gutt cats or get high-flow - TCCoA Forums
post #1 of 15 (permalink) Old 05-26-2006, 03:48 PM Thread Starter
hello i was just wonderin if i gutted my cats if it would sound the same as high-flow cats.i would gutt them but i have to pass emissions.usally i dont get a visual test done when i get emissions..but if anyone could help me i would appreciate it
v8thunderbird is offline
post #2 of 15 (permalink) Old 05-26-2006, 05:05 PM
cougar_ricer's Avatar
No cats/gutted cats is more flow than a high flow cat... too much flow can result in some backpressure loss, but added HP ... I have gutted my cats... and minimal flow restrictions thru out entire exhaust system... not a "seat of your pants" change in torgue loss from my experience. Sounds hella good with no cats and a muffler mounted mid-body.
Sold my Cougar . But I am in the market for another MN12 project!
cougar_ricer is offline
post #3 of 15 (permalink) Old 05-26-2006, 10:10 PM
Refrigerator Raider Hater
GreenBird's Avatar
go with the high flow. You can pickup a pair of magnaflow carsounds for cheap. I got a pair of stainless 2.5" cats for less than $100 shipped.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #4 of 15 (permalink) Old 05-28-2006, 02:21 PM
PCD
Confirmed V6 Nut
Hey, any leads on where I can find some downtubes for my 97 so I can put the High Flow cats I've got sitting in boxes on? I want to go to a 2.5" system from the stocker 2".
Also wondering if I should go with a Y pipe or an H pipe with the 2 High Flow Cats? I've got no resonator, but a hacked up stock beyond the 3rd cat (which I'd like to dump.).
PCD is offline
post #5 of 15 (permalink) Old 05-28-2006, 04:53 PM
FordFanatic's Avatar
you'll have to hit up your local exhaust shop.
FordFanatic is offline
post #6 of 15 (permalink) Old 05-28-2006, 05:37 PM
PCD
Confirmed V6 Nut
FordFanatic,
All the shops here are chicken****s. They don't want to do more than replace the Ford cats with new Ford cats.
PCD is offline
post #7 of 15 (permalink) Old 05-28-2006, 05:47 PM
jk69cat's Avatar
dan, pull your y-pipe, tkae it to a shop, tell them that you want a custom pipe setup to repalce this, and here, use this as the pattern. its a federal thing, if they take a cat off a car they have to replace it with a cat. but if you bring in the component they should do it for you
mn12 less!
jk69cat is offline
post #8 of 15 (permalink) Old 05-28-2006, 06:51 PM
PCD
Confirmed V6 Nut
Justin,
Just take the stock setup, plus the cats I want to use and they'll make up what I want?
Oh, one of the high flow cats has provision for air injection. Can I just have that tube welded shut as my T-Bird doesn't have an air pump on it?
PCD is offline
post #9 of 15 (permalink) Old 05-29-2006, 12:17 PM
jk69cat's Avatar
yes, they should, its different if its off the car , but research the shops in your area. if not i have a guy i could get you to hook up with . but he's waay out here
mn12 less!
jk69cat is offline
post #10 of 15 (permalink) Old 05-29-2006, 07:03 PM
x182dan's Avatar
Send a message via AIM to x182dan
i wouldn't get crapsound cats. I had them on my custom setup and one started to rattle not a month after the install. So what happened was i ordered a new one and while i waited for the cat to come in the mail the rattling stopped and got clogged and blew the headgasket in my supercoupe. I am almost certain that the cat clogged and its the reason why my hgs blew
1995 Mustang GT(331stroker, trickflow heads, cam, intake, cobra seats, foose nitrous rims, 410s, etc)-your average slow sn95
2002 Ranger XLT(daily driver)
1994SC to 5.0 conversion(gone)
1990 SC-b&m shifter, SCP exhaust, ported exhaust manifolds, ported and polished heads, cold air intake, mark8 mafs(sold)
1989 Taurass SHO(sold)
x182dan is offline
post #11 of 15 (permalink) Old 05-29-2006, 07:14 PM
Traveler's Avatar
Pertaining to "gutted" cats. I've heard one T-bird with gutted cats. You could hear the resonance inside the cats. Sounded like two beehives under your floorboards. I wouldn't do that. I'd either replace the cats with straight pipe, or get high flow cats.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #12 of 15 (permalink) Old 05-29-2006, 07:37 PM
Just so you know, contrary to what some people believe, if you have high flow cats, there is no loss in flow as opposed to straight pipe of the same inlet and outlet diameter in its place. Having them there will not hurt your performance at all provided the entire exhaust is appropriately sized for the power you are making.
In my opinion, if you have to pass emissions inspection, it just isn't worth the hassle of not having the cats on there. The extra money you will have to lay out now to have the cats welded on will be saved next time you need to get inspected and you have to search for someone to slide you through, or have a stock exhaust put back on for inspection then swapped again afterwards.
Mike
post #13 of 15 (permalink) Old 05-29-2006, 07:40 PM
Traveler's Avatar
I agree Mike. If KS had a mandatory exhaust inspection I wouldn't even THINK of going catless. But since they don't..........
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #14 of 15 (permalink) Old 05-30-2006, 07:27 AM
leet sauce
eg0r's Avatar
btw does any1 know how much of a difference highflow cats make in the emission tests vs stock cats?
eg0r is offline
post #15 of 15 (permalink) Old 05-30-2006, 11:10 AM
none
