Rear-mounted GM-5 turbo - TCCoA Forums
post #1 of 17 (permalink) Old 10-11-2007, 03:34 PM Thread Starter
fordmuscle's Avatar
I have a Borg-Warner GM-5 turbo from a chevy diesel truck. Its really big, and I want to rear -mount it at the rear y-pipe, where the exhaust splits to duels again. I only want about 4-5 psi. of boost and I dont care about lag. Does this idea sound possible? In terms of fitment, I plan on cutting into the spare tire well (trunk) a little.
Any info on this turbo, or ideas on how to do this would be appreciated.
Also, at these low boost levels, do you think my stock fuel system will keep up?
thanks
'77 F-350 460ci- Daily Driver
''94 T-Bird LX 4.6L SOHC
Mostly stock w/ 189,000 mi., but not for long. Soon to be a nitrous breathing 4000 lb. IRS terror.
fordmuscle is offline
post #2 of 17 (permalink) Old 10-11-2007, 03:40 PM
Stevo1111's Avatar
Send a message via AIM to Stevo1111
I would suggest looking in depth into remote mounted turbo set ups. Before that, boosting a 189k 4.6 will end in failure, sooner then later.
1991 Thunderbird 5.0:
Cobra upper and lower intake, 65mm Ford Racing TB, E303 cam, opened up E7 heads, Mac headers, Magnaflow true Duals, Tragnsgo shift kit, 3.73's in an auburn posi, hardly spins the tires! I NEED MORE SPEED! Anyone have anything quicker they want to trade for? PM ME!
http://s141.photobucket.com/albums/r...1165080039.pbw
Stevo1111 is offline
post #3 of 17 (permalink) Old 10-11-2007, 04:09 PM
twin turbo 281's Avatar
4-5 psi is a very safe level even on a 189k mod motor. The fuel system is ok if all is in good working order. You will need to tune or tune with a fmu and other piggy back devices. Look hard for specs on the turbo (stamped on the turbo) look for AR. numbers for the intake and exhaust. Also research the type of turbo and specs. For the fuel system you may just want to drop in a bigger pump and a adjustable FPR.
2x95 cougars to the scapper
51 Mack A51T restoration
twin turbo 281 is offline
post #4 of 17 (permalink) Old 10-11-2007, 04:23 PM Thread Starter
fordmuscle's Avatar
thanks stevo- I DO plan on blowing this motor eventually and swapping in a new one.
twin turbo 281, that is exactly why I chose 4-5 psi, is cuz, even though I have 190,000 mi. my motor runs good, and I take really good care of it.
Thanks for the tuning info, I hopes this works! It will be very unique.
Paul
post #5 of 17 (permalink) Old 10-11-2007, 05:36 PM
thanks
I think the first thing you need to do is find the compressor map for the turbo. You say you don't care about lag, but what if you get no boost until you're at 4500 rpm? Which could be a serious possibility with an oversized turbo.
There is a LOT more to installing a turbocharger on an engine than just slapping it on.
And I also wouldn't put ANY boost into an engine with 189K miles without at the very least do a leak down test on each cylinder.
Just my .02.
69 F100 LWB w/460 Engine
post #6 of 17 (permalink) Old 10-24-2007, 06:39 PM
seawalkersee's Avatar
TT281, What happened to your post?
Also, even with that kind of milage, there will be no problem on a 4.6 so long as it has had maintenence done to it. These engines will last a LONG time in stock form.
Chris
seawalkersee is offline
post #7 of 17 (permalink) Old 10-24-2007, 11:23 PM
TCCoA Founder
Sir William's Avatar
That turbo is WAY too big to spool up and give you boost. This is mine:
Here's a shot of it installed:
God Bless and Fly Low!
Sir William
TCCoA Founder
97 Thunderbird LX - Smoothed
99 Expedition Eddie Bauer
04 Grand Cherokee Overland
Sir William is offline
post #8 of 17 (permalink) Old 10-25-2007, 09:11 AM
You have an clip of that thing running yet? What about a timeslip or a dyno run?
Chris
post #9 of 17 (permalink) Old 10-25-2007, 09:46 AM
TCCoA Founder
It hasn't been running for a while. Turbo has been off it for a year....hope to get it back on soon. Plus it's been without tires/wheels since June. This too should get cleared up in the next week or so. I'm jonesin to drive it again.
Sir William
TCCoA Founder
post #10 of 17 (permalink) Old 11-20-2007, 06:25 PM
Sir William,
What diameter of tubing are you running on the cold side? I'm trying to put some research together right now...very clean install i might add.
Chris.
Boots is offline
post #11 of 17 (permalink) Old 11-21-2007, 02:40 AM
BIG PETE's Avatar
Sir William,
Ever work out the technicalities of getting that kit out there?
Pete
-97 XR-7
-5.0 Big Bore ...
Density Altitude = 4132'
1/8 mile: 8.75 @ 82
BIG PETE is offline
post #12 of 17 (permalink) Old 11-22-2007, 11:32 PM
David Neibert's Avatar
Bill,
Why is the turbo off the car....did something happen to it ?
David
David Neibert is offline
post #13 of 17 (permalink) Old 11-22-2007, 11:40 PM
tbirdbrain's Avatar
Originally Posted by David Neibert View Post
Bill,
David
It was probably best described as a “modestly catastrophic seal failure.” It has been rebuilt, rebalanced and made a touch more colorful with ceramic coating and powder coating.
tbirdbrain is offline
post #14 of 17 (permalink) Old 11-22-2007, 11:44 PM
TCCoA Founder
Well, first it inhaled/imploded a filter which started sucking oil around the seals....it was downhill from there.
The filter spec'd by STS was too small. Once it got a tad bit dirty (which it very much will back there), it couldn't flow enough air. The turbo started imploding the filter...when it couldn't pull enough air, it started sucking oil around the seals....I didn't realize this. Once that starts, it's not long before it's not much good any more.
So I sent the whole thing down to BrainCoating in Florida who rebuilt the unit with new seals and did me a sweet ceramic and powder coating job on it. One of these days, I'll get to get it back on the car....I haven't driven it since sometime in June.
Pete: The only way I could ever get a kit together would be to have the piping all fabbed up myself. STS, after hours of discussions, decided they weren't interested. I don't have the money to get 3 or 4 sets of piped bent up, so mine is still the only one out there.
Sir William
TCCoA Founder
post #15 of 17 (permalink) Old 11-26-2007, 01:00 PM
Bill,
I always wondered about that filter setup. Is there anything mounted in the trunk directly above it so that you could draw air from a big-ass filter up in there?
I envision a closed box with an open bottom mounted over a hole in the trunk pan with the filter on an elbow poking up into the cavity. Less road grunge and more filter area.
You have to miss driving your car pretty bad by now.
richardm
Most fun I ever had was with the Texas TCCOA guys making power and drag racing.
Now I am using a 2001 BMW M3 Vert for fun.
RichardM is offline
post #16 of 17 (permalink) Old 11-27-2007, 12:05 AM
Bummer...my car has had it share of problems too over this past year. Balancer failure, timing cover leaked several quarts of coolant into the motor, broke the motor mounts, wastegate spring lost tension coundn't make any boost, electronic boost controller quit saving changes and I accidently overboosted the motor big time...ect...ect...
Everything is fine now, but I'm sure something new will go wrong before spring.
David
post #17 of 17 (permalink) Old 12-03-2007, 10:31 AM
jahnaboi's Avatar
Pretty clean setup! How much was the blanket over the air filter from K&N if you don't mind me asking?
jahnaboi is offline
