What change? - TCCoA Forums
post #1 of 7 (permalink) Old 05-08-2006, 03:52 PM Thread Starter
soundman502's Avatar
Red face What change?
Recently while looking under my car to find a rattle, I noticed that the section between my resonator and 3rd cat had been cut, and apparently slid back together and attatched with a cheap clamp. Well, the clamp isn't holding, and the whole rear exhaust system is just sliding like a sleeve at this section. I've been wanting to get a little better tone out of my otherwise stock exhaust. Will I hear any difference if I take both the 3rd cat and resonator off and just "straight pipe" that section? Thanks for the info
1996 Thunderbird LX 4.6L 147,000 mi.
Mods: Stock
1979 Ford Bronco Custom 5.8L Modified 188,000 mi.
http://www.cardomain.com/ride/2547728
soundman502 is offline
post #2 of 7 (permalink) Old 05-08-2006, 08:06 PM
yes you will notice a difference in tone but i highly recommend that you buy some good mufflers
BallerBird is offline
post #3 of 7 (permalink) Old 05-09-2006, 08:35 AM Thread Starter
I plan on good mufflers, at some point, but need the money first. When you say a difference in tone, do you mean higher, lower, smoother, raspier? I want to eliminate that section anyway when I do the new exhaust, but just want to make sure that until that time arrives, it won't sound like a ricer.
Mods: Stock
post #4 of 7 (permalink) Old 05-09-2006, 04:39 PM
cougar_ricer's Avatar
With a stock setup (2-1-2) and no muffs, resonator, or 3rd cat... it will be Louder and Drone a lot around 2000 rpm. With Mufflers it might deepen the tone (depends on brand of muffler)... quiet it down, and drone less. I have done this setup first hand. Drone doesnt sound too nice... makes your car sound like a damn rice burner on steroids.
Sold my Cougar . But I am in the market for another MN12 project!
cougar_ricer is offline
post #5 of 7 (permalink) Old 05-10-2006, 09:02 AM Thread Starter
Thanks a lot guys, I hope to get this leak fixed this weekend. Here's what the setup will be when I get done. The 2 foward cats into 1 pipe (eliminating the 3rd cat and res.) back to stock mufflers. Until someday, I can afford the better sounding ones. Hopefully I won't cause that droning, but I guess I'll keep everything in case it does.
Mods: Stock
post #6 of 7 (permalink) Old 05-10-2006, 02:29 PM
girdnerg's Avatar
I have read that using 3" for the 1 in the 2-1-2 setup is pretty close to true duals performance wise. So while you are replacing that section, you might want to go to the bigger size in the middle. I had no cats with the 2-1-2 and stock mufflers out back for a little while. Since the car came that way, I can't tell you the difference between it and the stock setup. I could at least hear the exhaust, which I can't imagine with 3 cats and 3 mufflers.
Might gain a little throttle response and the price difference should be small.
Rob
girdnerg is offline
post #7 of 7 (permalink) Old 05-11-2006, 04:43 PM Thread Starter
I've considered that exact thing, that instead of running 2.25 true duals, I could run one smaller, 3" single all the way back, and just be slightly smaller, but much increased airflow. Thanks for the input!
Mods: Stock
