Full custom 2 1/2 - TCCoA Forums
post #1 of 17 (permalink) Old 07-21-2006, 05:21 AM Thread Starter
Full custom 2 1/2
Im getting ready to do a full custom 2 1/2 inch exshaust set up. Ill start with jba cat4ward headers then into a full true dual 2 1/2 to the rear finish with a rear mounted flowmaster 40series deltas . IM just wondering if anyone has done this or has attempted and any problems or issues i need to be aware of.
TroyN is offline
post #2 of 17 (permalink) Old 07-21-2006, 06:56 AM
tbirdbrain's Avatar
My gripe is that I have drone. It gets old after a while on the road but otherwise it sounds great..
tbirdbrain is offline
post #3 of 17 (permalink) Old 07-21-2006, 10:17 AM
hey that's what I have on mine!! I loved the way it sounded! The bad thing is that you can see the mufflers pretty good! My brother's kinda got the same thing without the headers and it has a nice growl to it. He left the cat's on it and took out the resonator!
97qwikcat is offline
post #4 of 17 (permalink) Old 07-22-2006, 01:08 AM Thread Starter
im not doing it for the sound guys... i need the 2 1/2 for preformance issues with my plans for a 500ponie bird. IM just looking for problems with the headers or clearance or what not.
TroyN is offline
post #5 of 17 (permalink) Old 07-22-2006, 11:19 AM
Ditch the JBA's and Flow Masters. Stock manifolds will flow as well as the JBGays and won't crack. If you need more performance, Kooks are the way to go. Flows drone in the T-Bird applications. I went with a midmount Magnaflow setup, it drones a little @ low RPM, but not nearly as bad as the Flows I've heard.
Eric Z. is offline
post #6 of 17 (permalink) Old 07-22-2006, 11:23 AM
tbirdbrain's Avatar
Not on a 5.0 and kooks aren't made for them.
post #7 of 17 (permalink) Old 07-22-2006, 02:51 PM
Bah..... I need to pay better attention.
Regardless of th manifold/header I would go with a midmount muffler setup vs. rear mount.
Eric Z. is offline
post #8 of 17 (permalink) Old 07-25-2006, 06:03 PM Thread Starter
well i talked to my muffler shop today and they said i cant run true duals on the basis of where my gass tank is, is this correct cause ive looked around and seen others with duals
TroyN is offline
post #9 of 17 (permalink) Old 07-25-2006, 07:35 PM
Bradone's Avatar
Lot's of good shots on here. Done all the time. My shop is going to run 2.5's for me.
Brad
[email protected] (engine/trans is stock)
Bradone is offline
post #10 of 17 (permalink) Old 07-25-2006, 07:41 PM
Bradone's Avatar
Just a followup, I sent my shop this link:
http://forums.tccoa.com/showthread.php?t=85069
It is RaceCougars setup.
Brad
Bradone is offline
post #11 of 17 (permalink) Old 07-25-2006, 07:46 PM
Bradone's Avatar
You may want to look at this also. I got my JBA's earlier than I intended due to a post by Lonnie. There are also post for getting through long tube installs aswell. I am not going for 500 hp so the JBA'S will work for me but they are small and expensive!
http://forums.tccoa.com/showthread.php?t=86807
Brad
Bradone is offline
post #12 of 17 (permalink) Old 07-26-2006, 05:18 AM Thread Starter
ill print that pick out and show them and as for the jbas i got mine aswell, well ive ordered them.. if these rumors are true then maybe ill have an oportunity to get long tubes but i think i can get 500hp through a full 2 1/2 in exshaust system it will only be 2 1/4 from headers to cats due to the jbas then 2 1/2 back
TroyN is offline
post #13 of 17 (permalink) Old 07-28-2006, 11:03 AM
dugweed's Avatar
Send a message via AIM to dugweed Send a message via Yahoo to dugweed
it can be done
make sure they put this in too, ease of trans removal
I've got Magnaflows and dont have a drone.
Mike
2009 Harley-Davidson Road Glide
1996 F350 CCLB 7.3 5 speed 4x4
dugweed is offline
post #14 of 17 (permalink) Old 07-29-2006, 02:26 PM
mark007's Avatar
magnaflow imho are the best performer out there for not having the dreaded drone at 1900-2200 rpm range. and they really arent that loud until you mash the go pedal and go wot.
mark007 is offline
post #15 of 17 (permalink) Old 07-29-2006, 08:02 PM
I noticed TroyN's Bird is a '91. Isn't there an issue with early fuel tanks having a different design that made doing duals tough, or was that from pre-91? I can't remember when the change happened. Sucks getting old...
Blown306 is offline
post #16 of 17 (permalink) Old 07-29-2006, 08:11 PM
Who is John Galt?
I think it was up until 91. The Dynomax and Flowmaster cat-backs list 92-97. Not 89-91.
"Won't work, can't be done"
cougar_guy04 is offline
post #17 of 17 (permalink) Old 07-31-2006, 09:40 AM
Back in Black
ShadowDragon's Avatar
So swap the gastank and heat shield with a 92-97.
ShadowDragon is offline
