Will shorty headers off 86-95 Mustang 302 fit? - TCCoA Forums
post #1 of 25 (permalink) Old 06-29-2006, 12:27 PM Thread Starter
Bradone's Avatar
Hello All,
1st time poster, recent TBird buyer. I have read most of the way through the postings on exhaust and have not seen this. In putting a Tbird shorty header next to a Mustang shorty header from JBA the main difference I saw was The TBird has 2.25 collector instead of a 2.5. This to me is a rather large advantage. I realize the human eye cannot tell. I wonder if anyone has put the Mustang shorty's on a 5.0 Tbird?
So much to absorb. so much to do.
Thanks for the help
Brad
Bradone is offline
post #2 of 25 (permalink) Old 06-29-2006, 12:51 PM
MaddMartigan's Avatar
Originally Posted by Bradone
Hello All,
Thanks for the help
Brad
Nope, unfortunately they won't. There are currently only two choice for headers for the 5.0 MN12 and they are from JBA and Mac. Neither are great for performance since they are a stock replacement.
1992 Ford Thunderbird SC
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.27 gears
Custom aluminum driveshaft
M5R2
Burned Chip for SN95 T4M0 ECM
OMGHI2U
MaddMartigan is offline
post #3 of 25 (permalink) Old 06-29-2006, 01:27 PM Thread Starter
Bradone's Avatar
So is there enough advantage to make it worth it. Those exhaust look awfully restrictive. Thanks for your quick reply.
Brad
Bradone is offline
post #4 of 25 (permalink) Old 06-29-2006, 07:17 PM
Brad
Sure, both will help. The JBA part is a better made part but is more restrictive because of it's heavier materials. However, if you put those on and replace the rest of the exhaust with something far less restrictive then it will help a good bit on your 5.0.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #5 of 25 (permalink) Old 06-29-2006, 08:25 PM
theres always porting
NiteFire is offline
post #6 of 25 (permalink) Old 06-29-2006, 08:37 PM
Porting of what? The stock headers on the 5.0 MN12's are indeed headers. They aren't cast iron manifolds so there is no real port of them. The aftermarket headers are also just steel tubing so I'm not so sure there is any porting that you could do that would accomplish anything there either.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #7 of 25 (permalink) Old 07-01-2006, 12:54 AM
cloud2or3's Avatar
We Outta Luck Bro...
I'm in the same boat right now. JBA apparently were the only ones that were worth considering and the are no longer in production.
We screwed...
EDIT: I'm almost at the point where im wishing I knew somewone who could make some CUSTOM??? hmmm theres an idea>>>>
- 1991 Mercury Cougar XR7 5.0L -
- Black Leather on Wine Metallic -
- So Far... 18" Mac Rims -
- Alpine Mp3 Player -
cloud2or3 is offline
post #8 of 25 (permalink) Old 07-01-2006, 07:17 AM
We screwed...
Well, if you are into doing things custom, I've been there and done that. Check out the 5.0/5.8 forum for a thread that talks about installing long tubes.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #9 of 25 (permalink) Old 10-04-2006, 09:46 AM
5oh Transformer
ZeroRain's Avatar
Send a message via AIM to ZeroRain
cam i ask whats stopping shortys from being installed?
1996 Ford Thunderbird LX EFI Swapped 311 5spd "TT 5oh project"
1998 Ford Taurus SE 24v Duratec auto "DD"
1966 Ford Galaxy 500 352 Cruise-O-Matic "Restoration Car"
We don't just dream about fast toys, we build them!
ZeroRain is offline
post #10 of 25 (permalink) Old 10-04-2006, 10:31 AM
tbirdtess's Avatar
Clearance Needed
~~Hello
You will need to move the steering shaft to clear the Mustang Exaust manifolds.
There is a listing showing this modification.
Paul
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #11 of 25 (permalink) Old 10-04-2006, 10:41 AM
5oh Transformer
ZeroRain's Avatar
alright tess i will do a search and see. but besides that they will fit?
ZeroRain is offline
post #12 of 25 (permalink) Old 10-04-2006, 12:54 PM
They won't be plug and play for sure. You will have to create custom downtubes. Now you may be able to work that out without relocating the steering shaft but there is no guarantee. If you look in the 5.0 Forum, there is a sticky there for putting long tubes on that are from a 86-93 Mustang automatic. Check that out.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #13 of 25 (permalink) Old 10-04-2006, 01:25 PM
5oh Transformer
ZeroRain's Avatar
im gonna have to. im not sure how i want to go jyst yet but it will have to open headers no matter what on the drive to the muffler shop.... or the tow
ZeroRain is offline
post #14 of 25 (permalink) Old 10-05-2006, 10:48 AM
TSTaCC President
Bob Kinee's Avatar
Send a message via AIM to Bob Kinee Send a message via MSN to Bob Kinee Send a message via Yahoo to Bob Kinee Send a message via Skype™ to Bob Kinee
You can always get one of those "build your own headers" kits out from Jegs or Summit. I have never done it myself but it seems like a way that could work if you got the pipes to go around the shaft, and have a buddy who can weld.
(2)93 lx 5.0s BOTH sunrise red
Double the pinkiness!
President of the Tri-State ThunderBird and Cougar Club
www.TSTaCC.com
Bob Kinee is offline
post #15 of 25 (permalink) Old 10-05-2006, 11:14 AM
Mark M. TCCoA VP's Avatar
sounds like someone around here needs to make up/alter some good large headers to fit these cars and sell them at a profit. There seems to be more and more pushrod guys doing things with the MN12s. I would like to see 1 3/4" (302 and 351) long tubes that fit and don't require messing with the steering shaft.
"Mark M. TCCoA VP. Emeritus"
To the Batmobile ! ! !
ADDCO MN12 big bar R&D guru
Mark M. TCCoA VP is offline
post #16 of 25 (permalink) Old 10-05-2006, 11:20 AM
FordFanatic's Avatar
they did that on the show muscle car on the power block. didnt look all that bad as long as you have some tools, time and skill.
FordFanatic is offline
post #17 of 25 (permalink) Old 10-05-2006, 11:35 AM
dode's Avatar
If only I had the time....
I did look into this a couple of years ago, but people balked at paying $500 plus for headers.
John
1997 Mercury Cougar XR7
1992 Thunderbird GT 5.0L
dode is offline
post #18 of 25 (permalink) Old 10-05-2006, 11:44 AM
why? the kooks headers cost more than that.
post #19 of 25 (permalink) Old 10-05-2006, 11:46 AM
$500 is a damn good price for pulg and play headers for a pushrod MN12. Long tubes with the O2 bungs and maybe a wide band bung and a 3.5" collector. They could support 500hp.
post #20 of 25 (permalink) Old 10-05-2006, 12:07 PM
dode's Avatar
well...notice there was a plus...it would totally depend on coating, size, etc.
John
dode is offline
post #21 of 25 (permalink) Old 10-05-2006, 12:11 PM
5oh Transformer
ZeroRain's Avatar
im gonna check into the build own headers idea
ZeroRain is offline
post #22 of 25 (permalink) Old 10-05-2006, 12:37 PM
tbirdbrain's Avatar
We do at least know who can coat them if anyone makes them
tbirdbrain is offline
post #23 of 25 (permalink) Old 10-05-2006, 12:40 PM
No comment.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #24 of 25 (permalink) Old 05-21-2007, 10:38 AM
I know I'm bringing up an old post, but would the headers fit if you raised the engine via shimming the motor mounts?
bakerrm is offline
post #25 of 25 (permalink) Old 05-21-2007, 11:09 AM
tbirdbrain's Avatar
In a word, no.
