Magnaflow Cats!!! - TCCoA Forums
post #1 of 25 (permalink) Old 04-22-2006, 08:02 PM Thread Starter
Magnaflow Cats!!!
I am gonna have a custom exhaust done for my t-bird, will these cats fit down the side near the tranny?
http://www.completeexhaust.com/produ...roducts_id=179
p_mcnaught is offline
post #2 of 25 (permalink) Old 04-22-2006, 10:19 PM
don't see why not, i was gonna do the same thing
1993 3.8L Tbird----sold
1994 4.6L Tbird----sold
1995 Mark VIII----sold
2004 Mustang GT----sold
2003 Mach 1----current
smitty2919 is offline
post #3 of 25 (permalink) Old 04-22-2006, 11:37 PM
Fry Rice Specialist
Casper's Avatar
don't get it!!!
i have a pair brand new sitting in garage as of right now. too big to fit into our car. you can put it on but it'll scrap like bulldozer to the ground.
get those smaller round one instead.
CarDomain Page
Casper is offline
post #4 of 25 (permalink) Old 04-23-2006, 02:32 AM Thread Starter
Do you have a link to the smaller round ones?
post #5 of 25 (permalink) Old 04-23-2006, 09:49 PM
94thunderchicken's Avatar
heres some that will fit but they are kinda pricey http://store.summitracing.com/partde...5&autoview=sku if you can find a good high flow thats less than 4 1/2 in. round you should be on the safe side without any scraping.
94 lx : sold
94thunderchicken is offline
post #6 of 25 (permalink) Old 04-24-2006, 12:11 AM Thread Starter
So I could run cats that are like 5 1/8" wide and 4" Tall! I want to run the cats that are 2 1/2" In/Out!
post #7 of 25 (permalink) Old 04-24-2006, 12:36 AM
heres some that are a little cheaper but in the size of tubing you want that will fit http://store.summitracing.com/partde...5&autoview=sku hope this helps
94 lx : sold
post #8 of 25 (permalink) Old 04-24-2006, 12:39 AM Thread Starter
Thanks!
post #9 of 25 (permalink) Old 04-24-2006, 12:47 AM
catco is a pretty decent brand of cat, some may say they suck but overall its a good high-flow cat for the money, if you want to go with magnaflow's cat heres a decent proced one that will work also http://store.summitracing.com/partde...5&autoview=sku pretty much just depends on what brand you like better than others. the balls in your court
94 lx : sold
post #10 of 25 (permalink) Old 05-17-2006, 02:35 PM
mybird_91's Avatar
Send a message via Yahoo to mybird_91
go w/ the magnaflow. I have a true dual set-up. custom fittings may be nessessary to install but is worth it. (I spent $250 on my custom exaust, cats went out, spent $108 on two magnaflow cats, then $182 to install) F***ING EXPENSIVE, BUT WORTH EVERY PENNY!
mybird_91 is offline
post #11 of 25 (permalink) Old 05-30-2006, 11:13 PM
JL2K7388's Avatar
Send a message via AIM to JL2K7388
sorry to restart the thread again but whats the difference between two way converters and three way converters, bcuz i need to buy new cats to replace the front two on our car thanks
96 LX 3.8
Custom air intake, 9" K&N Cone, ASP underdrive pulleys, True Duals with DI/DO midmounted Magnaflow, ported upper and lower intakes, ported TB...and more to come
http://www.cardomain.com/ride/2385772
-Johnny-
JL2K7388 is offline
post #12 of 25 (permalink) Old 06-19-2006, 10:32 PM
How much would a average exhaust shop charge to weld high flow cats and cut off the crapy stock ones??
post #13 of 25 (permalink) Old 06-20-2006, 11:21 AM
Mod Motor Cat's Avatar
For your needs, I wouldn't even bother. You need an entire exhaust upgrade to keep up with the breathing capabilities of your AED. A couple of high-flow cats in that otherwise restrictive 2" exhaust system isn't going to make much of a difference.
~Brian~
*1990 Mustang Coupe, 5.4L*
Black on Black & Stroked 'n' Polked!!!
Mod Motor Cat is offline
post #14 of 25 (permalink) Old 06-20-2006, 03:16 PM
so gutted cats, pipe in its place?
post #15 of 25 (permalink) Old 06-20-2006, 03:18 PM
JL2K7388's Avatar
oxman you have the stock set up still?
96 LX 3.8
-Johnny-
JL2K7388 is offline
post #16 of 25 (permalink) Old 06-20-2006, 03:25 PM
No
Stock manifolds--> Stock cats---> true duel exhaust (2 1/4 inch?)-----Dynomax muffs
post #17 of 25 (permalink) Old 06-20-2006, 03:53 PM
JL2K7388's Avatar
oh okay so then yeah i would think high flow magnaflows would be good that or gutted cats im not sure which is better
96 LX 3.8
-Johnny-
JL2K7388 is offline
post #18 of 25 (permalink) Old 06-20-2006, 04:29 PM
I was thinking just pipes instead, but clamped on, so when i get tested just hook up the cats
post #19 of 25 (permalink) Old 06-20-2006, 05:13 PM
No
Ahhh, sorry Ox. I thought you still had the crummy little 2-1-2 sysem our cars came with.
~Brian~
post #20 of 25 (permalink) Old 06-20-2006, 05:53 PM
But what do you think, should i open it up alittle more? delete cats, and strait pipes in back??
post #21 of 25 (permalink) Old 06-20-2006, 08:17 PM
Only if you like it loud and stinky. If you swap out the stock cats for a set of high flow units, your set up won't flow all that bad as it is. As it is, the difference between high flow cats and no cats at all at this level is probably only about 3-5hp. By "strait pipes in back", I'm assuming you're thinking of deleting the Dynomax mufflers altogether? It will certainly get a lot louder if you do that, but for what your cars making for power, I don't imagine getting rid of your mufflers is going to help a whole lot on anything but the upper RPM.
The drone for daily driving use would drive me nuts personally.
~Brian~
post #22 of 25 (permalink) Old 06-20-2006, 08:25 PM
jk69cat's Avatar
nothing wrong with the full body mangaflow cats,
mn12 less!
jk69cat is offline
post #23 of 25 (permalink) Old 06-20-2006, 09:16 PM
I used to have strait pipes on my last t-bird, i like the loudness. As long as the pipes are past the bumper it shouldnt give me a headache at all. I'm taking the bird to a good exhaust shop next week, ill have some time to think about cats or not. Thanks for your help Brian.
post #24 of 25 (permalink) Old 06-20-2006, 10:02 PM
Why does one of them look brand new and the other look like its gotten really hot? Did one of them get crunched and have to be replaced or something?
~Brian~
post #25 of 25 (permalink) Old 06-21-2006, 08:25 AM
jk69cat's Avatar
becasue of the way they are postioned, and the one has the heat sheild positioned different than the other
mn12 less!
jk69cat is offline
