HELP. Removing True Duals - TCCoA Forums
post #1 of 4 (permalink) Old 05-27-2006, 04:49 PM Thread Starter
tbird462002's Avatar
Exclamation HELP. Removing True Duals
I'm trying to remove my exhaust so i can put my gp driveshaft in but i can get the pipes to come out of the muffler. Ive soaked it with pb blaster and wiggled the hell out of it but no luck yet. I really dont want to have to cut it but it just wont come out. The pipes were clamped never welded and will move aroud where they go into the muffler if you wiggle the exhaust.
Anyone have any ideas or tricks to get this thing apart. Need to have the car back together by monday so and advice or help would be greatly appreciated.
2.25 Mid-mount true dual exhaust,
K&N cone , 22c plugs , Magnecor 8.5 wires, Addco 1 3/8 swaybar, XCal 2 , 02 Gt maf,Vogtland Springs, Sport Fronts-Cobra Rears,RSTB, Auburn Pro w/3.73s, Steeda IRS Brace
tbird462002 is offline
post #2 of 4 (permalink) Old 05-28-2006, 01:32 AM
the whole exhaust should just drop down? you souldnt have to take the pipes out of the muffler.
97goldbird is offline
post #3 of 4 (permalink) Old 05-28-2006, 04:12 AM
I second that....
unbolt the system at the headers, remove the rubber thingies back at the
mufflers, the one at the pumpkin and then slide the system backwards
to clear the tranny mounts...
Be prepared to use your muscle when it drops though...
The system weighs a lot!
//Per
Thyg0d is offline
post #4 of 4 (permalink) Old 05-28-2006, 05:27 AM
I did this maybe 3 days ago, and the above advise is exactly what I used to remove it.
DMcBrideBoston is offline
