gutting the cats ??? - TCCoA Forums
post #1 of 8 (permalink) Old 07-23-2006, 07:19 PM Thread Starter
i have my 3rd cat gutted. i was just wondering, if i gut the other 2 cats, will it help with performance ? also, would it cause the cel light to come on ? has anyone else tried this, and did it help the power any or cause any problems ?
95bird4.6 is offline
post #2 of 8 (permalink) Old 07-23-2006, 09:24 PM
Amateur Expert
Embalmer's Avatar
Send a message via AIM to Embalmer
I recently had my cats removed on my headswapped '97 because one of them melted and blocked the pipe. You need MIL eliminators or a tune to remove the check engine light you will get from having no catalyst. Yes, they also helped performance in my case.
2007 Ford Mustang GT Premium - SOLD March 2014.
2013 Ford Taurus SHO (TUXESHO) Tuxedo Black Bone stock for now.
Embalmer is offline
post #3 of 8 (permalink) Old 07-23-2006, 10:21 PM
CobraRThunder's Avatar
dont gut the other cats. it will sound like fire crackers going off in a coffe can. the cat housings aren't as thick as the rest of the exhaust. So the exhaust sound echos and pings.
4R70W From DirtyDog
CobraRThunder is offline
post #4 of 8 (permalink) Old 07-23-2006, 11:28 PM
3rd Gear Chirper
hotbird's Avatar
I have gutted cats with only a foot of pipe behind them on each side, straight pipes in other words. Sound good, but it does have that "ticking" sound to it, maybe some glasspacks will remove that ticking??
Performance, I'd say maybe it helps in the top end just a little bit, but I can't tell for sure.
hotbird is offline
post #5 of 8 (permalink) Old 07-24-2006, 07:28 AM
You'll lose some low end. Plus it will sound like a truck IMO.
Adam B. is offline
post #6 of 8 (permalink) Old 07-24-2006, 08:06 AM
leet sauce
eg0r's Avatar
if you gut the cats you might have issues passing emission testing
cel light will come on as others told you
id recomment getting highflow cats instad
eg0r is offline
post #7 of 8 (permalink) Old 07-24-2006, 08:46 AM Thread Starter
thanks for all the input here guys. we dont have emmision testing here on 1995 or older cars anymore, but i dont think i want that pinging and popping noise and i dont want to hurt the bottom end. anyone know how much high flow front cats cost ? is any brand better than another ?
also, are the high flow cats going to help ? or would i be best just to leave it like it is ?
post #8 of 8 (permalink) Old 07-24-2006, 09:14 AM
Personally unless they are bad or you're building up your exhaust for future upgrades, I would leave them on and forget about them.
Adam B. is offline
