4.6l longtubes - TCCoA Forums
post #1 of 23 (permalink) Old 07-04-2006, 04:44 PM Thread Starter
4.6l longtubes
Has anyone used or modified a set of 2v mustang long tubes for the mn12 cars. What needs to be done to get this to work?
teal944.6 is offline
post #2 of 23 (permalink) Old 07-04-2006, 06:08 PM
I think you'd be better off getting a set of kooks mid-lengths and extending them. Probably would be less work since you would already be past the steering shaft where you start modifying them. That's what I plan on doing for my DOHC swap.
Mike
post #3 of 23 (permalink) Old 07-04-2006, 06:38 PM
CobraRThunder's Avatar
or kooks could have made them long tubes in the first place......
4R70W From DirtyDog
CobraRThunder is offline
post #4 of 23 (permalink) Old 07-10-2006, 09:37 PM
TGJ
Baddest N/A NPI in Canada
TGJ's Avatar
What is wrong with the 1&3/4" Primaries, 3" Collector KOOKS headers? From my understanding you won't gain anything with LTs over them.
TGJ is offline
post #5 of 23 (permalink) Old 07-10-2006, 09:52 PM Thread Starter
I was trying to get away from having to drop 700$ for the set. Mustang headers are much more reasonable. But they are the ones i will probable go with
post #6 of 23 (permalink) Old 07-10-2006, 09:57 PM
The Great Obucina's Avatar
you wont be able to run the stang longtubes, you wont have the ground clearance, they will hit the starter, wont clear the steeringg shaft and you will have to find a way to route theeee EGR, since its on the opposite side as the mustang.
"Booyah". Stu Scott.
The Great Obucina is offline
post #7 of 23 (permalink) Old 07-10-2006, 10:04 PM
Simple solution....delete the EGR.
4R70W From DirtyDog
post #8 of 23 (permalink) Old 07-10-2006, 10:06 PM
and deleting it will do what for you?
post #9 of 23 (permalink) Old 07-10-2006, 10:08 PM
you wont need to fiddle with fabbing a EGR tube for a custom mustang long tubes install. And you save a few pounds.
4R70W From DirtyDog
post #10 of 23 (permalink) Old 07-11-2006, 11:28 AM
This is where you are wrong. The mid-length headers will flow well, however the concept behind long-tube headers is that the way the hot gases are being sent out, they actually create a vacuum in one primary tube when the valve opens. The longer the primary tubes, the lower the rpm this occurs at. The mid-length headers will not have this effect until such ridiculously high rpms that no street engine, and few race engines will ever see that high. And no matter how well something flows, it will never be as good as evacuating the exhaust as a tube that has a vacuum pulled on it. Mid-length and shorty style headers are popular for one reason and only one reason, they are easier to install. You will never get the same gains with mid-lengths as you will with equal length long-tubes. The question is whether the performance gain that you will get is worth the extra cost involved in fitting them into the car.
Mike
post #11 of 23 (permalink) Old 07-11-2006, 11:40 AM
Send a message via AIM to Runner383 Send a message via MSN to Runner383 Send a message via Yahoo to Runner383
But you need backpressure dammit, 4.6s need backpressure!!!!!!!!!!
"Piss poor planning on your part does not constitute an emergency on my part.
Runner383 is offline
post #12 of 23 (permalink) Old 07-11-2006, 03:49 PM
Lies! No motor ever made will benefit from backpressure in the exhaust. The only time opening up the exhaust will hurt you is if you have a turbo, and even then, it will only hurt if you open it up before the turbo and open it larger than the turbo inlet diameter.
Mike
post #13 of 23 (permalink) Old 07-11-2006, 09:53 PM Thread Starter
This is generally why long tubes make more power. I think what i'll do is bite the bullet and get the 1 3/4 to 3" collector and have extensions made to have true long tubes.
post #14 of 23 (permalink) Old 07-12-2006, 11:17 AM
That's what I plan on doing.
Mike
post #15 of 23 (permalink) Old 07-13-2006, 09:08 AM
Mike
That was just a bit of sarcasm on my part. I have read that argument about "the engine needs backpressure" way too many times here. There were a few folks that would always try to convince me I didnt understand that you need backpressure for torque. Thats why I used 2.5 inch true duals on a stock engine. I overbuilt the exhaust for future mods, but the car didnt make it. I know that all it does is restrict your flow, people seem to forget that you need exhaust velocity as well as good flow.
post #16 of 23 (permalink) Old 02-20-2007, 07:05 PM
MaleWhore
smokymance's Avatar
what performance gains are expected from stock manifolds to the 3/4s headers? how about if i have an SC....
smokymance is offline
post #17 of 23 (permalink) Old 02-20-2007, 07:18 PM
twin turbo 281's Avatar
you need exhaust velocity to scavenge the chambers not backpressure. When you go to big of pipe and you lose performance its not because of backpressure its because of the loss of velocity. Gases travel faster down a smaller pipe just as when you pinch a garden hose the water flows faster which helps pull the spent charge from the ports
2x95 cougars to the scapper
51 Mack A51T restoration
twin turbo 281 is offline
post #18 of 23 (permalink) Old 02-20-2007, 07:40 PM
PostSkank
StupidFly's Avatar
which is why there's a balance to be struck, and why bigger is not neccesarily better. And also another reason ceramic coating is helpful.
math > pasta
StupidFly is offline
post #19 of 23 (permalink) Old 02-20-2007, 08:10 PM
yep because unlike water thou the hotter the gases the faster they travel
post #20 of 23 (permalink) Old 03-14-2007, 11:59 PM
shaken, not stirred
stangboy7's Avatar
One question i have though, how much will it hurt the performance to get 2 1/2" on a completely stock engine? I plan on adding mods in the next year, but right now it is stock.
C.Hill
'97 Laser Red T-bird w/ Option 66S - 125,000 miles, stock except for 3.73s Best ET 15.6 @ 88.3
'94 Electric Red T-bird LX V-8- 212,000 miles- SOLD
2005 Ebony Black Excursion Limited 6.0 Diesel STUDDED
"Thinking is the hardest work there is, which is the probable reason so few engage in it."
- Henry Ford
"Opportunity is missed by most people because it is dressed in overalls and looks like work."
- Thomas A. Edison
http://www.tailofthedragon.com <---- A test of driving ability and nerves.
stangboy7 is offline
post #21 of 23 (permalink) Old 03-15-2007, 01:24 AM
It won't hurt at all. You need to be pretty darn wild (much farther than N/A) to be needing more than 2.5" piping.
post #22 of 23 (permalink) Old 03-15-2007, 02:00 AM
shaken, not stirred
stangboy7's Avatar
I wasn't planning on going bigger than 2.5" I just didn't want to use 2.25" and then later have to redo it with 2.5" pipes when i do a tune, exploder motor and so on. Just curious if anyone noticed any negative affects using 2.5" on a stock motor compared to 2.25".
C.Hill
- Henry Ford
- Thomas A. Edison
post #23 of 23 (permalink) Old 03-15-2007, 02:12 AM
You might lose a little bit of lower-end torque due to less exhaust scavenging with the stock motor, but upgrading later would probably eliminate that. 2.25" is plenty for a stock motor with minor mods. In fact, as long as the factory exhaust manifolds are on there, it's a waste to go bigger than 2.25". Put some headers and better heads, cam, intake, then you'll reap the benefits of the upgraded exhaust. But if you are planning on doing bigger stuff later, going with 2.5" won't be a bad idea.
