supercoupe exhaust backpressure q's- how do I fix it? - TCCoA Forums
post #1 of 8 (permalink) Old 06-17-2006, 05:35 AM Thread Starter
The_Ghost's Avatar
Hi there, I just bought a 1990 Supercoupe 5-speed, kind of high mileage.
From what I understand, it appears that the stock SuperCoupe exhaust is extremely restrictive and the 15psi of backpressure it creates can cause headgasket failure.
My SC has 187 or 189k, I can't remember which, miles on it and it runs very smoothly, and feels quite strong. I've been babying it, as did the previous owner and have been shifting at 3k in an effort to make sure the headgaskets don't fail.
Since I am on a limited budget and since I have to go to Pick-Your-Part anyways, I want to know if I can't put the V8's duals on as a means by which to reduce backpressure while still remaining smog legal.
One, are the v8's duals usable cat-back on a 3.8SC?
Two, if the V8's duals are unusable, what is another cost-effective solution to the backpressure problem?
Three, are there any other junkyardable inexpensive items that can be added to extend engine life and promote reliability/durability?
Thanks very much!
The Ghost
96 Laser Red 4.6L - Custom
Custom Nascar-Inspired Bodykit - 55* Rear Spoiler - J-modded Trans - 80mm MAF - One-Off Diablosport Chipmaster Revolution Chip/Tune W/Toggle - ScanGaugeII Diagnostics & Data Readout - PBR Brakes - Drilled/Slotted Rotors - SC Wheels & Springs - Falken Tires - KYB GR-1 Shocks/Struts - FSTB - RSTB - RTLB - LECB - 60/40 Split Rear - SC Seats - SC Vac/Boost Gauge
The_Ghost is offline
post #2 of 8 (permalink) Old 06-17-2006, 09:54 AM
Traveler's Avatar
I can't really speak for the SC's, as I've never had one (not for lack of wanting to. You're lucky!) Anyway I don't think the V8's duals are any less restrictive than the SC's. I do know that a couple of company's make cat-back kits for the T-bird. Or you can go with a true dual system that has gained popularity here. It utilizes a dual in/dual out Magnaflow muffler. For pics you can go here.
http://www.tccoa.com/gallery/exhaust/index.html
Here are some shots of my Dual set up, it's a fairly common around here:
http://members.tccoa.com/traveler/exhaust.html
If you haven't already, you might go to www.sccoa.com and ask there (after doing a search). Those guys are as knowledgeable about the SC's as the folks here are about the T-bird in general!
And welcome to the club.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #3 of 8 (permalink) Old 06-17-2006, 10:02 AM
There is a resonator that causes a lot of backpressure it looks kinda like a muffeler and if you remove it or replace it that should help a lot. Ford put this there so you would loose 10 or so hp so the SC wouldn't be faster tnan the mustang. One thing to note the sound might be different.
1996 sport 4.6 130k and still strong.
1991 SC 3.8 project and toy.
ncoop23 is offline
post #4 of 8 (permalink) Old 06-17-2006, 10:10 AM
Traveler's Avatar
Yep, the Resonator is (was ) right where my Magnaflow muffler is now, except on the V8's it isn't a resonator, its a third Catalytic Converter.
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #5 of 8 (permalink) Old 06-17-2006, 03:02 PM
MN12 Fanatic
Tony's Avatar
Send a message via AIM to Tony Send a message via MSN to Tony Send a message via Yahoo to Tony
First of all you have a 90, so you have the old style gas tank. You will want to switch over to the 92+ tank if you plan on running any sort of true duals on it.
I highly doubt that a V8 exhaust would just bolt right up to an SC and fact is, they don't flow much better. All MN12's got the crappy bends and small piping. Stock exhausts on any MN12 is one big bottleneck....lol.
Here is an article I suggest reading through:
http://www.mn12performance.com/mn12-...st/exhaust.htm
I'd recommend going with some high flow cats and running some good piping from there back however you want it.
Here is a popular setup for the SC's:
http://www.supercoupeperformance.com...spx?PartID=145
It is pricey but, you could always print out a picture and take it to a local shop and have them mock something up for you.
Just some thoughts....
Sold - 1997 Ford Thunderbird 4.6 Sport - Full bolt on, PI stuff, gears, converter, exhaust, full suspension & many other things.
2007 MUSTANG GT (5M) - 504rwhp/449rwtq
- Paxton NOVI 2200 H.O. (10psi) - CMDP's - 127200 Comp Cams - BBK LT's - O/R X - FRPP GTA's - Mid Atlantic Tuned - FRPP 4.10's - Truetrac - Moser Axles - McLeod RST - Fidanza Steel FW - Eibach Pro Kit - J&M LCA's - UMI Relo. Brackets - Spohn Adj. PHB - Prothane Motor Mounts - Hawk HPS Pads - 19" Sport Edition KV5 Rims - Hankook Ventus V12 Evo Tires
Tony is offline
post #6 of 8 (permalink) Old 06-17-2006, 08:19 PM Thread Starter
The_Ghost's Avatar
I was thinking more along the lines of $100 or LESS to fix it.
post #7 of 8 (permalink) Old 06-17-2006, 09:42 PM
try removing that resonator it will also increase the life on your headgaskets keep it so that you can put it back though you might not like the sound but you will gain 10 or so hp from that. should cost very little and lower backpressure by a few pounds.
ncoop23 is offline
post #8 of 8 (permalink) Old 06-25-2006, 04:18 AM Thread Starter
The_Ghost's Avatar
gonna have the resonator yanked I think.
