Opinion and Experience Wanted - TCCoA Forums
post #1 of 3 (permalink) Old 09-05-2006, 12:15 PM Thread Starter
PCD
Confirmed V6 Nut
I have to fix my exhaust. I detail what I'm thinking of doing, asking for your feed back.
I'm going to dual 2 1/2" pipes, and only 2 high flow cats. I'll go to a dual in and dual out muffler placed about where the resonator was and run dual pipes to the back.
Any suggestions or tips on a good, but cheap muffler for this application?
Also, I'm using aluminum pressure piping I'm getting for free.
PCD is offline
post #2 of 3 (permalink) Old 09-05-2006, 07:30 PM
Bradone's Avatar
Check this out plus I'll go find a post I made for parts sources:
http://forums.tccoa.com/showthread.php?t=85069
[email protected] (engine/trans is stock)
Bradone is offline
post #3 of 3 (permalink) Old 09-05-2006, 07:32 PM
Bradone's Avatar
Here is the link:
http://forums.tccoa.com/showthread.php?t=88131
Bradone is offline
