2way or 3way? - TCCoA Forums
post #1 of 6 (permalink) Old 06-02-2006, 02:15 PM Thread Starter
JL2K7388's Avatar
Send a message via AIM to JL2K7388
2way or 3way?
Hey i was wondering what is the difference between the two im assuming a 3 way cat has two inlets and one outlet but when i look at something like this
https://www.fulllineexhaust.com/cgi-...Converters.htm
it says its a 3 way but theres a single in and out, anyways to get to the point im replacing my front two cats will this be ok??
96 LX 3.8
Custom air intake, 9" K&N Cone, ASP underdrive pulleys, True Duals with DI/DO midmounted Magnaflow, ported upper and lower intakes, ported TB...and more to come
http://www.cardomain.com/ride/2385772
-Johnny-
JL2K7388 is offline
post #2 of 6 (permalink) Old 06-02-2006, 03:17 PM
2 way cats deal with carbon monoxide and hydrocarbons or volatile organic compounds (VOCs).
3 way cats deal with carbon monoxide, hydrocarbons or volatile organic compounds (VOCs) and NOx molecules.
Bangster is offline
post #3 of 6 (permalink) Old 06-02-2006, 04:28 PM
Get the 3-way. It will cut down on NOX emissions and it won't hurt anything else.
The 2-way or 3 way only refers to the gases that it converts. Basically a 3 way cat has 2 seperate catalysts inside it. First the gases pass over one that is identical to the 2 way cat, then they pass over another that reduces NOX.
Mike
post #4 of 6 (permalink) Old 06-02-2006, 04:58 PM Thread Starter
JL2K7388's Avatar
ohh got it thanks alot man
96 LX 3.8
-Johnny-
JL2K7388 is offline
post #5 of 6 (permalink) Old 06-03-2006, 10:55 AM
In short...
...3-ways are better than two ways...
post #6 of 6 (permalink) Old 06-07-2006, 06:19 PM
justin case's Avatar
2-ways contain platnum and palladium 3 ways have platnum palladium and rhodium
justin case is offline
