driver's side cat nut. - TCCoA Forums
post #1 of 7 (permalink) Old 05-16-2006, 10:22 PM Thread Starter
jesusraybrown's Avatar
OMFG I can't get this thing off! I've sprayed "PB as seen on tv PB Blaster" on it every day for three days, then heated it up with a tizorch. This MFer will NOT come off. Any suggestions, any previous experience with this?
1. This forum requires that you wait 30 seconds between sending private messages. Please try again in 266079416 seconds. wtf?
jesusraybrown is offline
post #2 of 7 (permalink) Old 05-16-2006, 11:11 PM
Lithsanatrex's Avatar
Send a message via MSN to Lithsanatrex
sawzall curezall
Lithsanatrex is offline
post #3 of 7 (permalink) Old 05-16-2006, 11:19 PM
jk69cat's Avatar
oxy and blow it off
mn12 less!
jk69cat is offline
post #4 of 7 (permalink) Old 05-16-2006, 11:52 PM Thread Starter
Originally Posted by jk89cat
oxy and blow it off
post #5 of 7 (permalink) Old 05-17-2006, 09:34 AM
jk69cat's Avatar
oxy/acetelne torch , cut it off
mn12 less!
jk69cat is offline
post #6 of 7 (permalink) Old 05-17-2006, 02:02 PM
Rolling-Thunder's Avatar
Dremel with right-angle drive attachment, plus approx. 1 1/4" dia. grinding disc.
Cut almost all the way thru one side of the nut, then split it the rest of the way with a flat blade screwdriver.
.....worked for me..........
Steve - TCCoA member
2003 Crown Vic LX Sport
Thanks for the ride !
Rolling-Thunder is offline
post #7 of 7 (permalink) Old 05-17-2006, 03:52 PM Thread Starter
thanx
