Quitest resonator?? - TCCoA Forums
post #1 of 8 (permalink) Old 08-19-2006, 02:06 PM Thread Starter
Send a message via AIM to Bacondoggy
Quitest resonator??
I need one if I am basically not going to have anything else on my car - I am considering a dual in/out resonator - what one would offer the most -db noise reduction without compromising too much flow? I was thinking of even taking a borla XS muffler and using it there in place (if they make a size that will fit) any thoughts or ideas on this? If this gets done this way I will be using a "boom tube" nascar side exhaust so it will be the only place I could have a resonator/muffler
91 sc - put the stockgears back on, underdrive pullyes, rear air hydraulics, headers, no cats or resonator, lowered 1 1/2", 10% pulley, cam, 70k, rebuilt engine bored .30 over, finally fixed!
Bacondoggy is offline
post #2 of 8 (permalink) Old 08-26-2006, 09:14 AM
TMcColl's Avatar
Send a message via AIM to TMcColl
I have a 4.6L LX and I have replaced the resonator and third cat with a magnaflow dual in single out. I do have high flow cats on 2 1/4 down tubes but no mufflers on the rear. It is nice and quiet with just a bit of a rumble.
I think you would be fine with something similar.
Tony
Tony McColl
1994 LX 4.6L
New motor as of Aug 1st.
No Dyno Numbers yet.
Just two runs at 5800 ft.
http://www.cardomain.com/ride/2203515
TMcColl is offline
post #3 of 8 (permalink) Old 08-28-2006, 07:31 PM Thread Starter
I would be looking for a dual in/out resonator since I will be having boom tubes going out the side... what size (length/heigth) would be good for our cars? would a borla XS muffler work decent or magnaflow?
post #4 of 8 (permalink) Old 08-28-2006, 10:25 PM
Bradone's Avatar
Magnaflow 14468 DI/DO 2.5"
[email protected] (engine/trans is stock)
Bradone is offline
post #5 of 8 (permalink) Old 08-30-2006, 10:27 AM
TMcColl's Avatar
I used the Magnaflow #12258. It was 2 1/4 in 2 1/2 out. It was almost exactly the same length as the third cat and resonator.
T
Tony McColl
1994 LX 4.6L
TMcColl is offline
post #6 of 8 (permalink) Old 08-30-2006, 01:28 PM Thread Starter
so magnaflow's are better then borla's? I am not sure what diamater I will be using as the out will have to go from a round pipe to an oval transition, but what is about the length of these mufflers?
post #7 of 8 (permalink) Old 08-30-2006, 01:43 PM
Bradone's Avatar
Here, try this link:
http://store.summitracing.com/egnsea...115+4294903588
You can move around in here to find what you want. I can't say which is best. Magnaflow had the option I wanted. Maybe Borla does as well. Be aware of the tunnel opening you have to work with. Are you planning on going out both sides with your side exit. That is going to leave you a long way forward with the gas tank.
Bradone is offline
post #8 of 8 (permalink) Old 08-31-2006, 01:09 PM Thread Starter
Lightbulb
ok these are what I am planning on getting:
http://www.musclemotorsports.com/exh...-36--used.html
He said they are more like $50 now, but I still see it as a good deal. He also said most people cut them in half and run them on either side, wich is what I am probablly going to do. Any input would be appriciated.
