Header Instal - TCCoA Forums
post #1 of 5 (permalink) Old 08-27-2006, 02:16 PM Thread Starter
RodKnockin5.0's Avatar
Header Instal
I have a 92 Sport, and I bought a set of JBA headers and will be installing them this fall. I'm sure that someone has done this before but when I searched the site I couldn't find any info on the swap. I was wondering if some could atleast tell me how hard this swap is and how involved is it. Also I got a cam and will be installing that after the headers and dual exhaust. I was also wondering how hard that was and what all was needed to do the swap. Any insight would be much appriecated, thanks in advance!
RodKnockin5.0 is offline
post #2 of 5 (permalink) Old 08-27-2006, 02:27 PM
95xbird's Avatar
Well i know when i did my headers on my 4.6 Bird it involved me to drop the front K-member and pull it out from underneath the car.It was a headace and it is not worth the trouble for JBA's IMO.They didnt provide any gain what so ever.Might be different for the 5.0
Its slow, Really.
LS1 KILLER
1995 svo Tbird. R.I.P.
95xbird is offline
post #3 of 5 (permalink) Old 08-27-2006, 02:34 PM
Well, mine were a pain in the *** to install, since I have a 351W and no one makes headers for my application, yours should be more straight forward.
Did you get LT's or shorties?
post #4 of 5 (permalink) Old 08-27-2006, 02:38 PM Thread Starter
I got the shorties. Am I gonna have to take out the motor mounts or do anything to raise the motor. Any word on the cam install?
post #5 of 5 (permalink) Old 08-28-2006, 08:30 PM
Bradone's Avatar
I have not installed mine yet but looks simple. I am waiting motor mounts so I have not installed yet, so I will not have answer. Plan to do both at the same time. How were the ports on your headers. Mine were terrible. Took me 6 hours with a grinder to clean them up. JBA claimed it is common on Stainless applications. Bulls...! I would think the biggest problem is breaking bolts loose. You will have to modify the dipstick tube bracket. What do you ever do to this car without modifications?
Brad
[email protected] (engine/trans is stock)
Bradone is offline
