Broke Manifold Studs - TCCoA Forums
post #1 of 6 (permalink) Old 06-07-2006, 02:33 AM Thread Starter
While doing my PI swap I broke 3 of the manifold studs off; I used Liquid Wrench too!
What do I do next? Do I have to buy OEM studs or can I go to the auto parts store and get something?
krazy3o4 is offline
post #2 of 6 (permalink) Old 06-07-2006, 02:57 AM
Blindloser1080's Avatar
i personally would see if you have any type of a fasteners shop there. Take the bolts and they'll be able to get you something the exact same thread and size, plus they are much stronger in the 1st place!
Blindloser1080 is offline
post #3 of 6 (permalink) Old 07-02-2006, 06:26 PM
CougarXR/7's Avatar
Send a message via Yahoo to CougarXR/7
Bolts
Try your local Ace Hardware store.............our local store has everything from stainless to brass, hex head to cap screws, standard to metric. That's my choice to buy bolts.
To ALL my fellow Veterans......................Thanks!
U. S. Army 1971 - 1974
1980 Thunderbird - R.I.P.
1992 Super Coupe five speed
1990 35Th "Anni" Super Coupe automatic - R.I.P.
1994 Super Coupe five speed
1994 4.6 LX Thunderbird automatic - R.I.P.
1995 4.6 LX Thunderbird automatic - R.I.P.
CougarXR/7 is offline
post #4 of 6 (permalink) Old 07-02-2006, 11:19 PM
And while you're out, grab a can of PB Blaster and dump that Liquid Wrench. I've been able to get bolts and nuts loose with PB that I thought would have never even budged.
Jay
FordMan77 is offline
post #5 of 6 (permalink) Old 07-03-2006, 05:25 AM Thread Starter
Hey thanks guys, I fixed this problem last week. Cut the studs flush, drilled them out, tapped new (larger) hole, installed new studs; (.99 ea).....Problem Solved
krazy3o4 is offline
post #6 of 6 (permalink) Old 07-03-2006, 04:55 PM
Jay
I'm with fordman; the pb blaster works, just spray it the day before you want to work on it, and it comes off like it's new...
I took my exhaust off this spring, and didn't even bust a knuckle...
