Can a Di/Do muffler serve as a H pipe? - TCCoA Forums
post #1 of 4 (permalink) Old 08-29-2006, 01:41 PM Thread Starter
Does anyone know if magnaflow's dual in/dual out mufflers are connected on the inside? I want to put my muffler there, but then i wouldnt have much room for an H pipe.
I have never built a dual exhaust but i am under the impresion the H pipe is an important piece of the exhaust.
Freshmaker is offline
post #2 of 4 (permalink) Old 08-29-2006, 01:43 PM
Traveler's Avatar
Yep, there's an X-pipe built into them. If you get one and look through it, you can see how its done.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #3 of 4 (permalink) Old 08-29-2006, 01:48 PM
Bradone's Avatar
Not all of them are. The ones noted as "TruX" are. The only 2.5" I found on their website was Model 14468. I question if Model 12468 is not aswell but does not have in its comments. Both seem to be the same spec just one is polished. I have another post in the exhaust section on how to buy them cheap.
[email protected] (engine/trans is stock)
Bradone is offline
post #4 of 4 (permalink) Old 08-29-2006, 01:50 PM
Bradone's Avatar
A followup. I was referring to mufflers that will fit in the tube without conflict. That info I got from racecougar. You can look up his posts and see the installation.
Bradone is offline
