Any LT's available for 5L? - TCCoA Forums
post #1 of 21 (permalink) Old 08-07-2006, 08:32 PM Thread Starter
Hate the idea of shorties and want some LT's. Anyone have LT's installed without any major work?
905LTB is offline
post #2 of 21 (permalink) Old 08-07-2006, 11:55 PM
No. Please try a search
weswing04 is offline
post #3 of 21 (permalink) Old 08-08-2006, 10:32 AM
bad93bird's Avatar
It takes some major work. No long tubes are made for out cars. You'll have to ask Madmartigan and some other people on here what they did to make them work. Some have to beat their floor pans in and some have to bend the headers. You will have to redo the steering linkage! That is a given. That's why I haven't gone with long tubes. Too much work. Later!
QUADSQUAD MEMBER
bad93bird is offline
post #4 of 21 (permalink) Old 08-08-2006, 02:56 PM
I put long tubes in.
It was a b1tch.
I am also running a 5.8l and a C6....so things were even tighter fitting for me.
The passenger side went in with some ease(easier then the drivers side), but the driver's side....thats where the fun began.
The biggest problem I had was my tranny linkage, not only did I have to bend it, but I had to bend the header tubes as well. I also had to beat the floor in some(which I can't even hardly tell anyway).
Check out this link...http://forums.tccoa.com/showthread.php?t=87389
post #5 of 21 (permalink) Old 08-08-2006, 04:07 PM Thread Starter
Thanks guys. Anyone make any very large shorties?
905LTB is offline
post #6 of 21 (permalink) Old 08-08-2006, 06:25 PM
I know that 351 swap shorties are 1 3/4".
post #7 of 21 (permalink) Old 08-08-2006, 11:33 PM Thread Starter
95,
Who makes them? Hooker?
905LTB is offline
post #8 of 21 (permalink) Old 08-09-2006, 07:52 AM
95,
BBK....
Here's a link over at Summit.
chrome
ceramic
post #9 of 21 (permalink) Old 08-09-2006, 09:40 AM
bad93bird's Avatar
Wouldn't you still have to modify the steering arms and linkage? I may be wrong and probably am.
QUADSQUAD MEMBER
post #10 of 21 (permalink) Old 08-09-2006, 10:10 AM
for shorties? I don't think so....but for the longtubes(at least the ones I installed), I had to.
I don't remember if MAdd did the steering shaft mod or not?????
I think he just routed the factory shaft through the LT's.
post #11 of 21 (permalink) Old 08-09-2006, 10:12 AM
bad93bird's Avatar
Ok. Will those work an a 5 oh?
QUADSQUAD MEMBER
post #12 of 21 (permalink) Old 08-09-2006, 10:24 AM
which ones?
post #13 of 21 (permalink) Old 08-09-2006, 10:29 AM
bad93bird's Avatar
chrome
ceramic[/QUOTE]
These links of shorties.
QUADSQUAD MEMBER
post #14 of 21 (permalink) Old 08-09-2006, 10:36 AM
honestly, I want to say yes.....but since I personally have not installed those on a 5.0 MN12, I don't know if they would work.
Hopefully someone chimes in that has some sort of shortie header on their MN12, can help us out.
post #15 of 21 (permalink) Old 08-09-2006, 10:57 AM
bad93bird's Avatar
Man if I remember, they have to be made for a MN12. I'm not sure either. I don't think the Mustang ones will work. I don't want to buy them and find out they don't. You know what I mean? Maybe I'll just put that 418 ci. motor in it and copy what you did????
QUADSQUAD MEMBER
post #16 of 21 (permalink) Old 08-09-2006, 11:29 AM
do it!!!!
I can give ya a pointer or 2
post #17 of 21 (permalink) Old 08-09-2006, 11:44 AM Thread Starter
Just go with the summit off road version for 140 dollars. Even if they don't fit you could always just send them back.
They have 1 5/8ths primary's
905LTB is offline
post #18 of 21 (permalink) Old 08-09-2006, 04:15 PM
bad93bird's Avatar
I can get Mac shorties for less.
QUADSQUAD MEMBER
post #19 of 21 (permalink) Old 08-09-2006, 05:27 PM Thread Starter
How much less?
905LTB is offline
post #20 of 21 (permalink) Old 08-10-2006, 04:57 AM
MaddMartigan's Avatar
It's not major work but here is your information: http://forums.tccoa.com/showthread.php?t=75182
1992 Ford Thunderbird SC
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.27 gears
Custom aluminum driveshaft
M5R2
Burned Chip for SN95 T4M0 ECM
OMGHI2U
MaddMartigan is offline
post #21 of 21 (permalink) Old 08-10-2006, 09:30 AM
bad93bird's Avatar
I'm not sure right now. I would have to call up the guy and ask him. It isn't on my next list of mods to do so I'm not in any real hurry. I'm kinda hopein my motor goes south and I can put a 347 ci in the car.
QUADSQUAD MEMBER
