Identifying Bad Cats - TCCoA Forums
post #1 of 17 (permalink) Old 04-05-2006, 02:27 PM Thread Starter
Send a message via Yahoo to thunder04
Question Identifying Bad Cats
How can you tell if you need new cats? Do you just wait until you don't pass smog?? lol
thunder04 is offline
post #2 of 17 (permalink) Old 04-05-2006, 03:07 PM
leet sauce
eg0r's Avatar
that is a good question
id like to know the answer to that as well
eg0r is offline
post #3 of 17 (permalink) Old 04-05-2006, 03:10 PM
Faster than Porkchop
cjchevez's Avatar
Mine got toast from a miss , they got red hot and then you could hear
the internals rattling.
But for them just going bad my guess is the performance would suck and you would fail the smog.
hope this helps.
1997 Ford Thunderbird 4.6 Sport .
60'...... 2.06
1/8th .. 9.194
mph .... 77.13
mods*
PI heads *PI intake*Mark VIII torque converter*Cobra T-loc w\4.10's * Jmod*tranny fluid cooler*P&P stock T/B & plenum*UD pulleys* Dynotech 4in ds*80mm Lightning maf*Xcal2*02 GT intake tube.
cjchevez is offline
post #4 of 17 (permalink) Old 04-05-2006, 03:42 PM
leet sauce
eg0r's Avatar
i thought its smog, mpg and performance
but its hard to judge if you drive car daily and get smog test done once 1-2years :S
im going soon tho so i guess that will tell me
eg0r is offline
post #5 of 17 (permalink) Old 04-05-2006, 03:50 PM Thread Starter
Yeah. I'm having trouble determining a problem with my car and wish there was an easy way to identify if the cats are my problem. I talked to my dad about the problem I am having and he doesn't seem to think that it would be the cats...but I don't know!! I could be running around checking things when it is in fact the cats!!!
post #6 of 17 (permalink) Old 04-05-2006, 09:06 PM
leet sauce
eg0r's Avatar
so can any1 answer this question?
or does any1 know what recomended cat replacement is?
thx
eg0r is offline
post #7 of 17 (permalink) Old 04-05-2006, 09:51 PM
cjchevez's Avatar
Man, sometimes it seems to me that there are veterans here that simply have heard the same questions 100 times and they just ignore them.
Just thought of something ,you could saw the exhaust before the cats to check if theres a diffrence .
But then you would have to welded them back.
60'...... 2.06
1/8th .. 9.194
mph .... 77.13
mods*
cjchevez is offline
post #8 of 17 (permalink) Old 04-05-2006, 10:33 PM Thread Starter
Yeah...sometimes I feel the same way here. I just wish I knew how to search better so us "newbies" don't seem so annoying. lol
post #9 of 17 (permalink) Old 04-05-2006, 10:54 PM
Sig Nazi & Gallery Moderator
mrs.tbirdbrain's Avatar
try this link - its about clogged cats:
http://forums.tccoa.com/showthread.p...ytic+converter
and here also:
http://forums.tccoa.com/showthread.p...hlight=clogged
TBIRDBRAIN - PRESTON
YOU WILL NEVER BE FORGOTTEN
4/22/63 - 4/23/14
RIP JOEL BENDER
07/30/1979 - 03/26/2006
mrs.tbirdbrain is offline
post #10 of 17 (permalink) Old 04-06-2006, 01:21 AM Thread Starter
Thanks for the info. I think I may need to replace 'em.
Which set on this page is the better set?: http://store.summitracing.com/compar...4294908395+115
post #11 of 17 (permalink) Old 04-06-2006, 08:44 AM
leet sauce
eg0r's Avatar
thx for articles
i didnt even think to search for that... :S
eg0r is offline
post #12 of 17 (permalink) Old 04-06-2006, 10:15 AM
a bad cat is when he pisses on the couch because you forgot to fill his bowl with food
Steve Cougar 25th is offline
post #13 of 17 (permalink) Old 04-06-2006, 02:39 PM Thread Starter
lmao!
post #14 of 17 (permalink) Old 04-06-2006, 11:31 PM
bad cats will usally smell...didint look at the links to see what they said, but thats what ive heard, that they make the exhoust smell bad or somthing..idk just my .02
86Fordtbird5.0 is offline
post #15 of 17 (permalink) Old 04-07-2006, 03:40 PM
Lithsanatrex's Avatar
Send a message via MSN to Lithsanatrex
just put set of new high flows on and call it done. easy!
Lithsanatrex is offline
post #16 of 17 (permalink) Old 04-11-2006, 09:37 AM
leet sauce
eg0r's Avatar
Lithsanatrex's 'easy' definition :
1. Waist your money on something you might NOT need.
2. Waist more money for welding shop to install something you might NOT need.
3. Waist 2 hours of your time driving to welding shop, back and wait for them to do the job for something you might NOT need.
4. Worry about emmission tests since you already have a modified exhaust after installation of something you might have NOT needed.
thx for help friend
but what im seeing so far from the posts and searching is that there is no way to easily check unless you are willing to smell your exhaust or buy a tool that will measure the airflow.
eg0r is offline
post #17 of 17 (permalink) Old 04-11-2006, 01:14 PM Thread Starter
To measure the exhaust pressure, I used an old, but very accurate, 0-15 PSI air tire gauge that was left over from when my dad used to race dirt stock, hacked apart an old O2 sensor, removed the gauge from the tire nozzle and clamped it to 10 feet of hose, clamping the hacked O2 sensor to the other end so I can screw the hose into the exhaust between the cat and the engine. Fired the car up and looked at the air pressure. Seemed to work extremely well. Of course, at first I didn't have the hose clamp on tight enough on the O2 sensor end, so it blew off and scared the hell out of me. OH **** WHAT'S THAT SOUND?!?!?! Ohhhh, hose blew off..ahahahahaha *change pants*
If I still have it (the gauge rig) laying around, I'll take pictures of it and post here.
