Does a converter effect the hc emissions? - TCCoA Forums
post #1 of 11 (permalink) Old 07-29-2006, 06:11 PM Thread Starter
Our '96 v-8 t-bird failed an emission test today. The HC was 53ppm,two and three years ago it was only 24 and 10ppm.The NO was 9ppm three years ago,two years ago it was 186ppm.Today,the NO was 244ppm (max is 409).We did have to gut one pre-cat due to it self destructing when a broken vacuum line caused several cylinders to lean misfire,which led to raw fuel igniting in the cats (and doing a meltdown).The vacuum line may have been an increasing hidden leak for several years before the big breakaway.Today's failed test seems not related to a gutted cat because cats are supposed to control NO more than anything else,right?The car currently has MSD ign wires,new plugs,clean air filter,new fuel filter,Dynomax dual exhaust,no vacuum leaks,and all original maf and oxy sensors. Fuel mileage around town is poor,averaging 13 to 14,but freeway mileage goes up to about 23mpg. I am thinking (guessing) that if the oxy sensors are "slow" maybe that degrades city mileage,wastes fuel and raises HC levels.What do you guys think? Also,would cleaning the maf have an emissions advantage?The car starts easily,has pretty good power,does not show a check eng light,and has no stored codes.I would like fix the problem and pass with a large margin.I've got four weeks until current registration expires.Every good tip would be very appreciated!
edman is offline
post #2 of 11 (permalink) Old 07-29-2006, 10:57 PM
Refrigerator Raider Hater
GreenBird's Avatar
RE: Does a converter effect the hc emissions?
In a word, yes.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #3 of 11 (permalink) Old 08-01-2006, 04:00 AM
no it isn't for just NO... its for everything. This is taken directly from how stuff works.com
A catalytic converter is a device that uses a catalyst to convert three harmful compounds in car exhaust into harmless compounds.
The three harmful compounds are:
Hydrocarbons (in the form of unburned gasoline)
Carbon monoxide (formed by the combustion of gasoline)
Nitrogen oxides (created when the heat in the engine forces nitrogen in the air to combine with oxygen)
Carbon monoxide is a poison for any air-breathing animal. Nitrogen oxides lead to smog and acid rain, and hydrocarbons produce smog.
In a catalytic converter, the catalyst (in the form of platinum and palladium) is coated onto a ceramic honeycomb or ceramic beads that are housed in a muffler-like package attached to the exhaust pipe. The catalyst helps to convert carbon monoxide into carbon dioxide. It converts the hydrocarbons into carbon dioxide and water. It also converts the nitrogen oxides back into nitrogen and oxygen.
It sounds to me like your other cats are going bad on you.
FunktasticLucky is offline
post #4 of 11 (permalink) Old 08-01-2006, 05:58 AM
Moved to Exhaust.
post #5 of 11 (permalink) Old 08-14-2006, 12:16 AM Thread Starter
Thanks! Yes, I got the info now too. If I could just get a source for good condition used cats we would be home free! Believe it or not, re-certified used cats are legal in Cal, but they still cost about $500 a set outright. A few months ago, I sent Summit back a Catco system (not legal in cal) due to severe bad fitup. The only system that seems to fit is a Ford factory setup. All the local wrecking yards have to cut thru the systems before cars enter the yard, and they can't legally sell a used set either. It looks like a big snafu for me.
edman is offline
post #6 of 11 (permalink) Old 08-14-2006, 12:25 PM
wilson502's Avatar
yep california is ghey. Stupid emission laws....
2007 White Ford Focus SE ZX3 Hatchback (The new driver)
1997 Alpine Green 4.6L Bird (SOLD!)
Mods:
Removed Air silencer, Clear Corners, Silverstar headlights and corner lights, Moroso Bluemax Spiral Core wires, Custom 3" Magnaflow exhaust with 2.5" Y-Pipe, 300-450 HP J-mod Kit by dirtyd0g , Hayden 30k GVWR Trans Cooler, Sport Front Suspension, 03-04 Cobra Rear Shocks, PBR Front Brake Swap, Xcal 2 by Lonnie @ Blueovalchips.com, 22C plugs, 180F T-stat, 02GT MAF/Airbox with K&N Drop in, Griffin Radiator, Cobra Water Pump
wilson502 is offline
post #7 of 11 (permalink) Old 08-14-2006, 12:47 PM
Faster than Porkchop
cjchevez's Avatar
I paid 650 for my refurb cats , and I got the you got raped stuff from people .
looks like prices are coming down . lol
1997 Ford Thunderbird 4.6 Sport .
60'...... 2.06
1/8th .. 9.194
mph .... 77.13
mods*
PI heads *PI intake*Mark VIII torque converter*Cobra T-loc w\4.10's * Jmod*tranny fluid cooler*P&P stock T/B & plenum*UD pulleys* Dynotech 4in ds*80mm Lightning maf*Xcal2*02 GT intake tube.
cjchevez is offline
post #8 of 11 (permalink) Old 08-14-2006, 08:30 PM
A couple years ago there wasn't any place that was selling used cats (OBDII compliant) for my T-Bird. At the time, my Dad owned the car and the cats went out. He went to get them replaced and he was told that the only way to pass was to get genuine OEM replacement cats. So he went the Ford route and paid a nice $980 for the 3-cat Y-pipe assembly, and then $75 for an install. All I can say is...ouch!
post #9 of 11 (permalink) Old 08-15-2006, 08:34 PM
kermit's Avatar
Send a message via Yahoo to kermit
you could always go to the for sale forum. i think a while back i saw somebody had exhaust components in there for sale. get a set from somebody doing a no cat conversion?
just a thought.
jamie
Jamie
'96 Thunderbird LX 4.6L
'07 Eddie Bauer Explorer 4.6L 3v
'06 Mustang GT 4.6L 3v 5 spd
"10 in the tank, 4 on the floor"
kermit is offline
post #10 of 11 (permalink) Old 12-11-2006, 11:44 PM
cats - cheaper wishbone
Just replaced my wishbone with 3 cats.
If you have a connection, you can get all 3 replaced for about 400.
Tip: exhaust pipes are extremely rigid; if you want a good seal, have your cats rebuilt, not get someone else's that might be off just a little. No amount of cranking on bolts will eliminate the HOG sound.
chicabee is offline
post #11 of 11 (permalink) Old 12-18-2006, 10:42 PM
twin turbo 281's Avatar
try replacing the O2s first i would try that. Ive had cars that had exessive emmissions and i just changed the O2 sensor and passed with outstanding low emissions...but cali is strict so the cats may be holding you back. I would just pop some new O2s on then take it thru a test...then if it still fails get new cats! If you get just new cats without replacing the O2s you could still fail.
2x95 cougars to the scapper
51 Mack A51T restoration
twin turbo 281 is offline
