly your better off removing the 3rd so you have some room there too. If you put that muffler in there it would sound similar to mine. Look in the soundclips sticky at the top of this forum (exhaust) i have a quick clip i took of the sound.
-Matt-
post #12 of 15 (permalink) Old 04-06-2006, 05:36 PM
Lithsanatrex's Avatar
Send a message via MSN to Lithsanatrex
why not go with a magna DI/DO muff and run straights the rest of the way out? they have a really good sound to em. and if you wanta really mean sound you can always do cams and maybe some headers, that always makes em sound great
Lithsanatrex is offline
post #13 of 15 (permalink) Old 04-06-2006, 05:47 PM Thread Starter
So how would that work..a Y pipe after 3rd cat then into muffler?
KANGEL is offline
post #14 of 15 (permalink) Old 04-06-2006, 06:39 PM
cut everyhting out, cut off 3r cat back. run true duals all the way back with the muffler where the resonator use to be midbody. this seems to be the most popular setup for sound and prob preformance
post #15 of 15 (permalink) Old 04-08-2006, 06:36 PM Thread Starter
Thanks for your input gents!
KANGEL is offline
