exhaust cut outs??? - TCCoA Forums
post #1 of 11 (permalink) Old 08-21-2006, 06:57 AM Thread Starter
4.3Lcougar's Avatar
exhaust cut outs???
wanted to install a set of mechanical cable exhaust cut out for my exhaust. especially for track set up. does anyone have these installed and are they worth the money to install???
1985 THUNDERBIRD CFI 5.0L..
4.3Lcougar is offline
post #2 of 11 (permalink) Old 08-24-2006, 06:43 AM Thread Starter
4.3Lcougar's Avatar
since no one replied, here is the picture of the cut outs
http://store.summitracing.com/partde...5&autoview=sku
post #3 of 11 (permalink) Old 08-24-2006, 10:31 PM
Merlon's Avatar
i wanted a set of electronic cutouts
those seem fine if you using them for race track purposes, instead of scarring people next to you at the light, then going back to normal when the cops show up.
id do it if it werent like $300 for each electric cut out, plus install.
00 GT transmission,Jmod,30,000 gvw transmission cooler
Air silencer removed(cone filter added w/ heatshield)
shaved emblems, doors, trunk, and antenna
Clear corners
chrome 95sc rims
20% tint all the way around,
6gallon air tank capacity, Viair 400c commpressor
175psi pressure switch
custom guages by Scott H.
http://www.cardomain.com/ride/2733945
Merlon is offline
post #4 of 11 (permalink) Old 08-24-2006, 10:52 PM
Baby Huey
warmaster259's Avatar
I wanted electrics but they want to friggin much for em, guess ill be going cable operated too.
A thought: Technically you may be able to run the cables into the cabin, then you can pop em open to show off or race at the track.
Jim
warmaster259 is offline
post #5 of 11 (permalink) Old 08-25-2006, 01:07 AM Thread Starter
4.3Lcougar's Avatar
Originally Posted by warmaster259
I wanted electrics but they want to friggin much for em, guess ill be going cable operated too..
im thinking that the cables will serve the same purpose as the electric minus the added weight of switches, relays, wires. not that it would make that much of a difference.
but the mechanical should be fairly easy to install., just a few welds and GTG
post #6 of 11 (permalink) Old 08-25-2006, 08:12 AM
loudpipessavelives's Avatar
Send a message via AIM to loudpipessavelives
Yeah i also thought about them, but they only have them in 2'' at summit, and i have 2 1/4'' duals...Also i have heard a downfalll with the mechanical cut outs...people seem to have a constant slight exhaust leak because of the little flap not shutting all the way. I have talked to 2 guys with old 30 something chevy coupes...Electric in my book would be the way to go but like you guys said the price is killer
93 Bird/ Trick Flow 5.0-- awaiting some fresh paint
99 Marquis on 20's (daily)
01 Mustang Cobra with bolt on's-- 22k miles, might be for sale soon
http://www.cardomain.com/id/CDogg93
loudpipessavelives is offline
post #7 of 11 (permalink) Old 08-25-2006, 11:30 AM
5.0 bird's Avatar
Send a message via MSN to 5.0 bird
A friend of mine has a set of the electric cut outs, that he uses for track purposes, on his lt1 camaro and they work and sound really good. My dad ran the cable operated cut outs on a 68 mustang he had a long time ago and they worked for a while, then they rusted/carboned up and wouldn't open anymore plus they leaked a little when closed. I guess it's just another one of those you get what you pay for deals.
IMO if you want a cheap and effective cut out you oughta think about block off plates with wingnuts. You do have to get out to remove them but they work well.
Matt
1986 Cougar 5.0
1989 Mk VII LSC 5 speed (sold)
1992 Thunderbird Sport 5.0 (sold)
5.0 bird is offline
post #8 of 11 (permalink) Old 08-25-2006, 06:10 PM
those were the kind i was thinking about running
krazy4 is offline
post #9 of 11 (permalink) Old 08-28-2006, 08:37 PM
3rd Gear Chirper
hotbird's Avatar
Those Race-Readies...what's up with the 4 dark-colored gaskets?? I would imagine the lighter (2) would be for the block-off plates...but the other 4??
hotbird is offline
post #10 of 11 (permalink) Old 08-29-2006, 08:03 PM
5.0 Chero's Avatar
I made a set of air powered cutouts fer the Chero. used gate valves and machined the bonnet to aceept bimba air cylinders. Sound great and open and close fast unlike the electric ones.
More fun to get ones walking down the side of the road.
THE PYL !
91 Tbird lx 5.0 swap
GONE 93 5.0 Stang vert
86 F250 Diesel 4x4
GONE 89 Aerostar
2003 F350 Super duty
1996 Exploder
5.0 Chero is offline
post #11 of 11 (permalink) Old 08-29-2006, 09:32 PM
i have a set of the ele cutouts just for show...
1996 Thunderbird 4.6 -Sold-
Bunch of motorcycles
2004 F150
KrAzyT is offline
