What to do this the right way. - TCCoA Forums
post #1 of 12 (permalink) Old 05-10-2006, 02:50 PM Thread Starter
Awaiting E-Mail Confirmation
BIRD-OF-PREY's Avatar
I apologize it some one has already answered this but I couldn’t find the tread.
I want to cut off the 3rd cat on my 94 bird and add two pipes and new muff’s. Is there going to be an issue with passing my emissions without the 3rd cat? Thanks in advance
BIRD-OF-PREY is offline
post #2 of 12 (permalink) Old 05-10-2006, 03:50 PM
Lithsanatrex's Avatar
Send a message via MSN to Lithsanatrex
i think its a resonator( it is/was on all of my mn12's so far), you /shouldnt/ have any problems, but they may get onto you about noise. you pull that resonator off and it gets fairly loud fairly fast, and it will drone a good bit around the 1800~2400 mark so you had better get some good mufflers to remedy that
see this thread
http://forums.tccoa.com/showthread.php?t=83421
Lithsanatrex is offline
post #3 of 12 (permalink) Old 05-10-2006, 08:16 PM
Are u talking about removing the 3rd cat or resonator or both?? If you remove both you should still pass but it all depends on your states test ect.. I have duals with stock cats and i pass fine. Youll get somewhat louder with those 2 things off if you just take the resonator off it will be a little louder not much.
-Matt-
MattsLE97 is offline
post #4 of 12 (permalink) Old 05-11-2006, 04:07 PM Thread Starter
Both I guess, I will be completely honest and say I dont know what or where the resonator is. I konw there is two cats by the manifolds and then the "Y" pipe to another cat. My plan is to replace the Y with two pipes and muffs.
post #5 of 12 (permalink) Old 05-11-2006, 04:36 PM
ya then you will be replacing both the 3rd cat and resonator, if your car still has one its directly after the 3rd cat
-Matt-
post #6 of 12 (permalink) Old 05-15-2006, 02:43 PM Thread Starter
So If I rip them out and put in strait pipes and mufflers am I still going to pass emmisions?
post #7 of 12 (permalink) Old 05-15-2006, 03:05 PM
the resenator looks like a little muffler..about a foot from the third cat,,,if you remove it it will drone as i did it and also no mufflers..am going to put a center in.. center out.. flowmaster race muffler in place of the resenator ,, almost the same size as the resenator
C F I FLY is offline
post #8 of 12 (permalink) Old 05-15-2006, 03:45 PM
my resonator was about 18~24 inches long, and i didnt have any cats other than the 2 off the headers. i guess that must be a pre94 thing
post #9 of 12 (permalink) Old 05-24-2006, 10:19 AM Thread Starter
Ok what about side pipes, I saw on here someone had fake ones but what do you guys think is it possable?
post #10 of 12 (permalink) Old 05-24-2006, 11:28 AM
I thought about side pipes for a while, and yes it is possible but its not a good idea. You will probably scrape alot. I think there is somebody on here that used to have side pipes but the pipes kept getting ripped off so he ditched them.
post #11 of 12 (permalink) Old 05-24-2006, 12:18 PM
Resident Line Creator
th3subtl3on3's Avatar
Nope, thats a V6 thing.
-Brian
th3subtl3on3 is offline
post #12 of 12 (permalink) Old 05-28-2006, 02:25 PM
PCD
Confirmed V6 Nut
My V-6 has 3 cats, and it had a resonator, too. The resonator is gone. If I ever find some 2.5" downtubes that I can put on 2 high flow cats only, then I'll go 2.5" out to the mufflers. I'll have to add one muffler as I only have one now.
PCD is offline
